Re: Re: [cgal-discuss] exact kernel + Polygon_set_2::join() + Visual C++ 2008 = fatal error C1060: compiler is out of heap space
- To:
- Subject: Re: Re: [cgal-discuss] exact kernel + Polygon_set_2::join() + Visual C++ 2008 = fatal error C1060: compiler is out of heap space
- Date: Fri, 4 Mar 2011 13:00:47 +0100 (CET)
Thank you for your reply!
Yes, I have already /Zm compiler option and tried several values such as
/Zm10,
/Zm100, /Zm200, /Zm500, /Zm1000, /Zm2000, etc. But neither values do not
work
so far. I will try other values later.
By the way, when I compiled the code attached in my previous post, the
compiler
seems to require almost or possibly more than 1GB RAM. Is this normal
behavior?
Thank you
Yusuke
- Re: [cgal-discuss] exact kernel + Polygon_set_2::join() + Visual C++ 2008 = fatal error C1060: compiler is out of heap space, Yasui, 03/04/2011
- Re: [cgal-discuss] exact kernel + Polygon_set_2::join() + Visual C++ 2008 = fatal error C1060: compiler is out of heap space, Karl Gaize, 03/04/2011
- Re: Re: [cgal-discuss] exact kernel + Polygon_set_2::join() + Visual C++ 2008 = fatal error C1060: compiler is out of heap space, Yasui, 03/04/2011
