- To:
- Subject: Re: [cgal-discuss] Memory leaks in CGAL
- Date: Tue, 01 Mar 2011 15:05:59 +0100
stzpz wrote:
I am using Bezier Arrangement in CGAL, and found that there exist some memoryHere is the patched file for identical Bezier curves.
leak problems when I inserting bezier curves into the arrangement using
insert(). Here is the code and the data.
===================== CODE BEGIN ======================
#include <CGAL/basic.h>
#include <CGAL/Cartesian.h>
#include <CGAL/CORE_algebraic_number_traits.h>
#include <CGAL/Arr_Bezier_curve_traits_2.h>
#include <CGAL/Arrangement_2.h>
#include <list>
using namespace std;
typedef CGAL::CORE_algebraic_number_traits Nt_traits;
typedef Nt_traits::Rational NT;
typedef Nt_traits::Rational Rational;
typedef Nt_traits::Algebraic Algebraic;
typedef CGAL::Cartesian<Rational> Rat_kernel;
typedef CGAL::Cartesian<Algebraic> Alg_kernel;
typedef Rat_kernel::Point_2 Rat_point_2;
typedef CGAL::Arr_Bezier_curve_traits_2<Rat_kernel, Alg_kernel, Nt_traits>
Traits_2;
typedef Traits_2::Curve_2 Bezier_curve_2;
typedef CGAL::Arrangement_2<Traits_2> Arrangement_2;
void insertCurves(const char *filename, Arrangement_2 *arr)
std::ifstream in_file (filename);
int n_curves;
list<Bezier_curve_2> curves;
int k;
Bezier_curve_2 B;
in_file >> n_curves;
for (k = 0; k < n_curves; k++) {
in_file >> B;
curves.push_back(B);
// Memory leaks here
insert (*arr, curves.begin(), curves.end());
int main (int argc, char *argv[])
const char *filename = (argc > 1) ? argv[1] : "test_data.txt";
int k = 0;
while(true)
Arrangement_2 arr;
insertCurves(filename, &arr);
printf("%d done.\n", k++);
return 0;
==================== CODE END ========================
==================== test_data.txt BEGIN ======================
3
4 -147 -99 102 -99 102 -99 102 -99 4 -116 -145 -56 41 -56 41 -56 41 4 -148 20 121 -159 121 -159 121 -159 ==================== test_data.txt END ========================
When I running this program, the using memory is increasing rapidly, which
can be seen from the Windows Task Manager. It seems that most of the memory
leaks was caused by the MemoryPool< T, nObjects >::allocate() in
CORE\MemoryPool.h, which is reported by Visual Leak Detector.
Does anyone know how to solve it? Or is there anyway to use other kinds of
Kernel like GMP instead of CORE?
Besides, I also found a bug that insert() will crash if the input curves are
identical, just like the test data below when using the code above:
=================== Test data BEGIN ===================
2
2 0 0 100 100
2 0 0 100 100
==================== Test data END ====================
Note that since you are using segments, it might be more efficient to
detect this before inserting segments in the arrangement.
S.
Thanks very much!
Stzpz
// Copyright (c) 2006 Tel-Aviv University (Israel). // All rights reserved. // // This file is part of CGAL (www.cgal.org); you may redistribute it under // the terms of the Q Public License version 1.0. // See the file LICENSE.QPL distributed with CGAL. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // $URL: svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/CGAL-3.7-branch/Arrangement_on_surface_2/include/CGAL/Arr_geometry_traits/Bezier_bounding_rational_traits.h $ // $Id: Bezier_bounding_rational_traits.h 56667 2010-06-09 07:37:13Z sloriot $ // // // Author(s) : Iddo Hanniel <> // Ron Wein <> #ifndef CGAL_BEZIER_BOUNDING_RATIONAL_TRAITS_H #define CGAL_BEZIER_BOUNDING_RATIONAL_TRAITS_H /*! \file * Definition of the Bezier_bounding_rational_traits<Kernel> class. */ #include <CGAL/Cartesian.h> #include <CGAL/Polygon_2_algorithms.h> #include <CGAL/Arr_geometry_traits/de_Casteljau_2.h> #include <deque> #include <list> #include <math.h> namespace CGAL { /*! \struct _Bez_point_bound * Representation of a bounding interval for a point on a Bezier curve. * Basically, we store an interval [t_min, t_max] such that the point p * equals B(t) for some point t_min <= t <= t_max. We also store a bounding * polynomial for the point (obtain by de Casteljau's algorithm). */ template <class Kernel_> struct _Bez_point_bound { /*! \enum Type * The point type. */ enum Type { RATIONAL_PT, /*!< A point with rational coordinates .*/ VERTICAL_TANGENCY_PT, /*!< A vertical tangency point .*/ INTERSECTION_PT, /*!< An intersection point .*/ UNDEFINED }; typedef Kernel_ Kernel; typedef typename Kernel::FT NT; typedef typename Kernel::Point_2 Point_2; typedef std::deque<Point_2> Control_points; Type type; /*!< The point type. */ Control_points ctrl; /*!< The control point whose convex hull contains the point. */ NT t_min; /*!< Minimal t value. */ NT t_max; /*!< Maximal t value. */ bool can_refine; /*!< Can we refine the current representation. */ /*! Default constructor. */ _Bez_point_bound() : type (UNDEFINED), ctrl(), t_min(), t_max(), can_refine (false) {} /*! Constructor with parameters. */ _Bez_point_bound (Type _type, const Control_points& _ctrl, const NT& _t_min, const NT& _t_max, bool _can_refine) : type (_type), ctrl (_ctrl), t_min (_t_min), t_max (_t_max), can_refine (_can_refine) {} }; /*! \struct _Bez_point_bbox * A bounding box for a point on a Bezier curve. */ template <class Kernel_> struct _Bez_point_bbox { typedef Kernel_ Kernel; typedef typename Kernel::FT NT; typedef _Bez_point_bbox<Kernel> Self; NT min_x; /*!< Lower bound for the x-coordinate. */ NT max_x; /*!< Upper bound for the x-coordinate. */ NT min_y; /*!< Lower bound for the y-coordinate. */ NT max_y; /*!