- To:
- Subject: Re: [cgal-discuss] Release vs Debug - why doesn't release work?
- Date: Mon, 28 Feb 2011 11:53:44 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject:references :in-reply-to:content-type:content-transfer-encoding; b=xPJM3GjfJvI0Sugf9h8i4L9yBbPIByku1NZC6xR+XriNEEORDJmr0Ig5Ba8Ao2oSv3 NxrbGEBIIDtIzIGLiId6D342xqUe7CbMdIRtMyy90UrxwNMe99ei2KkUwzpjcHfGkC59 zFs5LixAbC8gOMZ+VIVs0i0s6xX5OnotUMyoo=
Hello,
Thank you for your answer. I'm using CGAL-3.4 and as you have just written, I shouldn't expect support with this version;) Happily, I ended up with the same code translated into WinApi. So don't need this one anymore.
By the way, I'm using VS 2008, Windows 7. I had boost, qt etc. installed.
Regards,
annie
W dniu 2011-02-28 08:21, Sebastien Loriot (GeometryFactory) pisze:
annie wrote:
Hello,What are you using? do you have a minimal example showing the problem?what is you platform,compiler...?
I can't make my project working in Release mode, while everything is ok in
Debug.
S.
It may have sth to do with gmp I guess, but I have all necessery files I
guess. Please, could somebody help me? Sadly, it's urgent... :(
Regards,
annie
- [cgal-discuss] Release vs Debug - why doesn't release work?, annie, 02/26/2011
- Re: [cgal-discuss] Release vs Debug - why doesn't release work?, aneta, 02/26/2011
- Re: [cgal-discuss] Release vs Debug - why doesn't release work?, Sebastien Loriot (GeometryFactory), 02/28/2011
- Re: [cgal-discuss] Release vs Debug - why doesn't release work?, aneta, 02/28/2011
