- To:
- Subject: Re: [cgal-discuss] Memory leaks in CGAL
- Date: Tue, 01 Mar 2011 10:54:04 +0100
Hello stzpz,
There indeed was a bug in the version of CORE distributed with CGAL
that lead to a memory leak. Please found attached the patched file that
need to be replaced.
Thanks for the report.
Best,
S.
stzpz wrote:
I am using Bezier Arrangement in CGAL, and found that there exist some memory
leak problems when I inserting bezier curves into the arrangement using
insert(). Here is the code and the data.
===================== CODE BEGIN ======================
#include <CGAL/basic.h>
#include <CGAL/Cartesian.h>
#include <CGAL/CORE_algebraic_number_traits.h>
#include <CGAL/Arr_Bezier_curve_traits_2.h>
#include <CGAL/Arrangement_2.h>
#include <list>
using namespace std;
typedef CGAL::CORE_algebraic_number_traits Nt_traits;
typedef Nt_traits::Rational NT;
typedef Nt_traits::Rational Rational;
typedef Nt_traits::Algebraic Algebraic;
typedef CGAL::Cartesian<Rational> Rat_kernel;
typedef CGAL::Cartesian<Algebraic> Alg_kernel;
typedef Rat_kernel::Point_2 Rat_point_2;
typedef CGAL::Arr_Bezier_curve_traits_2<Rat_kernel, Alg_kernel, Nt_traits>
Traits_2;
typedef Traits_2::Curve_2 Bezier_curve_2;
typedef CGAL::Arrangement_2<Traits_2> Arrangement_2;
void insertCurves(const char *filename, Arrangement_2 *arr)
std::ifstream in_file (filename);
int n_curves;
list<Bezier_curve_2> curves;
int k;
Bezier_curve_2 B;
in_file >> n_curves;
for (k = 0; k < n_curves; k++) {
in_file >> B;
curves.push_back(B);
// Memory leaks here
insert (*arr, curves.begin(), curves.end());
int main (int argc, char *argv[])
const char *filename = (argc > 1) ? argv[1] : "test_data.txt";
int k = 0;
while(true)
Arrangement_2 arr;
insertCurves(filename, &arr);
printf("%d done.\n", k++);
return 0;
==================== CODE END ========================
==================== test_data.txt BEGIN ======================
3
4 -147 -99 102 -99 102 -99 102 -99 4 -116 -145 -56 41 -56 41 -56 41 4 -148 20 121 -159 121 -159 121 -159 ==================== test_data.txt END ========================
When I running this program, the using memory is increasing rapidly, which
can be seen from the Windows Task Manager. It seems that most of the memory
leaks was caused by the MemoryPool< T, nObjects >::allocate() in
CORE\MemoryPool.h, which is reported by Visual Leak Detector.
Does anyone know how to solve it? Or is there anyway to use other kinds of
Kernel like GMP instead of CORE?
Besides, I also found a bug that insert() will crash if the input curves are
identical, just like the test data below when using the code above:
=================== Test data BEGIN ===================
2
2 0 0 100 100
2 0 0 100 100
==================== Test data END ====================
Thanks very much!
Stzpz
* Core Library Version 1.7, August 2004
* Copyright (c) 1995-2004 Exact Computation Project
* All rights reserved.
* This file is part of CORE (http://cs.nyu.edu/exact/core/); you may
* redistribute it under the terms of the Q Public License version 1.0.
* See the file LICENSE.QPL distributed with CORE.
* Licensees holding a valid commercial license may use this file in
* accordance with the commercial license agreement provided with the
* software.
* This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
* WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
* File: Poly.tcc
* Purpose:
* Template implementations of the functions
* of the Polynomial<NT> class (found in Poly.h)
* OVERVIEW:
* Each polynomial has a nominal "degree" (this
* is an upper bound on the true degree, which
* is determined by the first non-zero coefficient).
* Coefficients are parametrized by some number type "NT".
* Coefficients are stored in the "coeff" array of
* length "degree + 1".
* IMPORTANT CONVENTION: the zero polynomial has degree -1
* while nonzero constant polynomials have degree 0.
* Bugs:
* Currently, coefficient number type NT only accept
* NT=BigInt and NT=int
* To see where NT=Expr will give trouble,
* look for NOTE_EXPR below.
* Author: Chee Yap, Sylvain Pion and Vikram Sharma
* Date: May 28, 2002
* WWW URL: http://cs.nyu.edu/exact/
* Email:
* $URL:
svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/CGAL-3.7-branch/Core/include/CGAL/CORE/poly/Poly.tcc
* $Id: Poly.tcc 36978 2007-03-10 10:37:52Z spion $
template <class NT>
int Polynomial<NT>::COEFF_PER_LINE = 4; // pretty print parameters
template <class NT>
const char* Polynomial<NT>::INDENT_SPACE =" "; // pretty print parameters
// Polynomial Constructors
template <class NT>
Polynomial<NT>::Polynomial(void) {
degree = -1; // this is the zero polynomial!
coeff = NULL;
//Creates a polynomial with nominal degree n
template <class NT>
Polynomial<NT>::Polynomial(int n) {
assert(n>= -1);
degree = n;
if (n == -1)
return; // return the zero polynomial!
if (n>=0)
coeff = new NT[n+1];
coeff[0]=1; // otherwise, return the unity polynomial
for (int i=1; i<=n; i++)
coeff[i]=0;
template <class NT>
Polynomial<NT>::Polynomial(int n, const NT * c) {
//assert("array c has n+1 elements");
degree = n;
if (n >= 0) {
for (int i = 0; i <= n; i++)
coeff[i] = c[i];
// Constructor from a vector of NT's
template <class NT>
Polynomial<NT>::Polynomial(const VecNT & vN) {
degree = vN.size()-1;
if (degree >= 0) {
coeff = new NT[degree+1];
for (int i = 0; i <= degree; i++)
coeff[i] = vN[i];
template <class NT>
Polynomial<NT>::Polynomial(const Polynomial<NT> & p):degree(-1) {
//degree must be initialized to -1 otherwise delete is called on coeff in
operator=
coeff = NULL;//WHY?