< Upper bound for the y-coordinate. */ /*! Default constructor. */ _Bez_point_bbox() : min_x(0), max_x(0), min_y(0), max_y(0) {} /*! Constructor with parameters. */ _Bez_point_bbox (const NT& _min_x, const NT& _max_x, const NT& _min_y, const NT& _max_y) : min_x(_min_x), max_x(_max_x), min_y(_min_y), max_y(_max_y) {} /*! Add two bounding boxes, and obtain a box bounding them both. */ Self operator+ (const Self& other) const { return (Self (std::min(min_x, other.min_x), std::max(max_x, other.max_x), std::min(min_y, other.min_y), std::max(max_y, other.max_y))); } /*! Addition and assignment. */ void operator+= (const Self& other) { min_x = std::min(min_x, other.min_x); max_x = std::max(max_x, other.max_x); min_y = std::min(min_y, other.min_y); max_y = std::max(max_y, other.max_y); return; } /*! Check whether the two bounding boxed overlap. */ bool overlaps (const Self& other) const { if ((CGAL::compare (max_x, other.min_x) == CGAL::SMALLER) || (CGAL::compare (min_x, other.max_x) == CGAL::LARGER) || (CGAL::compare (max_y, other.min_y) == CGAL::SMALLER) || (CGAL::compare (min_y, other.max_y) == CGAL::LARGER)) { return (false); } return (true); } /*! Check whether the two bounding boxed overlap in their x-range. */ bool overlaps_x (const Self& other) const { if ((CGAL::compare (max_x, other.min_x) == CGAL::SMALLER) || (CGAL::compare (min_x, other.max_x) == CGAL::LARGER)) { return (false); } return (true); } }; /*!\ class Bezier_bounding_rational_traits * A traits class for performing bounding operations on Bezier curves, * assuming the NT is rational. */ template <typename _Kernel> class Bezier_bounding_rational_traits { public: typedef _Kernel Kernel; typedef typename Kernel::FT NT; typedef _Bez_point_bound<Kernel> Bez_point_bound; typedef _Bez_point_bbox<Kernel> Bez_point_bbox; typedef typename Bez_point_bound::Control_points Control_points; /*! \struct Vertical_tangency_point * Representation of an approximated vertical tangency point. */ struct Vertical_tangency_point { Bez_point_bound bound; /*!< A point-on-curve bound. */ Bez_point_bbox bbox; /*!< Bounding box for the point. */ /*! Default constructor. */ Vertical_tangency_point () : bound (), bbox () {} /*! Constructor. */ Vertical_tangency_point (const Bez_point_bound& _bound, const Bez_point_bbox& _bbox) : bound (_bound), bbox (_bbox) {} }; /*! \struct Vertical_tangency_point * Representation of an approximated intersection point. */ struct Intersection_point { Bez_point_bound bound1; /*!< A point-on-curve bound for the first curve. */ Bez_point_bound bound2; /*!< A point-on-curve bound for the second curve. */ Bez_point_bbox bbox; /*!< Bounding box for the point. */ /*! Default constructor. */ Intersection_point() : bound1(), bound2(), bbox() {} /*! Constructor. */ Intersection_point (const Bez_point_bound& _bound1, const Bez_point_bound& _bound2, const Bez_point_bbox& _bbox) : bound1 (_bound1), bound2 (_bound2), bbox (_bbox) {} }; protected: typedef typename Kernel::Point_2 Point_2; typedef typename Kernel::Vector_2 Vector_2; typedef typename Kernel::Line_2 Line_2; typedef typename Kernel::Direction_2 Direction_2; // Data members: NT m_accuracy_bound; /*!< An accuracy bound. */ Kernel m_kernel; /*!< A geometry kernel. */ unsigned int m_active_nodes; /*!< Limit for the number of recursive calls for the approximated intersection procedure. */ // Kernel functors: typename Kernel::Construct_vector_2 f_construct_vector; typename Kernel::Construct_line_2 f_construct_line; typename Kernel::Construct_direction_2 f_construct_direction; typename Kernel::Construct_opposite_direction_2 f_opposite_direction; typename Kernel::Construct_translated_point_2 f_construct_point; typename Kernel::Equal_2 f_equal; typename Kernel::Compare_x_2 f_compare_x; typename Kernel::Compare_y_2 f_compare_y; typename Kernel::Orientation_2 f_orientation; typename Kernel::Counterclockwise_in_between_2 f_ccw_in_between; typename Kernel::Less_signed_distance_to_line_2 f_less_signed_distance; typename Kernel::Oriented_side_2 f_oriented_side; typename Kernel::Intersect_2 f_intersect; public: /*! * Constructor. * \param bound Accuracy bound. We cannot determine the order of two values * whose absolute difference is smaller than this bound. */ Bezier_bounding_rational_traits (double bound = 0.00000000000000011) : m_accuracy_bound (bound), m_active_nodes (0) { // Construct the kernel functors. f_construct_vector = m_kernel.construct_vector_2_object(); f_construct_line = m_kernel.construct_line_2_object(); f_construct_direction = m_kernel.construct_direction_2_object(); f_opposite_direction = m_kernel.construct_opposite_direction_2_object(); f_construct_point = m_kernel.construct_translated_point_2_object(); f_equal = m_kernel.equal_2_object(); f_compare_x = m_kernel.compare_x_2_object(); f_compare_y = m_kernel.compare_y_2_object(); f_orientation = m_kernel.orientation_2_object(); f_ccw_in_between = m_kernel.counterclockwise_in_between_2_object(); f_less_signed_distance = m_kernel.less_signed_distance_to_line_2_object(); f_oriented_side = m_kernel.oriented_side_2_object(); f_intersect = m_kernel.intersect_2_object(); } /// \name Handling intersection points. //@{ /*! * Check whether the curve specified by the given control polygon may * have self intersections. * \param cp The control polygon of the curve. * \return Whether the curve may be self-intersecting (but not necessarily). * In case the function returns false, there can be absolutely no * self-intersections. */ bool may_have_self_intersections (const Control_points& cp) { // In case the control polygon is convex, the Bezier curve cannot be // self-intersecting. if (is_convex_2 (cp.begin(), cp.end(), m_kernel)) return (false); // In case the angular span of the control polygon is less than 180 // degrees, it cannot be self-intersecting. Vector_2 v_min; Vector_2 v_max; if (_compute_angular_span (cp, v_min, v_max)) return (false); // Otherwise, the curve may be self-intersecting. return (true); } /*! * Compute bounds for the intersection points between two Bezier curves. * \param cp1 The control polygon of the first curve. * \param cp2 The control polygon of the second curve. * \param oi Output: The bounds of the intersection points. * The value-type of this iterator is Intersection_point. */ template <class OutputIterator> OutputIterator compute_intersection_points (const Control_points& cp1, const Control_points& cp2, OutputIterator oi) { // Call the recursive function. std::set<NT> dummy; std::list<Intersection_point> ipts; m_active_nodes = 1; _compute_intersection_points (cp1, 0, 1, cp2, 0, 1, true, dummy, // Check span. ipts); // Copy the computed points to the output iterator. typename std::list<Intersection_point>::iterator it; for (it = ipts.begin(); it != ipts.end(); ++it) { *oi = *it; ++oi; } return (oi); } /*! * Refine the approximation of a given intersection point. * \param in_pt The intersection point. * \param ref_pt Output: The refined representation of the point. * \return Whether the point has been successfully refined (if not, the * output point is the same as the input). */ bool refine_intersection_point (const Intersection_point& in_pt, Intersection_point& ref_pt) { // Check if it is not possible to refine. if (! in_pt.bound1.can_refine || ! in_pt.bound2.can_refine) { ref_pt = in_pt; return (false); } // In case the point is already rational, there is not point in refining // it. if (in_pt.bound1.type == Bez_point_bound::RATIONAL_PT || in_pt.bound2.type == Bez_point_bound::RATIONAL_PT) { ref_pt = in_pt; return (false); } // Check whether we can refine the parametric ranges of the two // originating Bezier curves. const Control_points& cp1 = in_pt.bound1.ctrl; const NT& t_min1 = in_pt.bound1.t_min; const NT& t_max1 = in_pt.bound1.t_max; bool can_refine1 = can_refine (cp1, t_min1, t_max1); const Control_points& cp2 = in_pt.bound2.ctrl; const NT& t_min2 = in_pt.bound2.t_min; const NT& t_max2 = in_pt.bound2.t_max; bool can_refine2 = can_refine (cp2, t_min2, t_max2); if (! can_refine1 || ! can_refine2) { // Failed in the bounded approach - stop the subdivision and indicate // that the subdivision has failed. ref_pt = in_pt; ref_pt.bound1.can_refine = false; ref_pt.bound2.can_refine = false; return (false); } // Apply de Casteljau's algorithm and bisect both bounding polylines. Control_points cp1a, cp1b; const NT t_mid1 = (t_min1 + t_max1) / 2; bisect_control_polygon_2 (cp1.begin(), cp1.end(), std::back_inserter(cp1a), std::front_inserter(cp1b)); Control_points cp2a, cp2b; const NT t_mid2 = (t_min2 + t_max2) / 2; bisect_control_polygon_2 (cp2.begin(), cp2.end(), std::back_inserter(cp2a), std::front_inserter(cp2b)); // Catch situations that we cannot further refine, in order to prevent // having multiple points as the refined point. const bool can_refine_pt_cp1a = can_refine (cp1a, t_min1, t_mid1); const bool can_refine_pt_cp1b = can_refine (cp1b, t_mid1, t_max1); const bool can_refine_pt_cp2a = can_refine (cp2a, t_min2, t_mid2); const bool can_refine_pt_cp2b = can_refine (cp2b, t_mid2, t_max2); if (! can_refine_pt_cp1a || ! can_refine_pt_cp1b || ! can_refine_pt_cp2a || ! can_refine_pt_cp2b) { // Construct an inconclusive point bound, which includes all parameters // found so far, with can_refine = false, and with the bounding // box of cp1. Bez_point_bound bound1 (Bez_point_bound::INTERSECTION_PT, cp1, t_min1, t_max1, false); // Cannot refine further. Bez_point_bound bound2 (Bez_point_bound::INTERSECTION_PT, cp2, t_min2, t_max2, false); // Cannot refine further. Bez_point_bbox ref_bbox; construct_bbox (cp1, ref_bbox); ref_pt = Intersection_point (bound1, bound2, ref_bbox); return (true); } // Use the bisection method to refine the intersection point. // We assume that there is no need to check the span, as the input point // already has all the necessary data. std::list<Intersection_point> ipts; std::set<NT> dummy; m_active_nodes = 1; _compute_intersection_points (cp1a, t_min1, t_mid1, cp2a, t_min2, t_mid2, false, dummy, // Don't check span. ipts); if (! ipts.empty()) { if (ipts.size() == 1) { ref_pt = ipts.front(); return (true); } ipts.clear(); } m_active_nodes = 1; _compute_intersection_points (cp1a, t_min1, t_mid1, cp2b, t_mid2, t_max2, false, dummy, // Don't check span. ipts); if (! ipts.empty()) { if (ipts.size() == 1) { ref_pt = ipts.front(); return (true); } ipts.clear(); } m_active_nodes = 1; _compute_intersection_points (cp1b, t_mid1, t_max1, cp2a, t_min2, t_mid2, false, dummy, // Don't check span. ipts); if (! ipts.empty()) { if (ipts.size() == 1) { ref_pt = ipts.front(); return (true); } ipts.clear(); } m_active_nodes = 1; _compute_intersection_points (cp1b, t_mid1, t_max1, cp2b, t_mid2, t_max2, false, dummy, // Don't check span. ipts); CGAL_assertion (ipts.size() == 1); ref_pt = ipts.front(); return (true); } //@} /// \name Handling vertcial tangency points. //@{ /*! * Compute bounds for the vertical tangency points of a Bezier curves. * The points are returned sorted by their parameter value. * \param cp The control polygon of the curve. * \param oi Output: The bounds of the vertical tangency points. * The value-type is Vertical_tangency_point. */ template <class OutputIterator> OutputIterator compute_vertical_tangency_points (const Control_points& cp, OutputIterator oi) { // Call the recursive function on the entire curve (0 <= t <= 1). std::list<Vertical_tangency_point> vpts; _compute_vertical_tangency_points (cp, 0, 1, vpts); // Copy the computed points to the output iterator, sorted by their // parameter