- To:
- Subject: [cgal-discuss] The problem when I compile the demo mesh_3
- Date: Thu, 24 Feb 2011 12:09:47 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=IbaO4PGT4PZUGCwzz3jpfO4vGuLUlcsBmltk1sIJAmURcuHoYC8eE0Z4BHqm8wCr1T a8sR7TKU9BrawMW8al2J+AezPiiAo2Ex5eagkXZ7gl2YGb4A/NVhpxeV8+M2dVMDbUHR oQfv/BvL4K4pKsX/4uQq4Fp1JsZZ4ljryrLI8=
I have installed the CGAL 3.7 on Windows 7 for Visual studio 2008, and have compile the CGAL library sucessfully.
But when I try to complie the demo of mesh_3, I get the error information as below:
1>Generating Scene_moc.cpp
1>moc: Cannot open options file specified with @
1>Usage: moc [options] <header-file>
1> -o<file> write output to file rather than stdout
1> -I<dir> add dir to the include path for header files
1> -E preprocess only; do not generate meta object code
1> -D<macro>[=<def>] define macro, with optional definition
1> -U<macro> undefine macro
1> -i do not generate an #include statement
1> -p<path> path prefix for included file
1> -f[<file>] force #include, optional file name
1> -nw do not display warnings
1> @<file> read additional options from file
1> -v display version of moc
1>Project : error PRJ0019: A tool returned an error code from "Generating Scene_moc.cpp"
I have the Scene_moc.cpp file under the directory of /demo/mesh_3_demo/, and what I should do for this error?
- [cgal-discuss] The problem when I compile the demo mesh_3, neman, 02/24/2011
- Re: [cgal-discuss] The problem when I compile the demo mesh_3, Laurent Rineau (GeometryFactory), 02/24/2011
- Re: [cgal-discuss] The problem when I compile the demo mesh_3, neman meng, 02/24/2011
- <Possible follow-up(s)>
- [cgal-discuss] The problem when I compile the demo mesh_3, neman meng, 02/24/2011