*this = p; // reduce to assignment operator=
// Constructor from a Character string of coefficients
template <class NT>
Polynomial<NT>::Polynomial(int n, const char * s[]) {
//assert("array s has n+1 elements");
degree = n;
if (n >= 0) {
coeff[i] = s[i];
//The BNF syntax is the following:-
// [poly] -> [term]| [term] '+/-' [poly] |
// '-' [term] | '-' [term] '+/-' [poly]
// [term] -> [basic term] | [basic term] [term] | [basic term]*[term]
// [basic term] -> [number] | 'x' | [basic term] '^' [number]
// | '(' [poly] ')'
//COMMENT:
// [number] is assumed to be a BigInt; in the future, we probably
// want to generalize this to BigFloat, etc.
template <class NT>
Polynomial<NT>::Polynomial(const string & s, char myX) {
string ss(s);
constructFromString(ss, myX);
template <class NT>
Polynomial<NT>::Polynomial(const char * s, char myX) {
string ss(s);
template <class NT>
void Polynomial<NT>::constructFromString(string & s, char myX) {
if(myX != 'x' || myX != 'X'){
//Replace myX with 'x'.
unsigned int loc = s.find(myX, 0);
while(loc != string::npos){
s.replace(loc,1,1,'x');
loc = s.find(myX, loc+1);
coeff = NULL;//Did this to ape the constructor from polynomial above
*this = getpoly(s);
template <class NT>
Polynomial<NT>::~Polynomial() {
if(degree >= 0)
delete[] coeff;
// METHODS USED BY STRING CONSTRUCTOR ABOVE
//Sets the input Polynomial to X^n
template <class NT>
void Polynomial<NT>::constructX(int n, Polynomial<NT>& P){
Polynomial<NT> q(n);//Nominal degree n
q.setCoeff(n,NT(1));
if (n>0) q.setCoeff(0,NT(0));
P = q;
//Returns in P the coeffecient starting from start
template <class NT>
int Polynomial<NT>::getnumber(const char* c, int start, unsigned int len,
Polynomial<NT> & P){
int j=0;
char *temp = new char[len];
while(isint(c[j+start])){
temp[j]=c[j+start];j++;
temp[j] = '\0';
NT cf = NT(temp);
Polynomial<NT> q(0);
q.setCoeff(0, cf);
P = q;
delete[] temp;
return (j-1+start);//Exactly the length of the number
template <class NT>
bool Polynomial<NT>::isint(char c){
if(c == '0' || c == '1' || c == '2' || c == '3' || c == '4' ||
c == '5' || c == '6' || c == '7' || c == '8' || c == '9')
return true;
else
return false;
//Returns as integer the number starting from start in c
template <class NT>
int Polynomial<NT>::getint(const char* c, int start, unsigned int len,
int & n){
int j=0;
temp[j] = '\n';
n = atoi(temp);
delete[] temp;
//Given a string starting with an open parentheses returns the place
// which marks the end of the corresponding closing parentheses.
//Strings of the form (A).
template <class NT>
int Polynomial<NT>::matchparen(const char* cstr, int start){
int count = 0;
int j=start;
do{
if(cstr[j] == '('){
count++;
if(cstr[j] == ')'){
count--;
j++;
}while(count != 0 );//j is one more than the matching ')'
return j-1;
template <class NT>
int Polynomial<NT>::getbasicterm(string & s, Polynomial<NT> & P){
const char * cstr = s.c_str();
unsigned int len = s.length();
int i=0;
//Polynomial<NT> * temp = new Polynomial<NT>();
if(isint(cstr[i])){
i = getnumber(cstr, i, len, P);
}else if(cstr[i] == 'x'||cstr[i] == 'X'){
constructX(1, P);
}else if(cstr[i] =='('){
int oldi = i;
i = matchparen(cstr, i);
string t = s.substr(oldi+1, i -oldi -1);
P = getpoly(t);
}else{
std::cout <<"ERROR IN PARSING BASIC TERM" << std::endl;
//i+1 points to the beginning of next syntactic object in the string.
if(cstr[i+1] == '^'){
int n;
i = getint(cstr, i+2, len, n);
P.power(n);
return i;
template <class NT>
int Polynomial<NT>::getterm(string & s, Polynomial<NT> & P){
if(len == 0){// Zero Polynomial
P=Polynomial<NT>();
return 0;
unsigned int ind, oind;
const char* cstr =s.c_str();
string t;
//P will be used to accumulate the product of basic terms.
ind = getbasicterm(s, P);
while(ind != len-1 && cstr[ind + 1]!='+' && cstr[ind + 1]!='-' ){
//Recursively get the basic terms till we reach the end or see
// a '+' or '-' sign.
if(cstr[ind + 1] == '*'){
t = s.substr(ind + 2, len - ind -2);
oind = ind + 2;
}else{
t = s.substr(ind + 1, len -ind -1);
oind = ind + 1;
Polynomial<NT> R;
ind = oind + getbasicterm(t, R);//Because the second term is the offset in
//t
P *= R;
return ind;
template <class NT>
Polynomial<NT> Polynomial<NT>::getpoly(string & s){
//Remove white spaces from the string
unsigned int cnt=s.find(' ',0);
while(cnt != string::npos){
s.erase(cnt, 1);
cnt = s.find(' ', cnt);
if(len <= 0){//Zero Polynomial
return Polynomial<NT>();
//To handle the case when there is one '=' sign
//Suppose s is of the form s1 = s2. Then we assign s to
//s1 + (-1)(s2) and reset len
unsigned int loc;
if((loc=s.find('=',0)) != string::npos){
s.replace(loc,1,1,'+');
string s3 = "(-1)(";
s.insert(loc+1, s3);
len = s.length();
s.insert(len, 1, ')');
len = s.length();
const char *cstr = s.c_str();
string t;
Polynomial<NT> P;
// P will be the polynomial in which we accumulate the
//sum and difference of the different terms.