value (note we compare the t_min values of the bounds; this // is possible as different vertical tangency points are expected to // have disjoint parametric ranges). typename std::list<Vertical_tangency_point>::iterator vpt_it; typename std::list<Vertical_tangency_point>::iterator vpt_end; typename std::list<Vertical_tangency_point>::iterator vpt_min; while (! vpts.empty()) { // Locate the vertical tangency point with minimal t-value. vpt_min = vpt_it = vpts.begin(); vpt_end = vpts.end(); ++vpt_it; while (vpt_it != vpt_end) { if (CGAL::compare (vpt_it->bound.t_min, vpt_min->bound.t_min) == SMALLER) { vpt_min = vpt_it; } ++vpt_it; } // Copy this point to the output iterator. *oi = *vpt_min; ++oi; // Remove it from the list. vpts.erase (vpt_min); } return (oi); } /*! * Refine the approximation of a given vertical tangency point. * \param in_pt The vertical tangency point. * \param ref_pt Output: The refined representation of the point. * \return Whether the point has been successfully refined (if not, the * output point is the same as the input). */ bool refine_vertical_tangency_point (const Vertical_tangency_point& in_pt, Vertical_tangency_point& ref_pt) { // Check if it is not possible to refine. if (! in_pt.bound.can_refine || in_pt.bound.type == Bez_point_bound::RATIONAL_PT) { ref_pt = in_pt; return (false); } // Check whether we can refine the parametric ranges of the originating // Bezier curve. const Control_points& cp = in_pt.bound.ctrl; const NT& t_min = in_pt.bound.t_min; const NT& t_max = in_pt.bound.t_max; if (! can_refine (cp, t_min, t_max)) { // Failed in the bounded approach - stop the subdivision and indicate // that the subdivision has failed. ref_pt = in_pt; ref_pt.bound.can_refine = false; return (false); } // Apply de Casteljau's algorithm and bisect the bounding polyline. Control_points cp_a, cp_b; const NT t_mid = (t_min + t_max) / 2; bisect_control_polygon_2 (cp.begin(), cp.end(), std::back_inserter(cp_a), std::front_inserter(cp_b)); // Handle the case where t_mid is a vertical (rational) tangency // point, by checking whether the first vector of right is vertical. if (f_compare_x (cp_b[0], cp_b[1]) == EQUAL) { // The subdivision point at t_mid is a vertical tangency point with // rational coordinates. const typename Kernel::Point_2 &vpt = cp_b[0]; Bez_point_bound bound (Bez_point_bound::RATIONAL_PT, cp_b, t_mid, t_mid, true); Bez_point_bbox bbox (vpt.x(), vpt.x(), vpt.y(), vpt.y()); ref_pt = Vertical_tangency_point (bound, bbox); return (true); } const bool can_refine_pt_cp_a = can_refine (cp_a, t_min, t_mid); const bool can_refine_pt_cp_b = can_refine (cp_b, t_mid, t_max); if (! can_refine_pt_cp_a || ! can_refine_pt_cp_b) { // Construct an inconclusive point bound, which includes all parameters // found so far, with can_refine = false, and with the bounding // box of the curve. Bez_point_bound bound (Bez_point_bound::VERTICAL_TANGENCY_PT, cp, t_min, t_max, false); // Cannot refine further. Bez_point_bbox ref_bbox; construct_bbox (cp, ref_bbox); ref_pt = Vertical_tangency_point (bound, ref_bbox); return (true); } // Compute the vertical tangency points of the two subcurves in order to // refine the vertical tangency point. std::list<Vertical_tangency_point> vpts; _compute_vertical_tangency_points(cp_a, t_min, t_mid, vpts); _compute_vertical_tangency_points(cp_b, t_mid, t_max, vpts); CGAL_assertion(vpts.size() == 1); ref_pt = vpts.front(); return (true); } //@} /// \name Predicates. //@{ /*! * Check whether the current polyline can be refined. * In this case we simply check the values that define the parametric * range are well-separated. */ bool can_refine (const Control_points& , const NT& t_min, const NT& t_max) { return (CGAL::compare (t_max - t_min, m_accuracy_bound) != SMALLER); } /*! * Compare the slopes of two Bezier curve at their intersection point, * given the point-on-curve bounds at this point. * \param bound1 The point-on-curve bound of the first curve. * \param bound2 The point-on-curve bound of the second curve. * \return The comparison result. */ Comparison_result compare_slopes_at_intersection_point (const Bez_point_bound& bound1, const Bez_point_bound& bound2) { const Control_points& cp1 = bound1.ctrl; const Control_points& cp2 = bound2.ctrl; // An (expensive) check that the angular spans do not overlap. CGAL_expensive_precondition_code ( Vector_2 v_min1; Vector_2 v_max1; const bool span_ok1 = _compute_angular_span (cp1, v_min1, v_max1); Vector_2 v_min2; Vector_2 v_max2; const bool span_ok2 = _compute_angular_span (cp2, v_min2, v_max2); bool spans_overlap = true; if (span_ok1 && span_ok2) { spans_overlap = _angular_spans_overlap (v_min1, v_max1, v_min2, v_max2); } ); CGAL_expensive_precondition (! spans_overlap); // As the angular spans of the control polygons do not overlap, we can // just compare any vector of the hodograph spans. const Vector_2 dir1 = f_construct_vector (cp1.front(), cp1.back()); const Vector_2 dir2 = f_construct_vector (cp2.front(), cp2.back()); // The slopes are given by dir1.y() / dir1.x() and dir2.y()/dir2.x(). // However, to avoid potential division by zero, we compare: // dir1.y()*dir2.x() and dir2.y()*dir1.x(), after considering the signs // of the xs. Comparison_result res; bool swap_res = false; if (CGAL::sign (dir1.x()) == CGAL::NEGATIVE) swap_res = ! swap_res; if (CGAL::sign (dir2.x()) == CGAL::NEGATIVE) swap_res = ! swap_res; res = CGAL::compare (dir1.y() * dir2.x(), dir2.y() * dir1.x()); if (swap_res) res = CGAL::opposite (res); return (res); } /*! * Construct a bounding box for the given control polygon. * \param cp A sequence of control point (the control polgon). * \param bbox