cgal-discuss - Re: [cgal-discuss] exact kernel + Polygon_set_2::join() + Visual C++ 2008 = fatal error C1060: compiler is out of heap space
  • To:
  • Subject: Re: [cgal-discuss] exact kernel + Polygon_set_2::join() + Visual C++ 2008 = fatal error C1060: compiler is out of heap space
  • Date: Fri, 04 Mar 2011 12:12:32 +0000
I wouldn't know exactly how much it requires, we don't require the use of the
exact predicates, so our build is quite a bit leaner.
probably the best idea is to remove the /Zm completely unless you're using
precompiled headers and are getting the C1076 error.
if you are and do, you should also be getting a C3859 message which tells you
what /Zm factor you need.
Karl
On 04/03/2011 12:00, Yasui wrote:
Thank you for your reply!
Yes, I have already /Zm compiler option and tried several values such as
/Zm10,
/Zm100, /Zm200, /Zm500, /Zm1000, /Zm2000, etc. But neither values do not
work
so far. I will try other values later.
By the way, when I compiled the code attached in my previous post, the
compiler
seems to require almost or possibly more than 1GB RAM. Is this normal
behavior?
Thank you
Yusuke