unsigned int ind;
if(cstr[0] == '-'){
t = s.substr(1, len);
ind = getterm(t,P) + 1;
P.negate();
}else{
ind = getterm(s, P);
unsigned int oind =0;//the string between oind and ind is a term
while(ind != len -1){
Polynomial<NT> R;
t = s.substr(ind + 2, len -ind -2);
oind = ind;
ind = oind + 2 + getterm(t, R);
if(cstr[oind + 1] == '+')
P += R;
else if(cstr[oind + 1] == '-')
P -= R;
else
std::cout << "ERROR IN PARSING POLY! " << std::endl;
return (P);
// METHODS
// assignment:
template <class NT>
Polynomial<NT> & Polynomial<NT>::operator=(const Polynomial<NT>& p) {
if (this == &p)
return *this; // self-assignment
if (degree >=0) delete[] coeff;
degree = p.getDegree();
if (degree < 0) return *this;
coeff = new NT[degree +1];
coeff[i] = p.coeff[i];
return *this;
// getTrueDegree
template <class NT>
int Polynomial<NT>::getTrueDegree() const {
for (int i=degree; i>=0; i--) {
if (sign(coeff[i]) != 0)
return i;
return -1; // Zero polynomial
//get i'th Coeff. We check whether i is not greater than the
// true degree and if not then return coeff[i] o/w 0
template <class NT>
NT Polynomial<NT>::getCoeffi(int i) const {
int deg = getTrueDegree();
if(i > deg)
return NT(0);
return coeff[i];
// polynomial arithmetic
// Expands the nominal degree to n;
// Returns n if nominal degree is changed to n
// Else returns -2
template <class NT>
int Polynomial<NT>::expand(int n) {
if ((n <= degree)||(n < 0))
return -2;
int i;
NT * c = coeff;
for (i = 0; i<= degree; i++)
coeff[i] = c[i];
for (i = degree+1; i<=n; i++)
coeff[i] = 0;
delete[] c;
degree = n;
return n;
// contract() gets rid of leading zero coefficients
// and returns the new (true) degree;
// It returns -2 if this is a no-op
template <class NT>
int Polynomial<NT>::contract() {
int d = getTrueDegree();
if (d == degree)
return (-2); // nothing to do
else
degree = d;
NT * c = coeff;
if (degree !=-1){
coeff = new NT[d+1];
for (int i = 0; i<= d; i++)
coeff[i] = c[i];
delete[] c;
return d;
template <class NT>
Polynomial<NT> & Polynomial<NT>::operator+=(const Polynomial<NT>& p) { // +=
int d = p.getDegree();
if (d > degree)
expand(d);
for (int i = 0; i<=d; i++)
coeff[i] += p.coeff[i];
return *this;
template <class NT>
Polynomial<NT> & Polynomial<NT>::operator-=(const Polynomial<NT>& p) { // -=
if (d > degree)
expand(d);
coeff[i] -= p.coeff[i];
return *this;
// SELF-MULTIPLICATION
// This is quadratic time multiplication!
template <class NT>
Polynomial<NT> & Polynomial<NT>::operator*=(const Polynomial<NT>& p) { // *=
if (degree==-1) return *this;
if (p.getDegree()==-1){
degree=-1;
delete[] coeff;
return *this;
int d = degree + p.getDegree();
NT * c = new NT[d+1];
c[i] = 0;
for (int i = 0; i<=p.getDegree(); i++)
for (int j = 0; j<=degree; j++) {
c[i+j] += p.coeff[i] * coeff[j];
degree = d;
delete[] coeff;
coeff = c;
return *this;
// Multiply by a scalar
template <class NT>
Polynomial<NT> & Polynomial<NT>::mulScalar( const NT & c) {
for (int i = 0; i<=degree ; i++)
coeff[i] *= c;
return *this;
// mulXpower: Multiply by X^i (COULD be a divide if i<0)
template <class NT>
Polynomial<NT> & Polynomial<NT>::mulXpower(int s) {
// if s >= 0, then this is equivalent to
// multiplying by X^s; if s < 0, to dividing by X^s
if (s==0)
return *this;
int d = s+getTrueDegree();
if (d < 0) {
degree = -1;
delete[] coeff;
coeff = NULL;
return *this;
if (s>0)
for (int j=0; j <= d; j++) {
if (j <= degree)
c[d-j] = coeff[d-s-j];
else
c[d-j] = 0;
if (s<0) {
c[d-j] = coeff[d-s-j]; // since s<0, (d-s-j) > (d-j) !!
delete[] coeff;
coeff = c;
degree = d;
return *this;
}//mulXpower
// REDUCE STEP (helper for PSEUDO-REMAINDER function)
// Let THIS=(*this) be the current polynomial, and P be the input
// argument for reduceStep. Let R be returned polynomial.
// R has the special form as a binomial,
// R = C + X*M
// where C is a constant and M a monomial (= coeff * some power of X).
// Moreover, THIS is transformed to a new polynomial, THAT, which
// is given by
// (C * THIS) = M * P + THAT
// MOREOVER: deg(THAT) < deg(THIS) unless deg(P)>deg(Q).
// Basically, C is a power of the leading coefficient of P.
// REMARK: R is NOT defined as C+M, because in case M is
// a constant, then we cannot separate C from M.
// Furthermore, R.mulScalar(-1) gives us M.
template <class NT>
Polynomial<NT> Polynomial<NT>::reduceStep (
// Chee: Omit the next 2 contractions as unnecessary
// since reduceStep() is only called by pseudoRemainder().
// Also, reduceStep() already does a contraction before returning.
// p.contract();
// contract(); // first contract both polynomials
Polynomial<NT> q(p); // q is initially a copy of p
// but is eventually M*P
int pDeg = q.degree;
int myDeg = degree;
if (pDeg == -1)
return *(new Polynomial()); // Zero Polynomial
// NOTE: pDeg=-1 (i.e., p=0) is really an error condition!
if (myDeg < pDeg)
return *(new Polynomial(0)); // Unity Polynomial
// i.e., C=1, M=0.