Output: The bounding box. * \pre cp is not empty. */ void construct_bbox (const Control_points& cp, Bez_point_bbox& bez_bbox) { CGAL_precondition (! cp.empty()); // Go over the points, and locate the ones with extremal x and y values. typename Control_points::const_iterator it = cp.begin(); typename Control_points::const_iterator it_end = cp.end(); typename Control_points::const_iterator min_x = it; typename Control_points::const_iterator max_x = it; typename Control_points::const_iterator min_y = it; typename Control_points::const_iterator max_y = it; while (it != it_end) { if (f_compare_x (*it, *min_x) == SMALLER) min_x = it; else if (f_compare_x (*it, *max_x) == LARGER) max_x = it; if (f_compare_y (*it, *min_y) == SMALLER) min_y = it; else if (f_compare_y (*it, *max_y) == LARGER) max_y = it; ++it; } // Set the bounding box. bez_bbox.min_x = min_x->x(); bez_bbox.max_x = max_x->x(); bez_bbox.min_y = min_y->y(); bez_bbox.max_y = max_y->y(); return; } //@} private: /*! * Check whether the given control polygon defines an x-monotone (or * y-monotone) Bezier curve. * \param cp The control points. * \param check_x (true) to check x-monotonicity; * (false) to check y-monotonicity. * \return Is the curve x-monotone (or y-monotone). */ bool _is_monotone (const Control_points& cp, bool check_x) const { Comparison_result curr_res; Comparison_result res = EQUAL; // Look for the first pair of consecutive points whose x-coordinate // (or y-coordinate) are not equal. Their comparsion result will be // set as the "reference" comparison result. typename Control_points::const_iterator pt_curr = cp.begin(); typename Control_points::const_iterator pt_end = cp.end(); typename Control_points::const_iterator pt_next = pt_curr; ++pt_next; while (pt_next != pt_end) { curr_res = check_x ? f_compare_x (*pt_curr, *pt_next) : f_compare_y (*pt_curr, *pt_next); pt_curr = pt_next; ++pt_next; if (curr_res != EQUAL) { res = curr_res; break; } } if (pt_next == pt_end || res == EQUAL) { // If we reached here, we have an iso-parallel segment. // In our context, we consider a horizontal segment as non-y-monotone // but a vertical segment is considered x-monotone. if (check_x) return (true); // Vertical segment when checking x-monoticity return (false); // Horizontal segment when checking y-monoticity } // Go over the rest of the control polygons, and make sure that the // comparison result between each pair of consecutive points is the // same as the reference result. while (pt_next != pt_end) { curr_res = check_x ? f_compare_x (*pt_curr, *pt_next) : f_compare_y (*pt_curr, *pt_next); if (curr_res != EQUAL && res != curr_res) return (false); pt_curr = pt_next; ++pt_next; } // If we reached here, the control polygon is x-monotone (or y-monotone). return (true); } /*! * Check whether the control polygon defines an x-monotone Bezier curve. * \param cp The control points. * \return Is the curve x-monotone. */ inline bool _is_x_monotone (const Control_points& cp) const { return (_is_monotone (cp, true)); } /*! * Check whether the control polygon defines a y-monotone Bezier curve. * \param cp The control points. * \return Is the curve y-monotone. */ inline bool _is_y_monotone (const Control_points& cp) const { return (_is_monotone (cp, false)); } /*! * Compute the angular span of a Bezier curve, given by its control polygon. * \param cp The control points. * \param v_min Output: The minimal direction of the angular span. * \param v_max Output: The maximal direction of the angular span. * \return Whether the span is less than 90 degrees * (as we don't want to work with larger spans). */ bool _compute_angular_span (const Control_points& cp, Vector_2& v_min, Vector_2& v_max) { // Initialize the output directions. Vector_2 dir = f_construct_vector (cp.front(), cp.back()); Vector_2 v; v_min = v_max = dir; // Go over the control points and examine the vectors defined by pairs // of consecutive control points. typename Control_points::const_iterator pt_curr = cp.begin(); typename Control_points::const_iterator pt_end = cp.end(); typename Control_points::const_iterator pt_next = pt_curr; ++pt_next; while (pt_next != pt_end) { v = f_construct_vector (*pt_curr, *pt_next); // If the current vector forms a right-turn with dir, it is a candidate // for the minimal vector, otherwise it is a candidate for the maximal // vector in the span. bool updated_span = false; if (f_orientation (f_construct_point (ORIGIN, v), ORIGIN, f_construct_point (ORIGIN, dir)) == RIGHT_TURN) { // Check if we need to update the minimal vector in the span. if (f_orientation (f_construct_point (ORIGIN, v), ORIGIN, f_construct_point (ORIGIN, v_min)) == RIGHT_TURN) { v_min = v; updated_span = true; } } else { // Check if we need to update the maximal vector in the span. if (f_orientation (f_construct_point (ORIGIN, v), ORIGIN, f_construct_point (ORIGIN, v_max)) == LEFT_TURN) { v_max = v; updated_span = true; } } // Before proceeding, check if the current span is larger than // 180 degrees. We do that by checking that (v_min, 0, v_max) // is still a right-turn, and did not become a left-turn. if (updated_span && f_orientation (f_construct_point (ORIGIN, v_min), ORIGIN, f_construct_point (ORIGIN, v_max)) != RIGHT_TURN) { return (false); } // Move to the next pair of points. pt_curr = pt_next; ++pt_next; } // If we reached here, the angular span is less than 180 degrees. return (true); } /*! * Check whether to angular spans overlap. * \param v_min1 The minimal vector in the first angular span. * \param v_max1 The maximal vector in the first angular span. * \param v_min2 The minimal vector in the second angular span. * \param v_max2 The maximal