- To:
- Subject: [cgal-discuss] how to compile mex-file based on CGAL in Matlab
- Date: Sun, 13 Mar 2011 10:40:40 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=cFaEsxBPriC/KfFNRY9BtaI7jcJ3toN1vuJPAnogMQV0fQf/33v/RQzk+6kmI/p5K3 dIYdvstzMlafNyZgK7ZwJ96k9ri3EW43DamBORWr3q6fJY4sFlYgxp8TX9vAw+JzKllL tATWtd/KIp8CA7Gb0g6piyTXnZHee0XjxYwKA=
Hi, everyone,
I have a problem to use mex in matlab to compile the "mexfile.cpp" in attachment. In matlab command windows, I use the following command:
>> mex mexfile.cpp -I/usr/include/:/usr/local/include/:/opt/matlab/extern/include/ -L/usr/lib/:/usr/local/lib/:/opt/matlab/extern/lib/glnxa64
My CGAL and gmp install location is /usr/include/ and /usr/lib, my boost location is /usr/local/include/ and /usr/local/lib/
But I can't complie it, can you give me some suggestion about it? Thanks very much!
The compile result is following:
Warning: You are using gcc version "4.4.3-4ubuntu5)". The version
currently supported with MEX is "4.2.3".
For a list of currently supported compilers see:
http://www.mathworks.com/support/compilers/current_release/
mexfile.o: In function `CGAL::Handle_for<CGAL::Gmpq_rep, std::allocator<CGAL::Gmpq_rep> >::~Handle_for()':
mexfile.cpp:(.text._ZN4CGAL10Handle_forINS_8Gmpq_repESaIS1_EED2Ev[CGAL::Handle_for<CGAL::Gmpq_rep, std::allocator<CGAL::Gmpq_rep> >::~Handle_for()]+0x18): undefined reference to `__gmpq_clear'
mexfile.o: In function `boost::operator-(CGAL::Gmpq const&, CGAL::Gmpq const&)':
mexfile.cpp:(.text._ZN5boostmiERKN4CGAL4GmpqES3_[boost::operator-(CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x3e): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN5boostmiERKN4CGAL4GmpqES3_[boost::operator-(CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x60): undefined reference to `__gmpq_sub'
mexfile.o: In function `boost::operator*(CGAL::Gmpq const&, CGAL::Gmpq const&)':
mexfile.cpp:(.text._ZN5boostmlERKN4CGAL4GmpqES3_[boost::operator*(CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x3e): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN5boostmlERKN4CGAL4GmpqES3_[boost::operator*(CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x60): undefined reference to `__gmpq_mul'
mexfile.o: In function `CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::orientationC2<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)':
mexfile.cpp:(.text._ZN4CGAL13orientationC2INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::orientationC2<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0xa1): undefined reference to `__gmpq_cmp'
mexfile.cpp:(.text._ZN4CGAL13orientationC2INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::orientationC2<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0xb6): undefined reference to `__gmpq_cmp'
mexfile.o: In function `CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >::operator()(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const':
mexfile.cpp:(.text._ZNK4CGAL19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS_16Simple_cartesianIdEELb1EEEEES6_EENS4_INS_4GmpqEEENS_12NT_converterIdS9_EEEclERKNS_7Point_3IS6_EE[CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >::operator()(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x37): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS_16Simple_cartesianIdEELb1EEEEES6_EENS4_INS_4GmpqEEENS_12NT_converterIdS9_EEEclERKNS_7Point_3IS6_EE[CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >::operator()(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x5a): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS_16Simple_cartesianIdEELb1EEEEES6_EENS4_INS_4GmpqEEENS_12NT_converterIdS9_EEEclERKNS_7Point_3IS6_EE[CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >::operator()(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x95): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS_16Simple_cartesianIdEELb1EEEEES6_EENS4_INS_4GmpqEEENS_12NT_converterIdS9_EEEclERKNS_7Point_3IS6_EE[CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >::operator()(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0xba): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS_16Simple_cartesianIdEELb1EEEEES6_EENS4_INS_4GmpqEEENS_12NT_converterIdS9_EEEclERKNS_7Point_3IS6_EE[CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >::operator()(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0xf5): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS_16Simple_cartesianIdEELb1EEEEES6_EENS4_INS_4GmpqEEENS_12NT_converterIdS9_EEEclERKNS_7Point_3IS6_EE[CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >::operator()(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x117): undefined reference to `__gmpq_set_d'
mexfile.o: In function `boost::thread_specific_ptr<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > >::Vector_with_reserve<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > >::iAdjacency_info, 64> >::~thread_specific_ptr()':