// Now (myDeg >= pDeg). Start to form the Return Polynomial R=C+X*M
Polynomial<NT> R(myDeg - pDeg + 1); // deg(M)= myDeg - pDeg
q.mulXpower(myDeg - pDeg); // q is going to become M*P
NT myLC = coeff[myDeg]; // LC means "leading coefficient"
NT qLC = q.coeff[myDeg]; // p also has degree "myDeg" (qLC non-zero)
NT LC;
// NT must support
// isDivisible(x,y), gcd(x,y), div_exact(x,y) in the following:
if (isDivisible(myLC, qLC)) { // myLC is divisible by qLC
LC = div_exact(myLC, qLC);
R.setCoeff(0, 1); // C = 1,
R.setCoeff(R.degree, LC); // M = LC * X^(myDeg-pDeg)
q.mulScalar(LC); // q = M*P.
else if (isDivisible(qLC, myLC)) { // qLC is divisible by myLC
LC = div_exact(qLC, myLC); //
if ((LC != 1) && (LC != -1)) { // IMPORTANT: unlike the previous
// case, we need an additional condition
// that LC != -1. THis is because
// if (LC = -1), then we have qLC and
// myLC are mutually divisible, and
// we would be updating R twice!
R.setCoeff(0, LC); // C = LC,
R.setCoeff(R.degree, 1); // M = X^(myDeg-pDeg)(THIS WAS NOT DONE)
mulScalar(LC); // THIS => THIS * LC
} else { // myLC and qLC are not mutually divisible
NT g = gcd(qLC, myLC); // This ASSUMES gcd is defined in NT !!
//NT g = 1; // In case no gcd is available
if (g == 1) {
R.setCoeff(0, qLC); // C = qLC
R.setCoeff(R.degree, myLC); // M = (myLC) * X^{myDeg-pDeg}
mulScalar(qLC); // forming C * THIS
q.mulScalar(myLC); // forming M * P
} else {
NT qLC1= div_exact(qLC,g);
NT myLC1= div_exact(myLC,g);
R.setCoeff(0, qLC1); // C = qLC/g
R.setCoeff(R.degree, myLC1); // M = (myLC/g) * X^{myDeg-pDeg}
mulScalar(qLC1); // forming C * THIS
q.mulScalar(myLC1); // forming M * P
(*this) -= q; // THAT = (C * THIS) - (M * P)
contract();
return R; // Returns R = C + X*M
}// reduceStep
// For internal use only:
// Checks that c*A = B*m + AA
// where A=(*oldthis) and AA=(*newthis)
template <class NT>
Polynomial<NT> Polynomial<NT>::testReduceStep(const Polynomial<NT>& A,
const Polynomial<NT>& B) {
std::cout << "+++++++++++++++++++++TEST REDUCE STEP+++++++++++++++++++++\n";
Polynomial<NT> cA(A);
Polynomial<NT> AA(A);
Polynomial<NT> quo;
quo = AA.reduceStep(B); // quo = c + X*m (m is monomial, c
const)
// where c*A = B*m + (*newthis)
std::cout << "A = " << A << std::endl;
std::cout << "B = " << B << std::endl;
cA.mulScalar(quo.coeff[0]); // A -> c*A
Polynomial<NT> m(quo);
m.mulXpower(-1); // m's value is now m
std::cout << "c = " << quo.coeff[0] << std::endl;
std::cout << "c + xm = " << quo << std::endl;
std::cout << "c*A = " << cA << std::endl;
std::cout << "AA = " << AA << std::endl;
std::cout << "B*m = " << B*m << std::endl;
std::cout << "B*m + AA = " << B*m + AA << std::endl;
if (cA == (B*m + AA))
std::cout << "CORRECT inside testReduceStep" << std::endl;
else
std::cout << "ERROR inside testReduceStep" << std::endl;
std::cout << "+++++++++++++++++END TEST REDUCE STEP+++++++++++++++++++++\n";
return quo;
// PSEUDO-REMAINDER and PSEUDO-QUOTIENT:
// Let A = (*this) and B be the argument polynomial.
// Let Quo be the returned polynomial,
// and let the final value of (*this) be Rem.
// Also, C is the constant that we maintain.
// We are computing A divided by B. The relation we guarantee is
// (C * A) = (Quo * B) + Rem
// where deg(Rem) < deg(B). So Rem is the Pseudo-Remainder
// and Quo is the Pseudo-Quotient.
// Moreover, C is uniquely determined (we won't spell it out)
// except to note that
// C divides D = (LC)^{deg(A)-deg(B)+1}
// where LC is the leading coefficient of B.
// NOTE: 1. Normally, Pseudo-Remainder is defined so that C = D
// So be careful when using our algorithm.
// 2. We provide a version of pseudoRemainder which does not
// require C as argument. [For efficiency, we should provide this
// version directly, instead of calling the other version!]
template <class NT>
Polynomial<NT> Polynomial<NT>::pseudoRemainder (
NT temp; // dummy argument to be discarded
return pseudoRemainder(B, temp);
}//pseudoRemainder
template <class NT>
const Polynomial<NT>& B, NT & C) {
contract(); // Let A = (*this). Contract A.
Polynomial<NT> tmpB(B);
tmpB.contract(); // local copy of B
C = NT(1); // Initialized to C=1.
if (B.degree == -1) {
std::cout << "ERROR in Polynomial<NT>::pseudoRemainder :\n" <<
" -- divide by zero polynomial" << std::endl;
return Polynomial(0); // Unit Polynomial (arbitrary!)
if (B.degree > degree) {
return Polynomial(); // Zero Polynomial
// CHECK: 1*THIS = 0*B + THAT, deg(THAT) < deg(B)
Polynomial<NT> Quo; // accumulate the return polynomial, Quo
Polynomial<NT> tmpQuo;
while (degree >= B.degree) { // INVARIANT: C*A = B*Quo + (*this)
tmpQuo = reduceStep(tmpB); // Let (*this) be (*oldthis), which
// is transformed into (*newthis). Then,
// c*(*oldthis) = B*m + (*newthis)
// where tmpQuo = c + X*m
// Hence, C*A = B*Quo + (*oldthis) -- the old invariant
// c*C*A = c*B*Quo + c*(*oldthis)
// = c*B*Quo + (B*m + (*newthis))
// = B*(c*Quo + m) + (*newthis)
// i.e, to update invariant, we do C->c*C, Quo --> c*Quo + m.
