cgal-discuss - Re: [cgal-discuss] how to extend kd-tree to range-query user defined point?
  • To:
  • Subject: Re: [cgal-discuss] how to extend kd-tree to range-query user defined point?
  • Date: Wed, 30 Mar 2011 17:45:33 +0200
yanyajie wrote:
> ?Dear S,
> I see. Just to be sure: practiacally I need to provide a new query item
> (box or sphere), my new point type, and wrap them in a new SearchTraits,
> right?
Not a new fuzzy object, as you can provide your traits as
template parameter to CGAL::Fuzzy_sphere and CGAL::Fuzzy_iso_box.
you simply need to define
struct Search_traits_with_my_point{
typedef XXX Cartesian_const_iterator_d;
typedef XXX Construct_cartesian_const_iterator_d;
typedef XXX Point_d;
typedef XXX Iso_box_d;
typedef XXX Sphere_d;
typedef XXX Construct_iso_box_d;
typedef XXX Construct_min_vertex_d;
typedef XXX Construct_max_vertex_d;
typedef XXX Construct_center_d;
typedef XXX Compute_squared_radius_d;
typedef XXX FT;
For the details see:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching_ref/Concept_SearchTraits.html
S.
> Yan.
> -----原始邮件----- From: Sebastien Loriot (GeometryFactory)
> Sent: Wednesday, March 30, 2011 8:42 PM
> To:
> defined point?
> There is a bug in the documentation we are aware of and that should be
> fixed in the 3.9 release. Search_traits is not a real model of the
> SearchTraits concept as it cannot be used for range-search queries.
> It should not be hard to define your own traits class using this concept
> page:
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching_ref/Concept_SearchTraits.html#Cross_link_anchor_1634
> For a concise view you can also have a look at
> include/CGAL/Search_traits_2.h (which simply contains types that
> need to be defined)
> Basically you simply have to define more functors than in the example
> here:
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching/Chapter_main.html#Subsection_59.3.5
> S.
> yanyajie wrote:
>> Hi,
>> I have a specific point type, known as surfel. I would like to build a
>> kd-tree for a bunch of surfels and to do range-query specified by a
>> sphere queryitem. How can I extend the kd-tree to achieve my goal?
>> I examined the search() routine in kd_tree_node.h and found kd_tree
>> heavily rely on the query item’s contains() member to do actual query.
>> Does that mean all I have to do is just implement my own extended
>> version of query item, like a sphere, so that it can determine whether
>> or not a surfel is contained in? Or do I have to provide another
>> distance class as exemplified in the example?
>> Really need some help here. Thanks in advance!!!
>> Yan.
>> * The State Key Labratory of Virtual Reality and Technology
>> * School of Computer Science and Engineering
>> * Beijing University Aeronautics and Astronautics (Beihang Univ.)
