[cgal-discuss] the problem when inserted line feature in to Mesh_domain_with_polyline_features_3
- To:
- Subject: [cgal-discuss] the problem when inserted line feature in to Mesh_domain_with_polyline_features_3
- Date: Mon, 21 Mar 2011 15:01:51 +0100 (CET)
I tried to use the CGAL 3.8 beta to generate 3D mesh for two polyhedral
surfaces. There is a intersected line of the two surfaces, and the code I used
is as below:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Mesh_3::Robust_intersection_traits_3<K> Geom_traits;
typedef CGAL::Polyhedron_3<Geom_traits> Polyhedron;
typedef CGAL::Mesh_domain_with_polyline_features_3<
CGAL::Polyhedral_mesh_domain_3<Polyhedron, Geom_traits> >
MD_IntersectedLines;
typedef CGAL::Mesh_triangulation_3<MD_IntersectedLines>::type Tr_MDI;
typedef CGAL::Mesh_criteria_3<Tr_MDI> Mesh_criteria_MDI;
typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr_MDI,
MD_IntersectedLines::Corner_index,MD_IntersectedLines::Curve_segment_index>
C3t3_MDI;
typedef K::Point_3 PointK;
typedef std::vector<PointK> InterPolyline;
typedef std::list<InterPolyline> InterPolylines;
int main()
std::vector<Polyhedron*> AllSurfaces;
Polyhedron bounding_box;
//constructing bounding_box
bounding_box.make_triangle(...); //use triangular mesh as bouding box
polyhedron;
//constructing surfaces
Polyhedron *pNewPolyhedron1 = new Polyhedron;
pNewPolyhedron1->make_triangle(...);
AllSurfaces.push_back(pNewPolyhedron1);
Polyhedron *pNewPolyhedron2 = new Polyhedron;
pNewPolyhedron2->make_triangle(...);
AllSurfaces.push_back(pNewPolyhedron2);
//constructing intersection line
InterPolylines interPolySet;
InterPolyline newEdge;
newEdge.push_back(PointK(pVertex_0->x, pVertex_0->y, pVertex_0->z));
newEdge.push_back(PointK(pVertex_n->x, pVertex_n->y, pVertex_n->z));
interPolySet.push_back(newEdge);
MD_IntersectedLines domain(AllSurfaces.begin(), AllSurfaces.end(),
bounding_box);
domain.add_features(interPolySet.begin(), interPolySet.end());
Mesh_criteria_MDI criteria(facet_angle=20, cell_size=300,
facet_topology = CGAL::FACET_VERTICES_ON_SURFACE);
C3t3_MDI c3t3 = CGAL::make_mesh_3<C3t3_MDI>(domain, criteria);
I compiled the code under VS2008 sucessfully. But when I run, there is an
error
happened at the line "domain.add_features(interPolySet.begin(),
interPolySet.end())", this error is an exception as descripted as below:
Unhandled exception at 0x759e9617 in xx.exe: Microsoft C++ exception:
CGAL::Precondition_exception at memory location 0x0028cec8..
Without this line of add_feature, the code work well but the line featrue
didn't keep in the 3D mesh. And the similar example:
"examples/Mesh_3/mesh_two_implicit_spheres_with_balls.cpp" also can work well
on my computer.
So are there some incorrect part in my code or some special requirement on the
input of intersection line?
- [cgal-discuss] the problem when inserted line feature in to Mesh_domain_with_polyline_features_3, xianhai meng, 03/21/2011
- [cgal-discuss] Re: the problem when inserted line feature in to Mesh_domain_with_polyline_features_3, neman, 03/22/2011
- Re: [cgal-discuss] Re: the problem when inserted line feature in to Mesh_domain_with_polyline_features_3, Laurent Rineau (GeometryFactory), 03/23/2011
