- To:
- Subject: [cgal-discuss] Re: Mesh local differential properties
- Date: Tue, 8 Mar 2011 08:54:03 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=YDAXIPzFrdOxnDixFz6TX/qcEXjpSnv9+Jk6XKv/d/boVrpZRXobsPRXrpt0rJuIuY XeKp6+GcJv7zx9orLVLDKe+eJbvasEy9KWFIycQFLY1lfKsDmCovvkj13T2Cbxkl9LSB zaUO+umgTtLIPw3P8X0qyOrhSvS5JeglWHJ8Y=
Hi all,
No one on that point ?
Regards,
Asher
2011/3/3 Asher Kamiraze <>
Hi all,I am trying to use the mesh local differential properties on a mesh (on a windows 7 / 64 bit), and I have a few questions.1) When I execute the sample program (with the default parameters), I get (a lot of) errors on the console: "MKL ERROR: Parameter 12 was incorrect on entry to DGELSS"2) The file xxx.4ogl.txt is created. How can I view it?Hope you could help.Best regards,Asher
PS : windows 7 / 64 bit, VC++ 2010, CGAL 3.7
- [cgal-discuss] Mesh local differential properties, Asher Kamiraze, 03/03/2011
- [cgal-discuss] Re: Mesh local differential properties, Asher Kamiraze, 03/08/2011
- Re: [cgal-discuss] Mesh local differential properties, Marc Pouget, 03/16/2011
