cgal-discuss - [cgal-discuss] which lib does a CGAL example actually link to?
  • To: "cgal-discuss-list" <>
  • Subject: [cgal-discuss] which lib does a CGAL example actually link to?
  • Date: Sat, 19 Feb 2011 11:28:00 +0800
  • Importance: Normal
Hi all,
I am playing with CGAL example "Voronoi_daigram_2" to see if CGAL is correctly installed and configured.
By default, in the "additional dependencies" item of "linker" option, there is no gmp or CGAL related libs specified. Since this project is configured using cmake previously, I thought the configuration was correct and shouldn't be tamed. However, building it gives me the following symbols not found: gmpq_clear, gmpq_mul, gmpq_add, gmpq_sub, etc.. Then I added gmp.lib to the dependencies, the errors gone.
I want to know what libs does a CGAL example actually link to. I use VS2010. I tried to set "MSBuild project log" in "project and solution -> generate and run" to "diagnostic", but the log generated still doesn't list any lib the project links to. So, does any one know how to enable this detailed info in VS2010??
Besides, is it the case that this example does not need any CGAL lib since there is none specified in "additional dependencies"? If it does need and automatically link to the lib it wants, then what makes this possible? Is it the cmake configuration process, or something else? Need some light shed on this question, too!
THX in advance!
Yajie Yan.
