[cgal-discuss] Re: CGAL::natural_neighbor_coordinates_2 and typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt
- To:
- Subject: [cgal-discuss] Re: CGAL::natural_neighbor_coordinates_2 and typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt
- Date: Mon, 21 Feb 2011 06:49:46 -0800 (PST)
Thank you for your reply. Yes, I have an example followed by the error
message:
struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt;
typedef CGAL::Triangulation_vertex_base_2<Gt> Vb;
typedef CGAL::Triangulation_face_base_2<Gt> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb> Tds;
typedef CGAL::Delaunay_triangulation_2<Gt,Tds> Delaunay;
PointCloudManip::delaunayTriangulation()
typedef K::Point_3 Point_3;
std::vector<Point_3> points;
points.push_back(Point_3(0,0,1));
points.push_back(Point_3(4,0,1));
points.push_back(Point_3(0,4,1));
points.push_back(Point_3(4,4,1));
points.push_back(Point_3(5,4,1));
Delaunay dt;
dt.insert(points.begin(), points.end());
return dt;
void PointCloudManip::validate_CBH_Delaunay_Neighbors2(const
CGAL::Delaunay_triangulation_2<Gt,Tds> dt)
const std::string validationCBH
("/home/aferraz/Bureau/validationCBH.txt");
ofstream f (validationCBH.c_str(),ios::app);
typedef Delaunay::Face_handle Face_handle;
typedef std::vector<std::pair<K::Point_2,K::FT> > Point_coordinates_vector;
K::Point_2 p(0.5,0.3,1);
Point_coordinates_vector coords;
Face_handle start = Face_handle();
CGAL::Triple<std::back_insert_iterator<Point_coordinates_vector>,K::FT,bool>
result=CGAL::natural_neighbor_coordinates_2(dt,p,std::back_inserter(coords),start);
The message error is:
(CGAL::Delaunay_triangulation_2<CGAL::Triangulation_euclidean_traits_xy_3<K>,
CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_2<CGAL::Triangulation_euclidean_traits_xy_3<K>,
CGAL::Triangulation_ds_vertex_base_2<void> >,
CGAL::Triangulation_face_base_2<CGAL::Triangulation_euclidean_traits_xy_3<K>,
CGAL::Triangulation_ds_face_base_2<void> > > >)’:
/home/aferraz/code/Forest/src/manip/PointCloudManip.cpp:4705: error: no
matching function for call to ‘natural_neighbor_coordinates_2(const
CGAL::Triangulation_ds_face_base_2<void> > > >&,
CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > >&,
std::back_insert_iterator<std::vector<std::pair<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> >, double>,
std::allocator<std::pair<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> >, double> > > >,
PointCloudManip::validate_CBH_Delaunay_Neighbors2(CGAL::Delaunay_triangulation_2<CGAL::Triangulation_euclidean_traits_xy_3<K>,
CGAL::Triangulation_ds_face_base_2<void> > > >)::Face_handle&)’
Thank you
Antonio
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-natural-neighbor-coordinates-2-and-typedef-CGAL-Triangulation-euclidean-traits-xy-3-K-Gt-tp3315539p3317456.html
- [cgal-discuss] CGAL::natural_neighbor_coordinates_2 and typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt, tochaf, 02/20/2011
- Re: [cgal-discuss] CGAL::natural_neighbor_coordinates_2 and typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt, Sebastien Loriot (GeometryFactory), 02/21/2011
- [cgal-discuss] Re: CGAL::natural_neighbor_coordinates_2 and typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt, tochaf, 02/21/2011
- Re: [cgal-discuss] Re: CGAL::natural_neighbor_coordinates_2 and typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt, Sebastien Loriot (GeometryFactory), 02/21/2011
- Re: [cgal-discuss] Re: CGAL::natural_neighbor_coordinates_2 and typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt, Sebastien Loriot (GeometryFactory), 02/22/2011
- [cgal-discuss] Re: CGAL::natural_neighbor_coordinates_2 and typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt, tochaf, 02/22/2011