C *= tmpQuo.coeff[0]; // C = c*C
Quo.mulScalar(tmpQuo.coeff[0]); // Quo -> c*Quo
tmpQuo.mulXpower(-1); // tmpQuo is now equal to m
Quo += tmpQuo; // Quo -> Quo + m
return Quo; // Quo is the pseudo-quotient
}//pseudoRemainder
// Returns the negative of the pseudo-remainder
// (self-modification)
template <class NT>
Polynomial<NT> & Polynomial<NT>::negPseudoRemainder (
if (temp < 0) return (*this);
return negate();
template <class NT>
Polynomial<NT> & Polynomial<NT>::operator-() { // unary minus
for (int i=0; i<=degree; i++)
coeff[i] *= -1;
return *this;
template <class NT>
Polynomial<NT> & Polynomial<NT>::power(unsigned int n) { // self-power
if (n == 0) {
degree = 0;
delete [] coeff;
coeff = new NT[1];
coeff[0] = 1;
} else {
Polynomial<NT> p = *this;
for (unsigned int i=1; i<n; i++)
*this *= p; // Would a binary power algorithm be better?
return *this;
// evaluation of BigFloat value
// NOTE: we think of the polynomial as an analytic function in this setting
// If the coefficients are more general than BigFloats,
// then we may get inexact outputs, EVEN if the input value f is exact.
// This is because we would have to convert these coefficients into
// BigFloats, and this conversion precision is controlled by the
// global variables defRelPrec and defAbsPrec.
template <class NT>
BigFloat Polynomial<NT>::eval(const BigFloat& f) const { // evaluation
if (degree == -1)
return BigFloat(0);
if (degree == 0)
return BigFloat(coeff[0]);
BigFloat val(0);
val *= f;
val += BigFloat(coeff[i]);
return val;
}//eval
/// Evaluation Function (generic version, always returns the exact value)
/// This evaluation function is easy to use, but may not be efficient
/// when you have BigRat or Expr values.
/// User must be aware that the return type of eval is Max of Types NT and T.
/// E.g., If NT is BigRat, and T is Expr then Max(NT,T)=Expr.
/// REMARK: If NT is BigFloat, it is assumed that the BigFloat is error-free.
template <class NT>
template <class T>
MAX_TYPE(NT, T) Polynomial<NT>::eval(const T& f) const { // evaluation
typedef MAX_TYPE(NT, T) ResultT;
if (degree == -1)
return ResultT(0);
if (degree == 0)
return ResultT(coeff[0]);
ResultT val(0);
val *= ResultT(f);
val += ResultT(coeff[i]);
return val;
}//eval
/// Approximate Evaluation of Polynomials
/// the coefficients of the polynomial are approximated to some
/// specified composite precision (r,a).
/// @param f evaluation point
/// @param r relative precision to which the coefficients are evaluated
/// @param a absolute precision to which the coefficients are evaluated
/// @return a BigFloat with error containing value of the polynomial.
/// If zero is in this BigFloat interval, then we don't know the sign.
// ASSERT: NT = BigRat or Expr
template <class NT>
BigFloat Polynomial<NT>::evalApprox(const BigFloat& f,
const extLong& r, const extLong& a) const { // evaluation
if (degree == -1)
return BigFloat(0);
if (degree == 0)
return BigFloat(coeff[0], r, a);
BigFloat val(0), c;
c = BigFloat(coeff[i], r, a);
val *= f;
val += c;
return val;
}//evalApprox
// This BigInt version of evalApprox should never be called...
template <>
CORE_INLINE
BigFloat Polynomial<BigInt>::evalApprox(const BigFloat& /*f*/,
const extLong& /*r*/, const extLong& /*a*/) const { // evaluation
assert(0);
return BigFloat(0);
* Evaluation at a BigFloat value
* using "filter" only when NT is BigRat or Expr.
* Using filter means we approximate the polynomials
* coefficients using BigFloats. If this does not give us
* the correct sign, we will resort to an "exact" evaluation
* using Expr.
* If NT <= BigFloat, we just call eval().
We use the following heuristic estimates of precision for coefficients:
r = 1 + lg(|P|_\infty) + lg(d+1) if f <= 1
r = 1 + lg(|P|_\infty) + lg(d+1) + d*lg|f| if f > 1
if the filter fails, then we use Expr to do evaluation.
This function is mainly called by Newton iteration (which
has some estimate for oldMSB from previous iteration).
@param p polynomial to be evaluated
@param val the evaluation point
@param oldMSB an rough estimate of the lg|p(val)|
@return bigFloat interval contain p(val), with the correct sign
template <class NT>
BigFloat Polynomial<NT>::evalExactSign(const BigFloat& val,
const extLong& oldMSB) const {
assert(val.isExact());
if (getTrueDegree() == -1)
return BigFloat(0);
extLong r;
r = 1 + BigFloat(height()).uMSB() + clLg(long(getTrueDegree()+1));
if (val > 1)
r += getTrueDegree() * val.uMSB();
r += core_max(extLong(0), -oldMSB);
if (hasExactDivision<NT>::check()) { // currently, only to detect NT=Expr
and NT=BigRat
BigFloat rVal = evalApprox(val, r);
if (rVal.isZeroIn()) {
Expr eVal = eval(Expr(val)); // eval gives exact value
eVal.approx(54,CORE_INFTY); // if value is 0, we get exact 0
return eVal.BigFloatValue();
} else
return rVal;
} else
return BigFloat(eval(val));
//return 0; // unreachable
}//evalExactSign
// Bounds
// Cauchy Upper Bound on Roots
// -- ASSERTION: NT is an integer type
template < class NT >
BigFloat Polynomial<NT>::CauchyUpperBound() const {
if (zeroP(*this))
return BigFloat(0);
NT mx = 0;
for (int i = 0; i < deg; ++i) {
mx = core_max(mx, abs(coeff[i]));
Expr e = mx;
e /= Expr(abs(coeff[deg]));
e.approx(CORE_INFTY, 2);
// get an absolute approximate value with error < 1/4
return (e.BigFloatValue().makeExact() + 2);
// An iterative version of computing Cauchy Bound from Erich Kaltofen.
