cgal-discuss - Re: [cgal-discuss] 3D model orientation
  • To:
  • Subject: Re: [cgal-discuss] 3D model orientation
  • Date: Mon, 14 Mar 2011 08:53:26 +0100
serg.healthy wrote:
Sorry for my bad english.
I have a lot of 3D models of buildings (more than two thousand) that must be
placed on a map of city (in 3D engine). I know position of each model but
not the angle of model orientation. Also I know 2D polygon which corresponds
to the model. Orient a thousands of models by hand is too time-consuming, so
I would like to somehow automate.
How can i solve this problem?
3D model of building
http://cgal-discuss.949826.n4.nabble.com/file/n3348109/building.png
2d polygon which should stand model
http://cgal-discuss.949826.n4.nabble.com/file/n3348109/polygon.jpg
I think to calc 2D projection of a model and then consistently turning the
projection relative to the initial polygon to find the angle with the
maximum overlap area.
Now I try to solve first part of problem - find 2D projection of 3D model.
When projecting I want to take into account only the walls of buildings, so
take into account only the triangles whose normal is parallel to the ground.
But I can't get simple polygon from this projection.
Put each edge into a constrained triangulation and then extract edges
that are accessible from outside by using a union-find procedure
on 2D triangles; 2 triangles being in the same component if they share
a non-constrained edge.
Have a look at the constrained triangulation here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Section_35.8
and Union-find here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Miscellany/Chapter_main.html#Section_76.5
Can't you simply have the contour by considering edges with points at
say z=0?
S.
Convex Hull algo i think not suitable. Now I look at http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Envelope_2/Chapter_main.html
Envelopes of Curves in 2D and try to understand it.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-model-orientation-tp3348109p3348109.html