mexfile.cpp:(.text._ZN5boost19thread_specific_ptrIN4CGAL30Triangulation_data_structure_3INS1_26Surface_mesh_vertex_base_3INS1_28Robust_circumcenter_traits_3INS1_15Filtered_kernelINS1_16Simple_cartesianIdEELb1EEEEENS1_27Triangulation_vertex_base_3IS9_NS1_30Triangulation_ds_vertex_base_3IvEEEEEENS1_43Triangulation_cell_base_with_circumcenter_3IS9_NS1_24Surface_mesh_cell_base_3IS9_NS1_25Triangulation_cell_base_3IS9_NS1_28Triangulation_ds_cell_base_3IvEEEEEEEEE19Vector_with_reserveINSN_15iAdjacency_infoELi64EEEED1Ev[boost::thread_specific_ptr<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > >::Vector_with_reserve<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > >::iAdjacency_info, 64> >::~thread_specific_ptr()]+0x2d): undefined reference to `boost::detail::set_tss_data(void const*, boost::shared_ptr<boost::detail::tss_cleanup_function>, void*, bool)'
mexfile.o: In function `CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > >::create_star_3(CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > >, CGAL::Default>, false>, CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > > >, CGAL::Default>, false>, int, int)':
mexfile.cpp:(.text._ZN4CGAL30Triangulation_data_structure_3INS_26Surface_mesh_vertex_base_3INS_28Robust_circumcenter_traits_3INS_15Filtered_kernelINS_16Simple_cartesianIdEELb1EEEEENS_27Triangulation_vertex_base_3IS7_NS_30Triangulation_ds_vertex_base_3IvEEEEEENS_43Triangulation_cell_base_with_circumcenter_3IS7_NS_24Surface_mesh_cell_base_3IS7_NS_25Triangulation_cell_base_3IS7_NS_28Triangulation_ds_cell_base_3IvEEEEEEEEE13create_star_3ENS_8internal11CC_iteratorINS_17Compact_containerINS1_IS7_NS8_IS7_NS9_ISL_EEEEEENS_7DefaultEEELb0EEENSN_INSO_INSD_IS7_NSE_IS7_NSF_IS7_NSG_ISL_EEEEEEEESS_EELb0EEEii[CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > >::create_star_3(CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > >, CGAL::Default>, false>, CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > > >, CGAL::Default>, false>, int, int)]+0x294): undefined reference to `boost::detail::get_tss_data(void const*)'
mexfile.cpp:(.text._ZN4CGAL30Triangulation_data_structure_3INS_26Surface_mesh_vertex_base_3INS_28Robust_circumcenter_traits_3INS_15Filtered_kernelINS_16Simple_cartesianIdEELb1EEEEENS_27Triangulation_vertex_base_3IS7_NS_30Triangulation_ds_vertex_base_3IvEEEEEENS_43Triangulation_cell_base_with_circumcenter_3IS7_NS_24Surface_mesh_cell_base_3IS7_NS_25Triangulation_cell_base_3IS7_NS_28Triangulation_ds_cell_base_3IvEEEEEEEEE13create_star_3ENS_8internal11CC_iteratorINS_17Compact_containerINS1_IS7_NS8_IS7_NS9_ISL_EEEEEENS_7DefaultEEELb0EEENSN_INSO_INSD_IS7_NSE_IS7_NSF_IS7_NSG_ISL_EEEEEEEESS_EELb0EEEii[CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > >::create_star_3(CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > >, CGAL::Default>, false>, CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > > >, CGAL::Default>, false>, int, int)]+0x304): undefined reference to `boost::detail::get_tss_data(void const*)'
mexfile.cpp:(.text._ZN4CGAL30Triangulation_data_structure_3INS_26Surface_mesh_vertex_base_3INS_28Robust_circumcenter_traits_3INS_15Filtered_kernelINS_16Simple_cartesianIdEELb1EEEEENS_27Triangulation_vertex_base_3IS7_NS_30Triangulation_ds_vertex_base_3IvEEEEEENS_43Triangulation_cell_base_with_circumcenter_3IS7_NS_24Surface_mesh_cell_base_3IS7_NS_25Triangulation_cell_base_3IS7_NS_28Triangulation_ds_cell_base_3IvEEEEEEEEE13create_star_3ENS_8internal11CC_iteratorINS_17Compact_containerINS1_IS7_NS8_IS7_NS9_ISL_EEEEEENS_7DefaultEEELb0EEENSN_INSO_INSD_IS7_NSE_IS7_NSF_IS7_NSG_ISL_EEEEEEEESS_EELb0EEEii[CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > >::create_star_3(CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > >, CGAL::Default>, false>, CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > > >, CGAL::Default>, false>, int, int)]+0x346): undefined reference to `boost::detail::set_tss_data(void const*, boost::shared_ptr<boost::detail::tss_cleanup_function>, void*, bool)'
mexfile.cpp:(.text._ZN4CGAL30Triangulation_data_structure_3INS_26Surface_mesh_vertex_base_3INS_28Robust_circumcenter_traits_3INS_15Filtered_kernelINS_16Simple_cartesianIdEELb1EEEEENS_27Triangulation_vertex_base_3IS7_NS_30Triangulation_ds_vertex_base_3IvEEEEEENS_43Triangulation_cell_base_with_circumcenter_3IS7_NS_24Surface_mesh_cell_base_3IS7_NS_25Triangulation_cell_base_3IS7_NS_28Triangulation_ds_cell_base_3IvEEEEEEEEE13create_star_3ENS_8internal11CC_iteratorINS_17Compact_containerINS1_IS7_NS8_IS7_NS9_ISL_EEEEEENS_7DefaultEEELb0EEENSN_INSO_INSD_IS7_NSE_IS7_NSF_IS7_NSG_ISL_EEEEEEEESS_EELb0EEEii[CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > >::create_star_3(CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > >, CGAL::Default>, false>, CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<CGAL::Triangulation_data_structure_3<CGAL::Surface_mesh_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_vertex_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_vertex_base_3<void> > >, CGAL::Triangulation_cell_base_with_circumcenter_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Surface_mesh_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_cell_base_3<CGAL::Robust_circumcenter_traits_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Triangulation_ds_cell_base_3<void> > > > > > > > >, CGAL::Default>, false>, int, int)]+0x3a1): undefined reference to `boost::detail::get_tss_data(void const*)'
