- To:
- Subject: Re: [cgal-discuss] The problem when I compile the demo mesh_3
- Date: Thu, 24 Feb 2011 12:13:22 +0100
Le jeudi 24 février 2011 12:08:36, neman a écrit :
> I have installed the CGAL 3.7 on Windows 7 for Visual studio 2008, and have
> compile the CGAL library sucessfully.
> But when I try to complie the demo of mesh_3, I get the error information
> as below:
> 1>Generating Scene_moc.cpp
> 1>moc: Cannot open options file specified with @
> 1>Usage: moc [options] <header-file>
Probably a bad mix of Qt versions. Can you try to compile a simpler Qt4 demo,
such as the ones in demo/Triangulation_2/ ? You probably will have problems
too.
Laurent Rineau, PhD
- [cgal-discuss] The problem when I compile the demo mesh_3, neman, 02/24/2011
- Re: [cgal-discuss] The problem when I compile the demo mesh_3, Laurent Rineau (GeometryFactory), 02/24/2011
- Re: [cgal-discuss] The problem when I compile the demo mesh_3, neman meng, 02/24/2011
- <Possible follow-up(s)>
- [cgal-discuss] The problem when I compile the demo mesh_3, neman meng, 02/24/2011
