cgal-discuss - [cgal-discuss] how to do operation similar Polyhedron_3 join_loop
  • To:
  • Subject: [cgal-discuss] how to do operation similar Polyhedron_3 join_loop
  • Date: Fri, 18 Feb 2011 17:04:15 +0100 (CET)
Hi everyone, I now have a problem as follows:
I have two rings of vertices (halfedges) with different degrees (number of
edges), each ring can be seen as a hole, which means the halfedges on each
ring
are border edges. Now i want to merge the two rings with some algorithm, how
to
use the functions in Polyhedron_3, for example split_edge,join_facet..., to
connect the vertices on the two rings one by one, in order to finish this task
please?
Actually, this problem can be explained as: how to do the "join_loop"
operation
in Polyhedron_3 when the degrees of the two facets are different? I know the
rule of how to connect the vertices on the two rings gradually, and just don't
know how to do it through the functions provided in Polyhedron_3, since the
two
rings are diconnected to each other at first.
Meanwhile, I just want to use the operations in Polyhedron_3 without
rebuilding
the whole mesh using the "delegate " method or Nef_polyhedron.
Could you please help me? Thanks!