mexfile.o: In function `CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::coplanar_orientationC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)':
mexfile.cpp:(.text._ZN4CGAL22coplanar_orientationC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::coplanar_orientationC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0xb3): undefined reference to `__gmpq_cmp'
mexfile.cpp:(.text._ZN4CGAL22coplanar_orientationC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::coplanar_orientationC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0xc7): undefined reference to `__gmpq_cmp'
mexfile.o: In function `CGAL::Gmpq CGAL::determinant<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)':
mexfile.cpp:(.text._ZN4CGAL11determinantINS_4GmpqEEET_RKS2_S4_S4_S4_S4_S4_S4_S4_S4_[CGAL::Gmpq CGAL::determinant<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x23a): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL11determinantINS_4GmpqEEET_RKS2_S4_S4_S4_S4_S4_S4_S4_S4_[CGAL::Gmpq CGAL::determinant<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x265): undefined reference to `__gmpq_add'
mexfile.o: In function `CGAL::Gmpq CGAL::determinant<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)':
mexfile.cpp:(.text._ZN4CGAL11determinantINS_4GmpqEEET_RKS2_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_[CGAL::Gmpq CGAL::determinant<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x3f1): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL11determinantINS_4GmpqEEET_RKS2_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_[CGAL::Gmpq CGAL::determinant<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x420): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL11determinantINS_4GmpqEEET_RKS2_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_[CGAL::Gmpq CGAL::determinant<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x5a2): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL11determinantINS_4GmpqEEET_RKS2_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_[CGAL::Gmpq CGAL::determinant<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x5d1): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL11determinantINS_4GmpqEEET_RKS2_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_[CGAL::Gmpq CGAL::determinant<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x753): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL11determinantINS_4GmpqEEET_RKS2_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_[CGAL::Gmpq CGAL::determinant<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x786): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL11determinantINS_4GmpqEEET_RKS2_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_[CGAL::Gmpq CGAL::determinant<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x90e): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL11determinantINS_4GmpqEEET_RKS2_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_[CGAL::Gmpq CGAL::determinant<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x93d): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL11determinantINS_4GmpqEEET_RKS2_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_[CGAL::Gmpq CGAL::determinant<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0xae0): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL11determinantINS_4GmpqEEET_RKS2_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_[CGAL::Gmpq CGAL::determinant<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0xb0f): undefined reference to `__gmpq_add'
mexfile.o: In function `CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)':
mexfile.cpp:(.text._ZN4CGAL25side_of_oriented_sphereC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0xcd): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL25side_of_oriented_sphereC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0xfc): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL25side_of_oriented_sphereC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x178): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL25side_of_oriented_sphereC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x1a1): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL25side_of_oriented_sphereC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x32f): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL25side_of_oriented_sphereC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x35e): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL25side_of_oriented_sphereC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x3dd): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL25side_of_oriented_sphereC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x40c): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL25side_of_oriented_sphereC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x5aa): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL25side_of_oriented_sphereC