vector in the second angular span. * \return Do the two spans overlap. */ bool _angular_spans_overlap (const Vector_2& v_min1, const Vector_2& v_max1, const Vector_2& v_min2, const Vector_2& v_max2) { if ( f_equal (v_min1, v_min2) && f_equal (v_max1, v_max2)) //spans are identical return (true); const Direction_2 dir_l1 = f_construct_direction (v_min1); const Direction_2 dir_r1 = f_construct_direction (v_max1); const Direction_2 dir_l2 = f_construct_direction (v_min2); const Direction_2 dir_r2 = f_construct_direction (v_max2); // Check whether any of the vectors of the second span (or their // opposite vectors) is between the vectors of the first span. if (! f_equal (v_min1, v_max1) && (f_ccw_in_between (dir_l2, dir_l1, dir_r1) || f_ccw_in_between (f_opposite_direction (dir_l2), dir_l1, dir_r1) || f_ccw_in_between (dir_r2, dir_l1, dir_r1) || f_ccw_in_between (f_opposite_direction (dir_r2), dir_l1, dir_r1))) { return (true); } // Check whether the left vector of the first span (or its opposite // vector) is between the vectors of the second span. Note that at this // point, the only possibility is that the first span is totally contained // within the second, so we do not need to check both vectors. if (! f_equal (v_min2, v_max2) && (f_ccw_in_between (dir_l1, dir_l2, dir_r2) || f_ccw_in_between (f_opposite_direction (dir_l1), dir_l2, dir_r2))) { return (true); } // If we reached here, the two angular spans do not overlap. return (false); } /*! * Construct a skewed bounding box for the control polygon. * The skewed bounding box is represented as a pair of lines, both parallel * to the line connecting the first and last points of the control polygon, * that bound the curve from above and below. * \param cp The control points. * \param l_min Output: The line with minimal signed distance. * \param l_max Output: The line with maximal signed distance. */ void _skewed_bbox (const Control_points& cp, Line_2& l_min, Line_2& l_max) { // Construct the line that connects the first and the last control points. const Line_2 l = f_construct_line (cp.front(), cp.back()); const Vector_2 v = f_construct_vector (cp.front(), cp.back()); // Select the points with minimum and maximum distance from the line l, // and construct two lines parallel to l that pass through these points. typename Control_points::const_iterator pt_curr = cp.begin(); typename Control_points::const_iterator pt_end = cp.end(); typename Control_points::const_iterator pt_min = pt_curr; typename Control_points::const_iterator pt_max = pt_curr; ++pt_curr; while (pt_curr != pt_end) { if (f_less_signed_distance (l, *pt_curr, *pt_min)) { pt_min = pt_curr; } else if (f_less_signed_distance (l, *pt_max, *pt_curr)) { pt_max = pt_curr; } ++pt_curr; } // Construct the output lines. l_min = f_construct_line (*pt_min, v); l_max = f_construct_line (*pt_max, v); return; } /*! * Check whether the endpoints of the two curves coincide. * If so, it adds the Intersection_point to the list if the endpoint hasn't * already been inserted there. * Note that this function is not able to detect an endpoint that lies in * the interior of the other curve. Such cases will not be approximated * and we will have to resort to exact computation. * \param cp1 The control points of the first curve. * \param t_min1 The lower bound of the parameter range of the first curve. * \param t_max1 The upper bound of the parameter range of the first curve. * \param cp2 The control points of the second curve. * \param t_min2 The lower bound of the parameter range of the second curve. * \param t_max2 The upper bound of the parameter range of the second curve. * \param iept_params Input/Output: The set of parameter values (for cp1) * of known intersections at the endpoints. * \param ipts Input/Output: The computed intersection points. * \return Whether a pair of curve endpoints coincide. */ bool _endpoints_coincide (const Control_points& cp1, const NT& t_min1, const NT& t_max1, const Control_points& cp2, const NT& t_min2, const NT& t_max2, std::set<NT>& iept_params, std::list<Intersection_point>& ipts) const { // Get the first and last control points of each curve. const Point_2& s1 = cp1.front(); const Point_2& t1 = cp1.back(); const Point_2& s2 = cp2.front(); const Point_2& t2 = cp2.back(); // Check whether any pair of these endpoints conincide. NT x, y; // Coordinate of a common endpoint. NT t_val1, t_val2; // Its respective parameters. if (f_equal (s1, s2)) { x = s1.x(); y = s1.y(); t_val1 = t_min1; t_val2 = t_min2; } else if (f_equal (s1, t2)) { x = s1.x(); y = s1.y(); t_val1 = t_min1; t_val2 = t_max2; } else if (f_equal (t1, s2)) { x = t1.x(); y = t1.y(); t_val1 = t_max1; t_val2 = t_min2; } else if (f_equal (t1, t2)) { x = t1.x(); y = t1.y(); t_val1 = t_max1; t_val2 = t_max2; } else { // No common endpoint found: return (false); } // Try inserting the parameter value t1 into the set of parameters of // already discovered intersecting endpoints. std::pair<typename std::set<NT>::iterator, bool> res = iept_params.insert (t_val1); if (res.second) { // In case the insertion has succeeded, report on a new rational // intersection point. Bez_point_bound bound1 (Bez_point_bound::RATIONAL_PT, cp1, t_val1, t_val1, true); Bez_point_bound bound2 (Bez_point_bound::RATIONAL_PT, cp2, t_val2, t_val2, true); Bez_point_bbox bbox (x, x, y, y); ipts.push_back (Intersection_point (bound1, bound2, bbox)); } return (true); } /*! * An auxilary recursive function for computing the approximated * intersection points between two Bezier curves. * \param cp1 The control points of the first curve. * \param t_min1 The lower bound of the parameter range of the first curve. * \param