cgal-discuss - [cgal-discuss] Boundary markers and vertex attributes in 3D Mesh Generation
  • To:
  • Subject: [cgal-discuss] Boundary markers and vertex attributes in 3D Mesh Generation
  • Date: Fri, 11 Mar 2011 17:06:46 +0100
Hello everyone,
First of all I would like to say I'm new to CGAL and this mailing list so
literally every bit of knowledge may help :)
Second of all I would like to ask about the usage of custom vertex attributes
and boundary markers with 3D Mesh Generation (Mesh_3) package.
I'll start by providing some context. I would like to use the D Mesh
Generation (Mesh_3) package to generate a tetrahedron mesh to be used with
Finite Element Method.
The problem I'm working on suggests following data flow:
1) The problem domain will be modeled in some 3d modeling application and
saved to a file as a polyhedral mesh (format of the file still has to be
chosen but there are no constraints on this). The domain will have a
subdomain (that I guess will be a polyhedral mesh itself) that is contained
within the main domain. The boundary of the main domain has some "hot spots"
that I need to designate during this first step - for this I would like to
"mark" the triangles that constitute the part of this boundary with some
boundary marker.
2) The domain and subdomain should now be used to genarate a tetrahedron mesh
3) The mesh will be edited again in order to assign some vertex attributes -
the diffusion tensors, initial densities etc. to the vertices
4) The mesh may undergo one or more refinements depending on the FEM
computation results
The problem I haven't found an obvious answer to is how to include the
boundary markers and vertex attributes in such a way that the propagate as
follows:
- For boundary markers, if a marked triangle is split into several triangles
each new one will be marked as well.
- For vertex attributes, the new vertices generated should have the
attributes interpolated linearly from vertices used to generate the new one.
How can one achieve above behavior?
Let me note that it doesn't have to be direct. If after creating a mesh/doing
refinement I can get a mapping from vertices of the old mesh to the same
vertices in new mesh I'll be more than happy to compute the
attributes/markers myself.
Best Regards,
Bartłomiej Siwek
  • [cgal-discuss] Boundary markers and vertex attributes in 3D Mesh Generation, Bartłomiej Siwek, 03/11/2011
