Re: [cgal-discuss] Installing CGAL3.7 and error compiling algebraic_curves exemple
- To:
- Subject: Re: [cgal-discuss] Installing CGAL3.7 and error compiling algebraic_curves exemple
- Date: Tue, 22 Feb 2011 20:04:48 +0100
Hi,
On 02/22/2011 05:57 PM,
wrote:
> Conversely if I compile the examples I have the following error for
> "algebraic_curves":
> In file included from /usr/local/include/boost/numeric/interval.hpp:18,
> from
> /CGAL3.7/examples/Arrangement_on_surface_2/../../include/CGAL/Algebraic_kernel_d/Interval_evaluate_1.h:30,
> from
> /CGAL3.7/examples/Arrangement_on_surface_2/../../include/CGAL/Algebraic_kernel_d_1.h:41,
> from
> /CGAL-3.7/examples/Arrangement_on_surface_2/../../include/CGAL/Arr_algebraic_segment_traits_2.h:25,
> from
> /CGAL-3.7/examples/Arrangement_on_surface_2/algebraic_curves.cpp:14:
> /usr/local/include/boost/numeric/interval/hw_rounding.hpp:40:4: error:
> #error Boost.Numeric.Interval: Please specify rounding control mechanism.
> make[3]: ***
> [examples/Arrangement_on_surface_2/CMakeFiles/algebraic_curves.dir/algebraic_curves.o]
> Error 1
> make[2]: ***
> [examples/Arrangement_on_surface_2/CMakeFiles/algebraic_curves.dir/all]
> Error 2
> make[1]: *** [CMakeFiles/examples.dir/rule] Error 2
> make: *** [examples] Error 2
> Any suggestions?
> Thank you in advance!
it would be nice if you would include some important information, like which
linux distribution you are using, 32 or 64bit, compiler and version, Boost
version. And please attach the first ~45 lines of
/usr/local/include/boost/numeric/interval/hw_rounding.hpp.
Joachim
- [cgal-discuss] Installing CGAL3.7 and error compiling algebraic_curves exemple, cecilia, 02/22/2011
- Re: [cgal-discuss] Installing CGAL3.7 and error compiling algebraic_curves exemple, Joachim Reichel, 02/22/2011