t_max1 The upper bound of the parameter range of the first curve. * \param cp2 The control points of the second curve. * \param t_min2 The lower bound of the parameter range of the second curve. * \param t_max2 The upper bound of the parameter range of the second curve. * \param check_span Should we check the angular span of the curves. * \param iept_params Input/Output: The set of parameter values (for cp1) * of known intersections at the endpoints. * \param ipts Input/Output: The computed intersection points. */ void _compute_intersection_points (const Control_points& cp1, const NT& t_min1, const NT& t_max1, const Control_points& cp2, const NT& t_min2, const NT& t_max2, bool check_span, std::set<NT>& iept_params, std::list<Intersection_point>& ipts) { // Check if we got to subdivision termination criteria. const bool can_refine1 = can_refine (cp1, t_min1, t_max1); const bool can_refine2 = can_refine (cp2, t_min2, t_max2);; if (! can_refine1 || ! can_refine2) { // It is not possible to further refine the approximation, so we stop // the recursive subdivision, and construct an output intersection point // with can_refine = false. Note that we do not need a tight bounding // box here, since we cannot refine it anyway, so we take cp1's bbox // (which certainly contains the intersection point). Bez_point_bound bound1 (Bez_point_bound::INTERSECTION_PT, cp1, t_min1, t_max1, false); // Cannot refine further. Bez_point_bound bound2 (Bez_point_bound::INTERSECTION_PT, cp2, t_min2, t_max2, false); // Cannot refine further. Bez_point_bbox ipt_bbox; construct_bbox (cp1, ipt_bbox); ipts.push_back (Intersection_point (bound1, bound2, ipt_bbox)); m_active_nodes--; return; } // Consturct bounding boxes for the two curves and check whether they // overlap. Bez_point_bbox bbox1; Bez_point_bbox bbox2; construct_bbox (cp1, bbox1); construct_bbox (cp2, bbox2); if (! bbox1.overlaps (bbox2)) { // The bounding boxes do not overlap, so the two input curves do not // intersect. m_active_nodes--; return; } // Check the angular spans, if necessary. bool spans_overlap = false; if (check_span) { // Compute the angular spans of the two curves. Vector_2 v_min1, v_max1; const bool span_ok1 = _compute_angular_span (cp1, v_min1, v_max1); Vector_2 v_min2, v_max2; const bool span_ok2 = _compute_angular_span (cp2, v_min2, v_max2); if (span_ok1 && span_ok2) { spans_overlap = _angular_spans_overlap (v_min1, v_max1, v_min2, v_max2); } else { // One of the spans is greater than 180 degrees, so we do not have to // check for overlaps (we know that it must overlap the other span). spans_overlap = true; } } if (! spans_overlap) { // In case the spans do not overlap, we potentially have a single // intersection point. // Checking for endpoint intersections. if (_endpoints_coincide (cp1, t_min1, t_max1, cp2, t_min2, t_max2, iept_params, ipts)) { // As we have located the single intersection point (a common endpoint // in this case), we can stop here. m_active_nodes--; return; } // Construct the skewed bounding boxes for the two curves and check // whether the endpoints of the first curve lie on opposite side of // the skewed bounding box of the second curve, and vice versa. Line_2 skew1a, skew1b; Line_2 skew2a, skew2b; const Point_2& s1 = cp1.front(); const Point_2& t1 = cp1.back(); const Point_2& s2 = cp2.front(); const Point_2& t2 = cp2.back(); _skewed_bbox(cp1, skew1a, skew1b); _skewed_bbox(cp2, skew2a, skew2b); const Oriented_side or_2a_s1 = f_oriented_side (skew2a, s1); const Oriented_side or_2a_t1 = f_oriented_side (skew2a, t1); const Oriented_side or_2b_s1 = f_oriented_side (skew2b, s1); const Oriented_side or_2b_t1 = f_oriented_side (skew2b, t1); const bool s1_t1_are_opposite = ((or_2a_s1 == CGAL::opposite (or_2a_t1)) && (or_2b_s1 == CGAL:: opposite (or_2b_t1))); const Oriented_side or_1a_s2 = f_oriented_side (skew1a, s2); const Oriented_side or_1a_t2 = f_oriented_side (skew1a, t2); const Oriented_side or_1b_s2 = f_oriented_side (skew1b, s2); const Oriented_side or_1b_t2 = f_oriented_side (skew1b, t2); const bool s2_t2_are_opposite = ((or_1a_s2 == CGAL::opposite (or_1a_t2)) && (or_1b_s2 == CGAL::opposite (or_1b_t2))); if (s1_t1_are_opposite && s2_t2_are_opposite) { // Construct a finer bounding box for the intersection point from // the intersection of the two skewed bounding boxes. Bez_point_bbox ipt_bbox; Control_points aux_vec; CGAL::Object res; Point_2 p; res = f_intersect (skew1a, skew2a); if (! assign (p, res)) { CGAL_error(); } aux_vec.push_back(p); res = f_intersect (skew1a, skew2b); if (! assign(p, res)) { CGAL_error(); } aux_vec.push_back(p); res = f_intersect (skew1b, skew2a); if (! assign(p, res)) { CGAL_error(); } aux_vec.push_back(p); res = f_intersect (skew1b, skew2b); if (!assign(p, res)) { CGAL_error(); } aux_vec.push_back(p); construct_bbox (aux_vec, ipt_bbox); // Report on the intersection point we have managed to isolate. Bez_point_bound bound1 (Bez_point_bound::INTERSECTION_PT, cp1, t_min1, t_max1, true); // We can further refine it. Bez_point_bound bound2 (Bez_point_bound::INTERSECTION_PT, cp2, t_min2, t_max2, true); // We can further refine it. ipts.push_back (Intersection_point (bound1, bound2, ipt_bbox)); m_active_nodes--; return; } } // Apply de Casteljau's algorithm and bisect both bounding polylines. Control_points cp1a, cp1b; const NT t_mid1 = (t_min1 + t_max1) / 2; bisect_control_polygon_2 (cp1.begin(), cp1.end(), std::back_inserter(cp1a), std::front_inserter(cp1b)); Control_points cp2a, cp2b; const NT t_mid2 = (t_min2 + t_max2) / 2; bisect_control_polygon_2 (cp2.begin(), cp2.end(), std::back_inserter(cp2a), std::front_inserter(cp2b)); // Recursively compute