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x5d9): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL25side_of_oriented_sphereC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x658): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL25side_of_oriented_sphereC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x687): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL25side_of_oriented_sphereC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x825): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL25side_of_oriented_sphereC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x856): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL25side_of_oriented_sphereC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x8d5): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL25side_of_oriented_sphereC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_4SignET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Sign, CGAL::Gmpq>::type CGAL::side_of_oriented_sphereC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x906): undefined reference to `__gmpq_add'
mexfile.o: In function `CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)':
mexfile.cpp:(.text._ZN4CGAL33coplanar_side_of_bounded_circleC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_12Bounded_sideET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0xbc): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL33coplanar_side_of_bounded_circleC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_12Bounded_sideET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0xeb): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL33coplanar_side_of_bounded_circleC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_12Bounded_sideET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x167): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL33coplanar_side_of_bounded_circleC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_12Bounded_sideET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x190): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL33coplanar_side_of_bounded_circleC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_12Bounded_sideET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x31a): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL33coplanar_side_of_bounded_circleC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_12Bounded_sideET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x349): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL33coplanar_side_of_bounded_circleC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_12Bounded_sideET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x3c8): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL33coplanar_side_of_bounded_circleC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_12Bounded_sideET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x3f7): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL33coplanar_side_of_bounded_circleC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_12Bounded_sideET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x598): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL33coplanar_side_of_bounded_circleC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_12Bounded_sideET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x5c7): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL33coplanar_side_of_bounded_circleC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_12Bounded_sideET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x646): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL33coplanar_side_of_bounded_circleC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_12Bounded_sideET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0x676): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL33coplanar_side_of_bounded_circleC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_12Bounded_sideET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0xa31): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL33coplanar_side_of_bounded_circleC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_12Bounded_sideET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0xa60): undefined reference to `__gmpq_add'
mexfile.cpp:(.text._ZN4CGAL33coplanar_side_of_bounded_circleC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_12Bounded_sideET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0xadf): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZN4CGAL33coplanar_side_of_bounded_circleC3INS_4GmpqEEENS_19Same_uncertainty_ntINS_12Bounded_sideET_E4typeERKS4_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_S8_[CGAL::Same_uncertainty_nt<CGAL::Bounded_side, CGAL::Gmpq>::type CGAL::coplanar_side_of_bounded_circleC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&)]+0xb0e): undefined reference to `__gmpq_add'
mexfile.o: In function `CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const':
