cgal-discuss - Re: [cgal-discuss] how to extend kd-tree to range-query user defined point?
  • To: <>
  • Subject: Re: [cgal-discuss] how to extend kd-tree to range-query user defined point?
  • Date: Thu, 31 Mar 2011 00:02:12 +0800
  • Importance: Normal
?But how can the existing fuzzy object know if it contains my point or not? Isn't there supposed to be some new "bool contain(PointType p)" which does this?
-----原始邮件----- From: Sebastien Loriot (GeometryFactory)
Sent: Wednesday, March 30, 2011 11:45 PM
To:
yanyajie wrote:
?Dear S,
I see. Just to be sure: practiacally I need to provide a new query item
(box or sphere), my new point type, and wrap them in a new SearchTraits,
right?
Not a new fuzzy object, as you can provide your traits as
template parameter to CGAL::Fuzzy_sphere and CGAL::Fuzzy_iso_box.
you simply need to define
struct Search_traits_with_my_point{
typedef XXX Cartesian_const_iterator_d;
typedef XXX Construct_cartesian_const_iterator_d;
typedef XXX Point_d;
typedef XXX Iso_box_d;
typedef XXX Sphere_d;
typedef XXX Construct_iso_box_d;
typedef XXX Construct_min_vertex_d;
typedef XXX Construct_max_vertex_d;
typedef XXX Construct_center_d;
typedef XXX Compute_squared_radius_d;
typedef XXX FT;
For the details see:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching_ref/Concept_SearchTraits.html
S.
Yan.
Sent: Wednesday, March 30, 2011 8:42 PM
To:
defined point?
There is a bug in the documentation we are aware of and that should be
fixed in the 3.9 release. Search_traits is not a real model of the
SearchTraits concept as it cannot be used for range-search queries.
It should not be hard to define your own traits class using this concept
page:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching_ref/Concept_SearchTraits.html#Cross_link_anchor_1634
For a concise view you can also have a look at
include/CGAL/Search_traits_2.h (which simply contains types that
need to be defined)
Basically you simply have to define more functors than in the example
here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching/Chapter_main.html#Subsection_59.3.5
S.
yanyajie wrote:
Hi,
I have a specific point type, known as surfel. I would like to build a
kd-tree for a bunch of surfels and to do range-query specified by a
sphere queryitem. How can I extend the kd-tree to achieve my goal?
I examined the search() routine in kd_tree_node.h and found kd_tree
heavily rely on the query item’s contains() member to do actual query.
Does that mean all I have to do is just implement my own extended
version of query item, like a sphere, so that it can determine whether
or not a surfel is contained in? Or do I have to provide another
distance class as exemplified in the example?
Really need some help here. Thanks in advance!!!
Yan.
* The State Key Labratory of Virtual Reality and Technology
* School of Computer Science and Engineering
* Beijing University Aeronautics and Astronautics (Beihang Univ.)
