cgal-discuss - Re: [cgal-discuss] dynamic convex hulls
  • To:
  • Subject: Re: [cgal-discuss] dynamic convex hulls
  • Date: Mon, 28 Feb 2011 11:47:11 +0100
Vissarion Fisikopoulos wrote:
hello all,
I would like to maintain a dynamic convex hull in CGAL (in fact I only need insertions). As I read in the manual the implementation in "CGAL::Convex_hull_d" is not very efficient so I use the alternative "CGAL::Delaunay_triangulation_3". In this way, the vertices of the convex hull will be the vertices incident to the infinite vertex, but also some degenerate vertices laying on some faces of the convex hull.
Is there any other built-in data structure to dynamically maintain only the vertices of the convex hull?
Hi Vissarion,
No, you should definitely use Delaunay_triangulation_3.
If you need to export the convex hull as a Polyhedron see this thread:
https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2010-12/msg00120.html
S.
Thanks a lot,