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors22Coplanar_orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_EENS_4SignERKT_RKT0_RKT1_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x1eb): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors22Coplanar_orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_EENS_4SignERKT_RKT0_RKT1_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x212): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors22Coplanar_orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_EENS_4SignERKT_RKT0_RKT1_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x24d): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors22Coplanar_orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_EENS_4SignERKT_RKT0_RKT1_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x273): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors22Coplanar_orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_EENS_4SignERKT_RKT0_RKT1_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x2ad): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors22Coplanar_orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_EENS_4SignERKT_RKT0_RKT1_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x2d0): undefined reference to `__gmpq_set_d'
mexfile.o: In function `CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const':
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x1b9): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x1df): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x21d): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x243): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x27d): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x2a0): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x348): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x36e): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x3ab): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x3d2): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x411): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x43a): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x4ea): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x516): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x558): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x584): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x5c6): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x5f0): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x6b2): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x6de): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x720): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x74c): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x78d): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors13Orientation_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_4SignERKT_RKT0_RKT1_RKT2_[CGAL::Sign CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Orientation_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x7b6): undefined reference to `__gmpq_set_d'
mexfile.o: In function `CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const':
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x1c0): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x1e6): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x224): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x24d): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x288): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x2ab): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x356): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x37d): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x3bb): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x3e2): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x421): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x44a): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x4fa): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x526): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x568): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x594): undefined reference to `__gmpq_set_d'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x5d6): undefined reference to `__gmpq_init'
mexfile.cpp:(.text._ZNK4CGAL18Filtered_predicateINS_23CartesianKernelFunctors33Coplanar_side_of_bounded_circle_3INS_16Simple_cartesianINS_4GmpqEEEEENS2_INS3_INS_11Interval_ntILb0EEEEEEENS_19Cartesian_converterINS_21Type_equality_wrapperINS_27Cartesian_base_no_ref_countIdNS_15Filtered_kernelINS3_IdEELb1EEEEESG_EES5_NS_12NT_converterIdS4_EEEENSB_ISI_S9_NSJ_IdS8_EEEELb1EEclINS_7Point_3ISG_EESR_SR_SR_EENS_12Bounded_sideERKT_RKT0_RKT1_RKT2_[CGAL::Bounded_side CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Gmpq> >, CGAL::CartesianKernelFunctors::Coplanar_side_of_bounded_circle_3<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq> >, CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >, true>::operator()<CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > >(CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&, CGAL::Point_3<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const]+0x600): undefined reference to `__gmpq_set_d'
collect2: ld returned 1 exit status
mex: link of ' "mexfile.mexa64"' failed.
