cgal-discuss - Re: [cgal-discuss] which faces are destroyed when inserting a point to a delaunay triangulation?
  • To:
  • Subject: Re: [cgal-discuss] which faces are destroyed when inserting a point to a delaunay triangulation?
  • Date: Thu, 03 Mar 2011 08:09:14 +0100
First locate the point to insert using locate function documented in
[1], then use get_conflicts_and_boundary documented in [2] to get faces
that are going to be removed.
You can then use the function star_hole (see [1]) with the result of the
function get_conflicts_and_boundary to insert the point.
To get newly inserted faces use incident_faces documented in [1].
[1]http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.html
[2]http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Delaunay_triangulation_2.html
S.
Farzaneh wrote:
Hi,
I need to know which faces are destroyed and which faces are the new created
faces when inserting a point into a delaunay triangulation. I'm using a
hierarchical_delaunay triangulation. I know the new faces are the ones that
the inserted point is a vertex of them. but how to access this faces from
vertex and the main question is "How I access the destroyed faces"?
Each face has some info and I need to distribute the info of the destroyed
faces between the new faces.
here is the types I used for my delaunay triangulation:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Triangulation_vertex_base_with_info_2 Vbb;
typedef CGAL::Triangulation_face_base_with_info_2,K> Fb;
typedef CGAL::Triangulation_hierarchy_vertex_base_2 Vb;
typedef CGAL::Triangulation_data_structure_2 Tds;
typedef CGAL::Delaunay_triangulation_2 Dt;
typedef CGAL::Triangulation_hierarchy_2 Triangulation;
typedef Triangulation::Point Point;
typedef Triangulation::Vertex_handle
Vertex_handle;
typedef Triangulation::Finite_faces_iterator
Finite_faces_iterator;
typedef Triangulation::Face_handle
Face_handle;
Vertex_handle;
typedef K::Point_3
Point_3;
Thanks in advance,
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/which-faces-are-destroyed-when-inserting-a-point-to-a-delaunay-triangulation-tp3331971p3331971.html
