- To:
- Subject: Re: [cgal-discuss] Accuracy Issues
- Date: Mon, 21 Mar 2011 08:34:13 +0100
A nef polyhedron is made of planar facets, so if you provide a face with 4 vertices, these vertices must exactly lie in a plane.
If you use only triangular facets, then you will not have such issues.
S.
S K BOSE wrote:
Hi,
I have some problem regarding accuracy issues. I am using CGAL::Gmpq
For example in the following sample program
#include <fstream>
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/Nef_polyhedron_3.h>
#include <CGAL/Nef_3/SNC_indexed_items.h>
#include <CGAL/IO/Polyhedron_iostream.h>
typedef CGAL::Exact_predicates_exact_constructions_kernel kernel; typedef CGAL::Polyhedron_3<kernel> Polyhedron_3; typedef CGAL::SNC_indexed_items Items;
typedef CGAL::Nef_polyhedron_3<kernel,Items> Nef_polyhedron; using namespace std;
int main() { Polyhedron_3 model; fstream file; file.open("test.off"); if (!file.is_open()) { return 0; } file>>model; file.close(); Nef_polyhedron poly(model); return 0; }
If I used
OFF
6 5 0
-0.5 -0.5 0.0
0.5 -0.5 0
-0.5 0.25 0.433012
0.5 0.25 0.433012
-0.5 0.25 -0.433012
0.5 0.25 -0.433012
4 0 1 3 2
4 2 3 5 4
4 4 5 1 0
3 0 2 4
3 5 3 1
Nef_polyhedron conversion is going through. But if I used following Dataset
OFF
6 5 0
-0.49999999999999989 -0.50000000000000011 0.0
0.50000000000000011 -0.49999999999999999 0
-0.50000000000000011 0.25000000011841639 0.43301270182385149
0.49999999999999994 0.25000000000011841661 0.43301270182385149
-0.5 0.24999999976316684 -0.43301270202895492
0.49999999999999994 0.24999999976316706 -0.43301270202895492
4 0 1 3 2
4 2 3 5 4
4 4 5 1 0
3 0 2 4
3 5 3 1
I am facing problem while Nef_polyhedron conversion. This is possibly run
into accuracy issues. It gives
CGAL error: assertion violation!
Expression : pe_prev->is_border() || pe_prev->facet()->plane().
has_on(pe_prev->
opposite()->vertex()->point())
File : D:\DRIVE D\CGAL\include\CGAL/Nef_3/polyhedron_3_to_nef_3.h
Line : 219
I am using Microsoft Visual C++ 2008, 32 bit version. Please can anybody
point me the portion of the code, where I can tune the related parameters
which deals with accuracy so that both datasets will go through.
With Regards,
Bose
- [cgal-discuss] Accuracy Issues, S K BOSE, 03/21/2011
- Re: [cgal-discuss] Accuracy Issues, Sebastien Loriot (GeometryFactory), 03/21/2011