// See the writeup under collab/sep/.
BigInt Polynomial<NT>::CauchyBound() const {
BigInt B(1);
BigFloat lhs(0), rhs(1);
while (true) {
/* compute \sum_{i=0}{deg-1}{|a_i|B^i} */
lhs = 0;
for (int i=deg-1; i>=0; i--) {
lhs *= B;
lhs += abs(coeff[i]);
lhs /= abs(coeff[deg]);
lhs.makeFloorExact();
/* compute B^{deg} */
if (rhs <= lhs) {
B <<= 1;
rhs *= (BigInt(1)<<deg);
} else
break;
return B;
//Another iterative bound which is at least as good as the above bound
//by Erich Kaltofen.
BigInt Polynomial<NT>::UpperBound() const {
BigInt B(1);
BigFloat lhsPos(0), lhsNeg(0), rhs(1);
while (true) {
lhsPos = lhsNeg = 0;
if (coeff[i]>0) {
lhsPos = lhsPos * B + coeff[i];
lhsNeg = lhsNeg * B;
} else {
lhsNeg = lhsNeg * B - coeff[i];
lhsPos = lhsPos * B;
lhsNeg /= abs(coeff[deg]);
lhsPos /= abs(coeff[deg]);
lhsPos.makeCeilExact();
lhsNeg.makeCeilExact();
if (rhs <= max(lhsPos,lhsNeg)) {
B <<= 1;
} else
break;
return B;
// Cauchy Lower Bound on Roots
BigFloat Polynomial<NT>::CauchyLowerBound() const {
if ((zeroP(*this)) || coeff[0] == 0)
return BigFloat(0);
NT mx = 0;
for (int i = 1; i <= deg; ++i) {
Expr e = Expr(abs(coeff[0]))/ Expr(abs(coeff[0]) + mx);
e.approx(2, CORE_INFTY);
// get an relative approximate value with error < 1/4
return (e.BigFloatValue().makeExact().div2());
// Separation bound for polynomials that may have multiple roots.
// We use the Rump-Schwartz bound.
// ASSERT(the return value is an exact BigFloat and a Lower Bound)
BigFloat Polynomial<NT>::sepBound() const {
BigInt d;
BigFloat e;
CORE::power(d, BigInt(deg), ((deg)+4)/2);
e = CORE::power(height()+1, deg);
e.makeCeilExact(); // see NOTE below
return (1/(e*2*d)).makeFloorExact();
// BUG fix: ``return 1/e*2*d'' was wrong
// NOTE: the relative error in this division (1/(e*2*d))
// is defBFdivRelPrec (a global variable), but
// since this is always positive, we are OK.
// But to ensure that defBFdivRelPrec is used,
// we must make sure that e and d are exact.
// Finally, using "makeFloorExact()" is OK because
// the mantissa minus error (i.e., m-err) will remain positive
// as long as the relative error (defBFdivRelPrec) is >1.
/// height function
BigFloat Polynomial<NT>::height() const {
if (zeroP(*this))
return BigFloat(0);
NT ht = 0;
for (int i = 0; i< deg; i++)
if (ht < abs(coeff[i]))
ht = abs(coeff[i]);
return BigFloat(ht);
/// length function
BigFloat Polynomial<NT>::length() const {
if (zeroP(*this))
return BigFloat(0);
NT length = 0;
length += abs(coeff[i]*coeff[i]);
return sqrt(BigFloat(length));
// differentiation
template <class NT>
Polynomial<NT> & Polynomial<NT>::differentiate() { //
self-differentiation
if (degree >= 0) {
NT * c = new NT[degree];
for (int i=1; i<=degree; i++)
c[i-1] = coeff[i] * i;
degree--;
delete[] coeff;
coeff = c;
return *this;
}// differentiation
// multi-differentiate
template <class NT>
Polynomial<NT> & Polynomial<NT>::differentiate(int n) {
assert(n >= 0);
this->differentiate();
return *this;
} // multi-differentiate
// GCD, content, primitive and square-free parts
/// divisibility predicate for polynomials
// isDivisible(P,Q) returns true iff Q divides P
// To FIX: the predicate name is consistent with Expr.h but not with BigInt.h
template <class NT>
bool isDivisible(Polynomial<NT> p, Polynomial<NT> q) {
if(zeroP(p))
return true;
if(zeroP(q))
return false; // We should really return error!
if(p.getTrueDegree() < q.getTrueDegree())
return false;
p.pseudoRemainder(q);
if(zeroP(p))
return true;
else
return false;
}//isDivisible
//Content of a polynomial P
// -- content(P) is just the gcd of all the coefficients
// -- REMARK: by definition, content(P) is non-negative
// We rely on the fact that NT::gcd always
// return a non-negative value!!!
template <class NT>
NT content(const Polynomial<NT>& p) {
if(zeroP(p))
return 0;
int d = p.getTrueDegree();
if(d == 0){
if(p.coeff[0] > 0)
return p.coeff[0];
else
return -p.coeff[0];
NT content = p.coeff[d];
for (int i=d-1; i>=0; i--) {
content = gcd(content, p.coeff[i]);
if(content == 1) break; // remark: gcd is non-negative, by definition
//if (p.coeff[0] < 0) return -content;(BUG!)
return content;
}//content
// Primitive Part: (*this) is transformed to primPart and returned
// -- primPart(P) is just P/content(P)
// -- Should we return content(P) instead? [SHOULD IMPLEMENT THIS]
// IMPORTANT: we require that content(P)>0, hence
// the coefficients of primPart(P) does
// not change sign; this is vital for use in Sturm sequences
template <class NT>
Polynomial<NT> & Polynomial<NT>::primPart() {
// ASSERT: GCD must be provided by NT
assert (d >= 0);
if (d == 0) {
if (coeff[0] > 0) coeff[0] = 1;
else coeff[0] = -1;
return *this;
NT g = content(*this);
if (g == 1 && coeff[d] > 0)
return (*this);
for (int i=0; i<=d; i++) {
coeff[i] = div_exact(coeff[i], g);
return *this;
}// primPart
//GCD of two polynomials.
