- To:
- Subject: Re: [cgal-discuss] Mesh local differential properties
- Date: Wed, 16 Mar 2011 10:30:20 +0100
Hi, On Mar 3, 2011, at 11:13 AM, Asher Kamiraze wrote: Hi all,
Use instead the option -vtrue to get a human readable result, then you may want to modify the output to visualize it with your favorite tool (Now what is becoming the recommended visu tool for cgal is QGLViewer. I've never used it but it is qt and opengl based so standart and you can find demo code, for polyhedron for instance Hope this help best MArc
- [cgal-discuss] Mesh local differential properties, Asher Kamiraze, 03/03/2011
- [cgal-discuss] Re: Mesh local differential properties, Asher Kamiraze, 03/08/2011
- Re: [cgal-discuss] Mesh local differential properties, Marc Pouget, 03/16/2011
