[cgal-discuss] missing objects when meshing a 3D image with multiple disconnected inclusions
- To:
- Subject: [cgal-discuss] missing objects when meshing a 3D image with multiple disconnected inclusions
- Date: Fri, 11 Mar 2011 17:48:32 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject :content-type:content-transfer-encoding; b=kE0N+WUZ/pOBJrIJ6jyXAmZfEV5aszTqHDQ2Klh8DzbmOLGLI38i0+H+OluyhX5ftn Ir0TGVyMZ6jz/Vjn6vcRT/q+ay1DNfaejQMKzDCqSh1SgUpNTRMTx2Rxt7PVhG1ODeo4 q77UUIaUYCWHs+6+jGPXBquzhkZL5ghyOsWYw=
Dear list:
I found this issue in both CGAL 3D mesher and surface mesher.
The test data set can be downloaded at
http://nmr.mgh.harvard.edu/~fangq/temp/fivespheres.inr.gz
the gz file is 9k in size, containing a binary 100x100x100 image
with 5 spherical inclusions (inside the inclusions is 1, outside is 0).
When running example/Surface_mesher/mesh_a_3d_gray_image.cpp
for the data, the output surface mesh only contains a single sphere.
I modified CGAL to allow me to set random number seeds.
With different seeds, the program may occasionally give
2 spheres. Similarly observations for sample/Mesh_3/mesh_3D_image.cpp
Please advise how to make CGAL aware of all inclusions in
this type of images.
thank you
Qianqian
- [cgal-discuss] missing objects when meshing a 3D image with multiple disconnected inclusions, Qianqian Fang, 03/11/2011
