cgal-discuss - Re: [cgal-discuss] Point Set Process Simplification, but maintain the shape, volume and boundaries
  • To:
  • Subject: Re: [cgal-discuss] Point Set Process Simplification, but maintain the shape, volume and boundaries
  • Date: Thu, 03 Mar 2011 08:16:09 +0100
nsoonhui wrote:
For Point set simplification, two methods are available, http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Point_set_processing_3_ref/Function_random_simplify_point_set.html#Cross_link_anchor_1598
random_simplify_point_set and http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Point_set_processing_3_ref/Function_grid_simplify_point_set.html#Cross_link_anchor_1593
grid set simplification .
Neither which, I think, can maintain the shape, volume and boundaries as
well as the http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Surface_mesh_simplification/Chapter_main.html
surface mesh simplification .
Is there an algorithm to process the point set simplification such that the
delaunay triangulation formed from the simplified point set is the most
accurate with relative to the actual surface? I don't want to first
construct delaunay triangulation first, and only then applying the surface
mesh simplification because I afraid that triangulating a lot of points is
going to cost me a large amount of processing time.
I don't get your point.
The Delaunay triangulation of a point set is a partition of the convex
hull of your input points. How can this be accurate to a surface?
S.
  • Re: [cgal-discuss] Point Set Process Simplification, but maintain the shape, volume and boundaries, Sebastien Loriot (GeometryFactory), 03/03/2011
