cgal-discuss - [cgal-discuss] CGAL::natural_neighbor_coordinates_2 and typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt
  • To:
  • Subject: [cgal-discuss] CGAL::natural_neighbor_coordinates_2 and typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt
  • Date: Sun, 20 Feb 2011 13:56:20 -0800 (PST)
Hi
I have a Delaunay "terrain" Triangulation
struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef CGAL::Triangulation_euclidean_traits_xy_3<K>  Gt;
typedef CGAL::Triangulation_vertex_base_2<Gt>             Vb;
typedef CGAL::Triangulation_face_base_2<Gt>               Fb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb>      Tds;
typedef CGAL::Delaunay_triangulation_2<Gt,Tds>            Delaunay;
Then, I pretend to calculate the distance between some additional 3D points and my Delaunay Triangulation, kind of distance between points and a existing surface.
Can I use CGAL::natural_neighbor_coordinates_2 to perform that task. The latter "support" data "typedef CGAL::Triangulation_euclidean_traits_xy_3<K>  Gt"?
I read this http://cgal-discuss.949826.n4.nabble.com/Bug-CGAL-natural-neighbor-coordinates-2-with-CGAL-Triangulation-euclidean-traits-td2274818.html however I'm not able to realize if at least there are an answer to my topic.
After several compilation errors, i'm trying a weaker solution. Using the LOCATE function i identify where my 3D points fall in the Delaunay_triangulation_2, and then I made the interpolation myself. Unfortunately , I don't know how can I get the vertex coordinates when my 3D points coincides with a Delaunay::EDGE.
Finnaly, any suggestion to interpolate my 3D points with the Delaunay VERTEX coordinates outside the triangulation strucutre?
typedef Delaunay::Locate_type    Locate_type;
typedef Delaunay::Face_handle    Face_handle;
Locate_type lt;
int li;
 const K::Point_3 pointLayer(4,4,1);
 std::cout<<pointLayer.x()<<std::endl;
 Face_handle start = Face_handle();
 Face_handle c= dt.locate(pointLayer,lt,li,start);
 switch (lt)
       case Delaunay::VERTEX:{
      std::cout<<"Ok, dist=0"<<std::endl;
;} break;
       case Delaunay::FACE:{
      typedef Gt::Triangle_2 triangle_2;
      triangle_2 triangle=dt.triangle (c);
      std::cout<<triangle[0]<<std::endl;
      std::cout<<triangle[1]<<std::endl;
      std::cout<<triangle[2]<<std::endl;
        std::cout<<"Then , I interpolate such values<<std::endl;
 } break;
       case Delaunay::EDGE:{
      std::cout<<"I dont konw how can i get the VERTEX coordiantes to interpolate my 3D point "<<std::endl;
 } break;
       case Delaunay::OUTSIDE_CONVEX_HULL:{std::cout<<"convex"<<std::endl;;}break;
       case Delaunay::OUTSIDE_AFFINE_HULL:{std::cout<<"affine"<<std::endl;;};
Any help is appreciated
Antonio
View this message in context: CGAL::natural_neighbor_coordinates_2 and typedef CGAL::Triangulation_euclidean_traits_xy_3 Gt
