- To:
- Subject: Re: [cgal-discuss] Error while profiling
- Date: Mon, 28 Mar 2011 12:17:39 +0200
Can you at least describe in which context it happened?
I mean is it while using directly the compact container or when using a cgal package ? If so which package?
S.
Panagiotis Foteinos wrote:
Hello.
I attempted to profile my code (built on top of CGAL) using GNU gprof, and I got the following error (after a long time...):
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: DSC::type(m_ptr.p) == DSC::USED
File: /scratch/local/src/CGAL-3.7/include/CGAL/Compact_container.h
Line: 825
Explanation: Incrementing an invalid iterator.
Aborted
Has anybody else encountered the same problem? Is this because the program runs out of memory? Any guesses?
Sadly, I cannot provide a minimal example. My sincere apologies.
Regards,
Panagiotis Foteinos
- [cgal-discuss] Error while profiling, Panagiotis Foteinos, 03/15/2011
- Re: [cgal-discuss] Error while profiling, Sebastien Loriot (GeometryFactory), 03/28/2011