// --Assumes that the coeffecient ring NT has a gcd function
// --Returns the gcd with a positive leading coefficient (*)
// otherwise division by gcd causes a change of sign affecting
// Sturm sequences.
// --To Check: would a non-recursive version be much better?
template <class NT>
Polynomial<NT> gcd(const Polynomial<NT>& p, const Polynomial<NT>& q) {
// If the first polynomial has a smaller degree then the second,
// then change the order of calling
return gcd(q,p);
// If any polynomial is zero then the gcd is the other polynomial
if(zeroP(q)){
if(zeroP(p))
return p;
else{
if(p.getCoeffi(p.getTrueDegree()) < 0){
return Polynomial<NT>(p).negate();
}else
return p; // If q<>0, then we know p<>0
Polynomial<NT> temp0(p);
Polynomial<NT> temp1(q);
// We want to compute:
// gcd(p,q) = gcd(content(p),content(q)) * gcd(primPart(p), primPart(q))
NT cont0 = content(p); // why is this temporary needed?
NT cont1 = content(q);
NT cont = gcd(cont0,cont1);
temp0.primPart();
temp1.primPart();
temp0.pseudoRemainder(temp1);
return (gcd(temp1, temp0).mulScalar(cont));
}//gcd
// sqFreePart()
// -- this is a self-modifying operator!
// -- Let P =(*this) and Q=square-free part of P.
// -- (*this) is transformed into P, and gcd(P,P') is returned
// NOTE: The square-free part of P is defined to be P/gcd(P, P')
template <class NT>
Polynomial<NT> Polynomial<NT>::sqFreePart() {
if(d <= 1) // linear polynomials and constants are square-free
return *this;
Polynomial<NT> temp(*this);
Polynomial<NT> R = gcd(*this, temp.differentiate()); // R = gcd(P, P')
// If P and P' have a constant gcd, then P is squarefree
if(R.getTrueDegree() == 0)
return (Polynomial<NT>(0)); // returns the unit polynomial as gcd
(*this)=pseudoRemainder(R); // (*this) is transformed to P/R, the sqfree
part
//Note: This is up to multiplication by units
return (R); // return the gcd
}//sqFreePart()
// Useful member functions
// reverse:
// reverses the list of coefficients
template <class NT>
void Polynomial<NT>::reverse() {
NT tmp;
for (int i=0; i<= degree/2; i++) {
tmp = coeff[i];
coeff[i] = coeff[degree-i];
coeff[degree-i] = tmp;
}//reverse
// negate:
// multiplies the polynomial by -1
// Chee: 4/29/04 -- added negate() to support negPseudoRemainder(B)
template <class NT>
Polynomial<NT> & Polynomial<NT>::negate() {
for (int i=0; i<= degree; i++)
coeff[i] *= -1; // every NT must be able to construct from -1
return *this;
}//negate
// makeTailCoeffNonzero
// Divide (*this) by X^k, so that the tail coeff becomes non-zero.
// The value k is returned. In case (*this) is 0, return k=-1.
// Otherwise, if (*this) is unchanged, return k=0.
template <class NT>
int Polynomial<NT>::makeTailCoeffNonzero() {
int k=-1;
for (int i=0; i <= degree; i++) {
if (coeff[i] != 0) {
k=i;
break;
if (k <= 0)
return k; // return either 0 or -1
degree -=k; // new (lowered) degree
NT * c = new NT[1+degree];
c[i] = coeff[i+k];
delete[] coeff;
coeff = c;
return k;
// filedump(string msg, ostream os, string com, string com2):
// Dumps polynomial to output stream os
// msg is any message
// NOTE: Default is com="#", which is placed at start of each
// output line.
template <class NT>
void Polynomial<NT>::filedump(std::ostream & os,
std::string msg,
std::string commentString,
std::string commentString2) const {
int d= getTrueDegree();
if (msg != "") os << commentString << msg << std::endl;
int i=0;
if (d == -1) { // if zero polynomial
os << commentString << "0";
return;
for (; i<=d; ++i) // get to the first non-zero coeff
if (coeff[i] != 0)
break;
int termsInLine = 1;
// OUTPUT the first nonzero term
os << commentString;
if (coeff[i] == 1) { // special cases when coeff[i] is
if (i>1) os << "x^" << i; // either 1 or -1
else if (i==1) os << "x" ;
else os << "1";
} else if (coeff[i] == -1) {
if (i>1) os << "-x^" << i;
else if (i==1) os << "-x" ;
else os << "-1";
} else { // non-zero coeff
os << coeff[i];
if (i>1) os << "*x^" << i;
// OUTPUT the remaining nonzero terms
for (i++ ; i<= getTrueDegree(); ++i) {
if (coeff[i] == 0)
continue;
termsInLine++;
if (termsInLine % Polynomial<NT>::COEFF_PER_LINE == 0) {
os << std::endl;
os << commentString2;
if (coeff[i] == 1) { // special when coeff[i] = 1
if (i==1) os << " + x";
else os << " + x^" << i;
} else if (coeff[i] == -1) { // special when coeff[i] = -1
if (i==1) os << " - x";
else os << " -x^" << i;
} else { // general case
if(coeff[i] > 0){
os << " + ";
os << coeff[i];
}else
os << coeff[i];
if (i==1) os << "*x";
else os << "*x^" << i;
}//filedump
// dump(message, ofstream, commentString) -- dump to file
template <class NT>
void Polynomial<NT>::dump(std::ofstream & ofs,
std::string msg,
filedump(ofs, msg, commentString, commentString2);
// dump(message) -- to std output
template <class NT>
void Polynomial<NT>::dump(std::string msg, std::string com,