the intersection points on all pairs of bisected // curves. m_active_nodes += 4; if (m_active_nodes > 4 * cp1.size() * cp2.size()) { // It is not possible to further refine the approximation, as the // number of active nodes in the recursive search is too high. We stop // the recursive subdivision, and construct an output intersection point // with can_refine = false. Note that we do not need a tight bounding // box here, since we cannot refine it anyway, so we take cp1's bbox // (which certainly contains the intersection point). Bez_point_bound bound1 (Bez_point_bound::INTERSECTION_PT, cp1, t_min1, t_max1, false); // Cannot refine further. Bez_point_bound bound2 (Bez_point_bound::INTERSECTION_PT, cp2, t_min2, t_max2, false); // Cannot refine further. Bez_point_bbox ipt_bbox; construct_bbox (cp1, ipt_bbox); ipts.push_back (Intersection_point (bound1, bound2, ipt_bbox)); return; } _compute_intersection_points (cp1a, t_min1, t_mid1, cp2a, t_min2, t_mid2, spans_overlap, iept_params, ipts); _compute_intersection_points (cp1a, t_min1, t_mid1, cp2b, t_mid2, t_max2, spans_overlap, iept_params, ipts); _compute_intersection_points (cp1b, t_mid1, t_max1, cp2a, t_min2, t_mid2, spans_overlap, iept_params, ipts); _compute_intersection_points (cp1b, t_mid1, t_max1, cp2b, t_mid2, t_max2, spans_overlap, iept_params, ipts); m_active_nodes--; return; } /*! * An auxilary recursive function for computing the approximated vertical * tangency points of a Bezier curves. * \param cp The control points of the curve. * \param t_min The lower bound of the parameter range of the curve. * \param t_max The upper bound of the parameter range of the curve. * \param vpts Input/Output: The computed vertical tangency points. */ void _compute_vertical_tangency_points (const Control_points& cp, const NT& t_min, const NT& t_max, std::list<Vertical_tangency_point>& vpts) { // \todo Handle the special case of degree two curves. // Check if we got to subdivision termination criteria. if (! can_refine (cp, t_min, t_max)) { // It is not possible to further refine the approximation, so we stop // the recursive subdivision, and construct an output vertical tangency // point with can_refine = false. Note that we do not need a tight // bounding box here, since we cannot refine it anyway, so we take cp's // bbox (which certainly contains the intersection point). Bez_point_bound bound (Bez_point_bound::VERTICAL_TANGENCY_PT, cp, t_min, t_max, false); Bez_point_bbox vpt_bbox; construct_bbox (cp, vpt_bbox); vpts.push_back (Vertical_tangency_point (bound, vpt_bbox)); return; } // If the control polygon is x-monotone, the curve does not contain any // vertical tangency points. if (_is_x_monotone (cp)) { return; } // Check whether the control polygon is y-monotone. if (! _is_y_monotone (cp)) { // Use de Casteljau's algorithm and subdivide the control polygon into // two, in order to obtain y-monotone subcurves. Control_points cp_a, cp_b; const NT t_mid = (t_min + t_max) / 2; bisect_control_polygon_2 (cp.begin(), cp.end(), std::back_inserter (cp_a), std::front_inserter (cp_b)); // Check the case where t_mid is a vertical (rational) tangency // point, by checking whether the first vector of right is vertical. if (f_compare_x (cp_b[0], cp_b[1]) == EQUAL) { // The subdivision point at t_mid is a vertical tangency point with // rational coordinates. const typename Kernel::Point_2 &vpt = cp_b[0]; Bez_point_bound bound (Bez_point_bound::RATIONAL_PT, cp_b, t_mid, t_mid, true); Bez_point_bbox bbox (vpt.x(), vpt.x(), vpt.y(), vpt.y()); vpts.push_back (Vertical_tangency_point (bound, bbox)); return; } // Recursively compute the vertical tangency points of the two // subcurves. _compute_vertical_tangency_points (cp_a, t_min, t_mid, vpts); _compute_vertical_tangency_points (cp_b, t_mid, t_max, vpts); return; } // If we reached here, the control polygon of the curve is y-monotone, // but not x-monotone. Check whether it is convex. If it is, we know the // curve contains exactly one vertical tangency point. if (is_convex_2 (cp.begin(), cp.end(), m_kernel)) { // We managed to isolate a single vertical tangency point. Bez_point_bound bound (Bez_point_bound::VERTICAL_TANGENCY_PT, cp, t_min, t_max, true); // It is possible to refine further. Bez_point_bbox vpt_bbox; construct_bbox (cp, vpt_bbox); vpts.push_back (Vertical_tangency_point (bound, vpt_bbox)); return; } // If we reached here, the curve contains more than a single vertical // tangency point. We therefore bisect it and continue recursively. Control_points cp_a, cp_b; const NT t_mid = (t_min + t_max) / 2; bisect_control_polygon_2 (cp.begin(), cp.end(), std::back_inserter(cp_a), std::front_inserter(cp_b)); // Check the case where t_mid is a vertical (rational) tangency // point, by checking whether the first vector of right is vertical. if (f_compare_x (cp_b[0], cp_b[1]) == EQUAL) { // The subdivision point at t_mid is a vertical tangency point with // rational coordinates. const typename Kernel::Point_2 &vpt = cp_b[0]; Bez_point_bound bound (Bez_point_bound::RATIONAL_PT, cp_b, t_mid, t_mid, true); Bez_point_bbox bbox (vpt.x(), vpt.x(), vpt.y(), vpt.y()); vpts.push_back (Vertical_tangency_point (bound, bbox)); return; } // Recursively compute the vertical tangency points on the two subcurves. _compute_vertical_tangency_points (cp_a, t_min, t_mid, vpts); _compute_vertical_tangency_points (cp_b, t_mid, t_max, vpts); return; } }; } //namespace CGAL #endif //CGAL_BEZIER_BOUNDING_RATIONAL_TRAITS_H
- Re: [cgal-discuss] Memory leaks in CGAL, Sebastien Loriot (GeometryFactory), 03/01/2011
- <Possible follow-up(s)>
- Re: [cgal-discuss] Memory leaks in CGAL, Stzpz, 03/02/2011
