- To:
- Subject: Re: [cgal-discuss] 2D point sets and Boost Graph
- Date: Mon, 28 Mar 2011 15:11:16 +0200
Hello Mattia,
Conceptually I have a problem defining a graph on a data structure which
is documented as a point set on which you can do queries. I mean that
there is no notion of graph on the structure, whereas there is an
obvious one on triangulation.
Can you try using the following specialization of graph_traits boost::graph_traits<Point_set<Gt,Tds>::Base> instead of
boost::graph_traits<Point_set<Gt,Tds> > in your code and tell us whether
it is working?
I know that Base is not documented, I will investigate why.
S.
mattia.penati wrote:
I'm working with the package "2D Range and Neighbor Search" and I think it
could be a good idea to interface this package with Boost Graph. Currently
you could not use the structure Point_set_2 with Boost Graph although it is
a Delaunay_triangulation_2. For this reason I write my own header (attached
to this message) for this purpose. It's quite simple to use, it must be
copied inside CGAL/boost/graph directory.
http://cgal-discuss.949826.n4.nabble.com/file/n3356516/graph_traits_Point_set_2.h
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/2D-point-sets-and-Boost-Graph-tp3356516p3356516.html
- [cgal-discuss] 2D point sets and Boost Graph, mattia.penati, 03/15/2011
- Re: [cgal-discuss] 2D point sets and Boost Graph, Sebastien Loriot (GeometryFactory), 03/28/2011
- Re: [cgal-discuss] 2D point sets and Boost Graph, Mattia Penati, 03/28/2011