std::string com2) const {
filedump(std::cout, msg, com, com2);
// Dump of Maple Code for Polynomial
template <class NT>
void Polynomial<NT>::mapleDump() const {
if (zeroP(*this)) {
std::cout << 0 << std::endl;
return;
std::cout << coeff[0];
for (int i = 1; i<= getTrueDegree(); ++i) {
std::cout << " + (" << coeff[i] << ")";
std::cout << "*x^" << i;
std::cout << std::endl;
}//mapleDump
// Useful friend functions for Polynomial<NT> class
// friend differentiation
template <class NT>
Polynomial<NT> differentiate(const Polynomial<NT> & p) { //
differentiate
return q.differentiate();
// friend multi-differentiation
template <class NT>
Polynomial<NT> differentiate(const Polynomial<NT> & p, int n)
{//multi-differentiate
assert(n >= 0);
q.differentiate();
return q;
// friend equality comparison
template <class NT>
bool operator==(const Polynomial<NT>& p, const Polynomial<NT>& q) { // ==
int d, D;
Polynomial<NT> P(p);
P.contract();
Polynomial<NT> Q(q);
Q.contract();
if (P.degree < Q.degree) {
d = P.degree;
D = Q.degree;
for (int i = d+1; i<=D; i++)
if (Q.coeff[i] != 0)
return false; // return false
} else {
D = P.degree;
d = Q.degree;
if (P.coeff[i] != 0)
for (int i = 0; i <= d; i++)
if (P.coeff[i] != Q.coeff[i])
return true; // return true
// friend non-equality comparison
template <class NT>
bool operator!=(const Polynomial<NT>& p, const Polynomial<NT>& q) { // !=
return (!(p == q));
// stream i/o
template <class NT>
std::ostream& operator<<(std::ostream& o, const Polynomial<NT>& p) {
o << "Polynomial<NT> ( deg = " << p.degree ;
if (p.degree >= 0) {
o << "," << std::endl;
o << "> coeff c0,c1,... = " << p.coeff[0];
for (int i=1; i<= p.degree; i++)
o << ", " << p.coeff[i] ;
o << ")" << std::endl;
return o;
// fragile version...
template <class NT>
std::istream& operator>>(std::istream& is, Polynomial<NT>& p) {
is >> p.degree;
// Don't you need to first do "delete[] p.coeff;" ??
p.coeff = new NT[p.degree+1];
for (int i=0; i<= p.degree; i++)
is >> p.coeff[i];
return is;
// Simple test of poly
template <class NT>
bool testPoly() {
int c[] = {1, 2, 3};
Polynomial<NT> p(2, c);
std::cout << p;
Polynomial<NT> zeroP;
std::cout << "zeroP : " << zeroP << std::endl;
Polynomial<NT> P5(5);
std::cout << "Poly 5 : " << P5 << std::endl;
return 0;
//Resultant of two polynomials.
//Since we use pseudoRemainder we have to modify the original algorithm.
//If C * P = Q * R + S, where C is a constant and S = prem(P,Q), m=deg(P),
// n=deg(Q) and l = deg(S).
//Then res(P,Q) = (-1)^(mn) b^(m-l) res(Q,S)/C^(n)
//The base case being res(P,Q) = Q^(deg(P)) if Q is a constant, zero otherwise
template <class NT>
NT res(Polynomial<NT> p, Polynomial<NT> q) {
int m, n;
m = p.getTrueDegree();
n = q.getTrueDegree();
if(m == -1 || n == -1) return 0; // this definition is not certified
if(m == 0 && n == 0) return 1; // this definition is at variance from
// Yap's book (but is OK for purposes of
// checking the vanishing of resultants
if(n > m) return (res(q, p));
NT b = q.coeff[n];//Leading coefficient of Q
NT lc = p.coeff[m], C;
p.pseudoRemainder(q, C);
if(zeroP(p) && n ==0)
return (pow(q.coeff[0], m));
int l = p.getTrueDegree();
return(pow(NT(-1), m*n)*pow(b,m-l)*res(q,p)/pow(C,n));
//i^th Principal Subresultant Coefficient (psc) of two polynomials.
template <class NT>
NT psc(int i,Polynomial<NT> p, Polynomial<NT> q) {
assert(i >= 0);
if(i == 0)
return res(p,q);
int m = p.getTrueDegree();
int n = q.getTrueDegree();
if(m < n) return psc(i, q, p);
if ( i == n) //This case occurs when i > degree of gcd
return pow(q.coeff[n], m - n);
if(n < i && i <= m)
return 0;
if(zeroP(p) && i < n)//This case occurs when i < deg(gcd)
return 0;
if(zeroP(p) && i == n)//This case occurs when i=deg(gcd) might be constant
return pow(NT(-1),(m-i)*(n-i))*pow(b,m-l)*psc(i,q,p)/pow(C, n-i);
//factorI(p,m)
// computes the polynomial q which containing all roots
// of multiplicity m of a given polynomial P
// Used to determine the nature of intersection of two algebraic curves
// The algorithm is given in Wolperts Thesis
template <class NT>
Polynomial<NT> factorI(Polynomial<NT> p, int m){
int d=p.getTrueDegree();
Polynomial<NT> *w = new Polynomial<NT>[d+1];
w[0] = p;
Polynomial<NT> temp;
for(int i = 1; i <=d ; i ++){
temp = w[i-1];
w[i] = gcd(w[i-1],temp.differentiate());
Polynomial<NT> *u = new Polynomial<NT>[d+1];
u[d] = w[d-1];
for(int i = d-1; i >=m; i--){
temp = power(u[i+1],2);
for(int j=i+2; j <=d; j++){
temp *= power(u[j],j-i+1);
u[i] = w[i-1].pseudoRemainder(temp);//i-1 since the array starts at 0
delete[] w;
return u[m];
// End of Polynomial<NT>
- Re: [cgal-discuss] Memory leaks in CGAL, Sebastien Loriot (GeometryFactory), 03/01/2011
- <Possible follow-up(s)>
- Re: [cgal-discuss] Memory leaks in CGAL, Stzpz, 03/02/2011
