[cgal-discuss] which faces are destroyed when inserting a point to a delaunay triangulation?
- To:
- Subject: [cgal-discuss] which faces are destroyed when inserting a point to a delaunay triangulation?
- Date: Wed, 2 Mar 2011 10:03:44 -0800 (PST)
Hi,
I need to know which faces are destroyed and which faces are the new created
faces when inserting a point into a delaunay triangulation. I'm using a
hierarchical_delaunay triangulation. I know the new faces are the ones that
the inserted point is a vertex of them. but how to access this faces from
vertex and the main question is "How I access the destroyed faces"?
Each face has some info and I need to distribute the info of the destroyed
faces between the new faces.
here is the types I used for my delaunay triangulation:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Triangulation_vertex_base_with_info_2 Vbb;
typedef CGAL::Triangulation_face_base_with_info_2,K> Fb;
typedef CGAL::Triangulation_hierarchy_vertex_base_2 Vb;
typedef CGAL::Triangulation_data_structure_2 Tds;
typedef CGAL::Delaunay_triangulation_2 Dt;
typedef CGAL::Triangulation_hierarchy_2 Triangulation;
typedef Triangulation::Point Point;
typedef Triangulation::Vertex_handle
Vertex_handle;
typedef Triangulation::Finite_faces_iterator
Finite_faces_iterator;
typedef Triangulation::Face_handle
Face_handle;
Vertex_handle;
typedef K::Point_3
Point_3;
Thanks in advance,
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/which-faces-are-destroyed-when-inserting-a-point-to-a-delaunay-triangulation-tp3331971p3331971.html
- [cgal-discuss] which faces are destroyed when inserting a point to a delaunay triangulation?, Farzaneh, 03/02/2011
- Re: [cgal-discuss] which faces are destroyed when inserting a point to a delaunay triangulation?, Sebastien Loriot (GeometryFactory), 03/03/2011
