- To:
- Subject: [cgal-discuss] face_handle error
- Date: Tue, 22 Feb 2011 12:19:50 -0800 (PST)
Hi,
In my program I have a hierarchical delaunay triangulation (representing a
terrian) and I have some query points. I should find the face that this
query point locates and compute the distance of the point from that face.
I locate the point with:
Face_handle fh1 = dt.locate(pl[i].p);
But my programs gets runtime error when I want to access the vertices of
this face:
Vertex_handle v1=Face->vertex(1);
(In compute "computeError" function that which I wrote for computing the
distance of the point from the face)
does any one has any idea whats the reason and how I can resolve it?
Maybe the reason is that the query point is on an edge or vertex! If so, how
could I handle this cases?
Is the problem with my triangulation or what?
(In addition I appreciate it if some one could tell me a way for computing
the distance of the point from the face, I'm going to compute it by
accessing the vertices of the face and ..., but I don't know how to access
the vertices coordinates yet . Is there an easier way to do this?)
Thanks in advance,
Here is my code:
#include <CGAL/Polytope_distance_d.h>
#include <CGAL/Polytope_distance_d_traits_3.h>
#include <CGAL/Euclidean_distance.h>
#include <CGAL/Triangulation_vertex_base_with_info_2.h>
#include <CGAL/Triangulation_2.h>
#include <CGAL/Triangulation_euclidean_traits_xy_3.h>
#include <CGAL/Delaunay_triangulation_2.h>
#include <CGAL/Triangulation_hierarchy_2.h>
#include <vector>
#include <fstream>
#include <CGAL/point_generators_2.h>
#include <CGAL/algorithm.h>
#include <cassert>
#ifdef CGAL_USE_GMP
#include <CGAL/Gmpzf.h>
typedef CGAL::Gmpzf ET;
#else
#include <CGAL/MP_Float.h>
typedef CGAL::MP_Float ET;
#endif
using namespace std;
using namespace CGAL;
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Triangulation_vertex_base_with_info_2<int,K> Vbb;
typedef CGAL::Triangulation_hierarchy_vertex_base_2<Vbb> Vb;
typedef CGAL::Triangulation_face_base_2<K> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb> Tds;
typedef CGAL::Delaunay_triangulation_2<K,Tds> Dt;
typedef CGAL::Triangulation_hierarchy_2<Dt> Triangulation;
typedef Triangulation::Point Point;
typedef Triangulation::Vertex_handle
Vertex_handle;
typedef Triangulation::Finite_faces_iterator
Finite_faces_iterator;
typedef Triangulation::Face_handle
Face_handle;
Vertex_handle;
typedef K::Point_3
Point_3;
typedef CGAL::Polytope_distance_d_traits_3<K, ET, double> Traits;
typedef CGAL::Polytope_distance_d<Traits> Polytope_distance;
struct PointData{
Point p;
double z;
double er;
bool in;
double computeError(Point query,double z,Face_handle Face){
double x=query.x();
double y=query.y();
K::Point_3 p(x,y,z);
K::Point_3 P[1] = { p};
K::Point_3 Q[3] = { p,p,p};
Vertex_handle v2=Face->vertex(2);
Vertex_handle v3=Face->vertex(0);
Polytope_distance pd(P, P+1, Q, Q+3);
assert (pd.is_valid());
// get squared distance
double dis=0;
dis=sqrt(CGAL::to_double (pd.squared_distance_numerator())
/CGAL::to_double (pd.squared_distance_denominator()));
return dis;
int main()
std::ifstream in("terrain.txt");
std::istream_iterator<Point> begin(in);
std::istream_iterator<Point> end;
Triangulation dt;
double x,y,z;
x=y=z=0;
double maxX,minX,maxY,minY;
double curMaxError=100;//this is computed
double maxEr=0;//this must be input
double maxZ=1000;
vector<PointData> pl;
bool first=true;
while(in>>x>>y>>z){
Point tempP(x,y);
PointData pd;
pd.er=0;
pd.in=false;
pd.z=z;
if(first){
maxX=minX=x;
maxY=minY=y;
first=false;
pd.p=tempP;
pl.push_back(pd);
//adding the 4 corner
//for now
Point t00(minX,minY);
Point t01(minX,maxY);
Point t10(maxX,minY);
Point t11(maxX,maxY);
dt.insert(t00);
dt.insert(t01);
dt.insert(t10);
dt.insert(t11);
while(curMaxError>maxEr){
int candidIndex=0;
double tempMax=0;
int i;
for(i=0;i<pl.size();i++){
if(pl[i].in)continue;
Vertex_handle h1=fh1->vertex(0);
pl[i].er=computeError(pl[i].p,pl[i].z,fh1);
if(pl[i].er>tempMax){
tempMax=pl[i].er;
candidIndex=i;
dt.insert(pl[candidIndex].p);
pl[candidIndex].in=true;
curMaxError=tempMax;
cout << "# of all points: "<<pl.size() << endl;
cout << "# of simplification points: "<<dt.number_of_vertices() <<
endl;
cout << "Error: "<< curMaxError<< endl;
return 0;
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/face-handle-error-tp3319970p3319970.html
- [cgal-discuss] face_handle error, Farzaneh, 02/22/2011
- Re: [cgal-discuss] face_handle error, Sebastien Loriot (GeometryFactory), 02/23/2011
