cgal-discuss - Re: [cgal-discuss] which lib does a CGAL example actually link to?
  • To: <>
  • Subject: Re: [cgal-discuss] which lib does a CGAL example actually link to?
  • Date: Tue, 22 Feb 2011 10:23:57 +0800
  • Importance: Normal
yanyajie wrote:
Hi all,
I am playing with CGAL example "Voronoi_daigram_2" to see if CGAL is
correctly installed and configured.
By default, in the "additional dependencies" item of "linker" option,
there is no gmp or CGAL related libs specified. Since this project is
configured using cmake previously, I thought the configuration was
correct and shouldn't be tamed. However, building it gives me the
following symbols not found: gmpq_clear, gmpq_mul, gmpq_add, gmpq_sub,
etc.. Then I added gmp.lib to the dependencies, the errors gone.
You should not have such problems. Did you use cmake to configure these
examples? if so, are you a CMakeLists.txt generated by CGAL's script
cgal_create_cmake_script or you wrote it by hand?
S.
Dear S.,
Thanks to respond!
Yes, I used cmake to configure this example, and the CMakeLists.txt was generated
by CGAL's script rather than my hand.
So, are you implying that if GMP lib is a must to build the example, then the
project configured by cmake should have specified GMP in its "dependencies" right?
What's more, as asked in the last mail, how can I set VS2010 to see exactly what libs
are linked to a .exe?
THX!
Yan.
I want to know what libs does a CGAL example actually link to. I use
VS2010. I tried to set "MSBuild project log" in "project and solution ->
generate and run" to "diagnostic", but the log generated still doesn't
list any lib the project links to. So, does any one know how to enable
this detailed info in VS2010??
Besides, is it the case that this example does not need any CGAL lib
since there is none specified in "additional dependencies"? If it does
need and automatically link to the lib it wants, then what makes this
possible? Is it the cmake configuration process, or something else? Need
some light shed on this question, too!
THX in advance!
Yajie Yan.
