- To:
- Subject: Re: [cgal-discuss] 2D point sets and Boost Graph
- Date: Mon, 28 Mar 2011 17:23:25 +0200
Mattia Penati wrote:
On 28 March 2011 15:11, Sebastien Loriot (GeometryFactory)My answer was related to the fact that I was not enthusiast to add
wrote:
Hello Mattia,
Conceptually I have a problem defining a graph on a data structure which
is documented as a point set on which you can do queries. I mean that
there is no notion of graph on the structure, whereas there is an
obvious one on triangulation.
I completely agree with you about the fact that a point set doesn't
define a graph, but there are some applications where this definition
is implicit. Currently I'm working on a problem in which I need to do
geometric queries and to construct the Euclidean minimum spanning tree
(EMSP) of a 2D point set. To define the EMST obviously you need a
graph, but it's the complete graph given by points, so it's quite
useless to describe each edge. And the algorithm to construct the EMST
use the fact that EMST is a subgraph of Delaunay triangulation.
the graph_traits specialization and document it, because as you said you
are using the underlying Delaunay triangulation. Hopefully your code
works with the Delaunay specialization (up to documentation problem).
Thanks for your feedback.
Can you try using the following specialization of graph_traits
boost::graph_traits<Point_set<Gt,Tds>::Base> instead of
boost::graph_traits<Point_set<Gt,Tds> > in your code and tell us whether
it is working?
Yes.
- [cgal-discuss] 2D point sets and Boost Graph, mattia.penati, 03/15/2011
- Re: [cgal-discuss] 2D point sets and Boost Graph, Sebastien Loriot (GeometryFactory), 03/28/2011
- Re: [cgal-discuss] 2D point sets and Boost Graph, Mattia Penati, 03/28/2011