// Huayi Wei, <> #include <CGAL/Surface_mesh_default_triangulation_3.h> #include <iostream> #include <fstream> #include <list> #include <set> #include <vector> #include "matrix.h" #include "mex.h" // default triangulation for Surface_mesher typedef CGAL::Surface_mesh_default_triangulation_3 Delaunay3d; typedef Delaunay3d::Finite_vertices_iterator Vit; typedef Delaunay3d::Cell_handle Cell_handle; typedef Delaunay3d::Vertex_handle Vertex_handle; typedef Delaunay3d::Facet Facet; typedef Delaunay3d::Edge Edge; typedef Delaunay3d::Triangle Triangle; typedef Delaunay3d::Geom_traits GT; typedef GT::Point_3 Point_3; typedef GT::Vector_3 Vector_3; typedef GT::FT FT; void mexFunction(int nlhs, mxArray* plhs[], int nrhs, mxArray *prhs[]){ /* Check for proper number of input and output arguments */ if (nrhs != 1) { mexErrMsgTxt("we need one input of generators!"); } if(nlhs > 2){ mexErrMsgTxt("Too many output arguments."); } mwIndex offset; mxArray * generator_on_sphere = prhs[0]; mwSize number_of_generator = mxGetM(generator_on_sphere); std::vector<Point_3> points; double * pg_on_sphere = mxGetPr(generator_on_sphere); for(int i = 0; i < number_of_generator; i++){ int subs[2]; subs[0]=i; subs[1]=0; offset = mxCalcSingleSubscript(generator_on_sphere,2,subs); double x = pg_on_sphere[offset]; subs[1]=1; offset = mxCalcSingleSubscript(generator_on_sphere,2,subs); double y = pg_on_sphere[offset]; subs[1]=2; offset = mxCalcSingleSubscript(generator_on_sphere,2,subs); double z = pg_on_sphere[offset]; points.push_back(Point_3(x,y,z)); } //produce the delaunay triangulation Delaunay3d D3d(points.begin(),points.end()); //compute the circumcenter of the facet on the sphere surface std::map<Facet,int> facets_map; std::vector<Point_3> circumcenters; int count = 0; std::vector<Cell_handle> all_infinite_cells; D3d.incident_cells( D3d.infinite_vertex(), std::back_inserter(all_infinite_cells)); std::vector<Cell_handle>::iterator cit = all_infinite_cells.begin(); for( ;cit != all_infinite_cells.end(); cit++){ int idx =(*cit)->index(D3d.infinite_vertex()); Facet facet = Facet(*cit,idx); facets_map[facet]=count; Triangle t = D3d.triangle(facet); Point_3 p = CGAL::circumcenter(t); FT r = CGAL::sqrt(p.x()*p.x()+p.y()*p.y()+p.z()*p.z()); circumcenters[count] = Point_3(p.x()/r,p.y()/r,p.z()/r); count ++; } //construct the voronoi diagram std::vector<Edge> all_infinite_edges; std::vector<std::list<int> > voronoi_cells; D3d.incident_edges(D3d.infinite_vertex(),std::back_inserter(all_infinite_edges)); std::vector<Edge>::iterator eit = all_infinite_edges.begin(); for(;eit != all_infinite_edges.end(); eit++){ std::list<int> idx_of_voronoi_vertices; Cell_handle cell = (*eit).first; int i = (*eit).second; int j = (*eit).third; Vertex_handle v1, v2;// v1 is the finite vertex and v2 the infinite vertex of edge *eit if (D3d.is_infinite(cell->vertex(i))){ v1 = cell->vertex(j); v2 = cell->vertex(i); }else{ v1 = cell->vertex(i); v2 = cell->vertex(j); } Delaunay3d::Cell_circulator ccir = D3d.incident_cells(*eit); Delaunay3d::Cell_circulator ccir_begin = ccir; bool flag = true; while(true){ Delaunay3d::Cell_circulator ccir_tmp = ccir++; int k1 = ccir_tmp->index(v1); int k2 = ccir_tmp->index(v2); idx_of_voronoi_vertices.push_back(facets_map[Facet(ccir_tmp,k2)]); if(flag) for( int j =0; j < 3; j++){ if(k1 == D3d.vertex_triple_index(k2,j)){ j = (j+2)%3; if(ccir_tmp->neighbor(D3d.vertex_triple_index(k2,j))==ccir) flag = false; } } if( ccir == ccir_begin) break; } if(!flag) idx_of_voronoi_vertices.reverse(); voronoi_cells.push_back(idx_of_voronoi_vertices); } // set the return data: cell mxArray *cell_matrix = mxCreateCellMatrix((mwSize)number_of_generator,1); for(int i = 0; i < number_of_generator; i++){ int n = voronoi_cells[i].size(); mxArray * mxcell = mxCreateDoubleMatrix((mwSize)n,1, mxREAL); double * ptr = mxGetPr(mxcell); std::list<int>::iterator it; int j = 0; for(it = voronoi_cells[i].begin(); it != voronoi_cells[i].end(); it++) ptr[j++]=*it; mxSetCell(cell_matrix,i,mxcell); } // voronoi vertex mxArray * voronoi_vertices_matrix = mxCreateDoubleMatrix((mwSize)count,3, mxREAL); double * ptr_vv = mxGetPr(voronoi_vertices_matrix); for(int i = 0; i < count; i++){ int subs[2]; subs[0]=i; subs[1]=0; offset = mxCalcSingleSubscript(voronoi_vertices_matrix,2,subs); ptr_vv[offset] = circumcenters[i].x(); subs[0]=i; subs[1]=1; offset = mxCalcSingleSubscript(voronoi_vertices_matrix,2,subs); ptr_vv[offset] = circumcenters[i].y(); subs[0]=i; subs[1]=2; offset = mxCalcSingleSubscript(voronoi_vertices_matrix,2,subs); ptr_vv[offset] = circumcenters[i].z(); } plhs[0] = voronoi_vertices_matrix; plhs[1] = cell_matrix; }
- [cgal-discuss] how to compile mex-file based on CGAL in Matlab, 魏华祎, 03/13/2011
- Re: [cgal-discuss] how to compile mex-file based on CGAL in Matlab, Joachim Reichel, 03/14/2011
- Re: [cgal-discuss] how to compile mex-file based on CGAL in Matlab, 魏华祎, 03/14/2011
- Re: [cgal-discuss] how to compile mex-file based on CGAL in Matlab, Sylvain Pion, 03/14/2011
- Re: [cgal-discuss] how to compile mex-file based on CGAL in Matlab, avaxman, 03/14/2011
