- To:
- Subject: Re: [cgal-discuss] how to do operation similar Polyhedron_3 join_loop
- Date: Fri, 18 Feb 2011 17:30:07 +0100
wrote:
Hi everyone, I now have a problem as follows:Have you tried splitting some edges in the loop having the less boundary
I have two rings of vertices (halfedges) with different degrees (number of
edges), each ring can be seen as a hole, which means the halfedges on each
ring
are border edges. Now i want to merge the two rings with some algorithm, how
to
use the functions in Polyhedron_3, for example split_edge,join_facet..., to
connect the vertices on the two rings one by one, in order to finish this task
please?
halfedges (see split_vertex and split_edge)?
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Class_Polyhedron_3.html
Actually, this problem can be explained as: how to do the "join_loop"
operation
in Polyhedron_3 when the degrees of the two facets are different? I know the
rule of how to connect the vertices on the two rings gradually, and just don't
know how to do it through the functions provided in Polyhedron_3, since the
two
rings are diconnected to each other at first.
Meanwhile, I just want to use the operations in Polyhedron_3 without
rebuilding
the whole mesh using the "delegate " method or Nef_polyhedron.
Could you please help me? Thanks!
- [cgal-discuss] how to do operation similar Polyhedron_3 join_loop, wangk0705, 02/18/2011
- Re: [cgal-discuss] how to do operation similar Polyhedron_3 join_loop, Sebastien Loriot (GeometryFactory), 02/18/2011
- Re: [cgal-discuss] how to do operation similar Polyhedron_3 join_loop, Kye Wong, 02/19/2011
- Re: [cgal-discuss] how to do operation similar Polyhedron_3 join_loop, Guillaume Damiand, 02/19/2011
