- To:
- Subject: [cgal-discuss] disable autolinking?
- Date: Thu, 31 Mar 2011 14:50:07 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=jbIyWc52ZBb8l9gmWusllwhCQbEIbDQbhx7TvsgJn4X2/TvFrFHrTDx9WYAY5gniGn yENiLMMW1ZQmJ7Gp9OKWwMoCoiPfXPyEDZnsTeSgvIro/LGWjuo5y1t85YphnQPd93Dj hEpmJnn1ugyYt3AT3kj4pcXw4PYF+eY0ycAdk=
I have compiled only one version of CGAL (RelWithDebInfo) and the library is named CGAL-vc100-mt-g.lib. But linking to CGAL from my app I get an error that CGAL-vc100-mt.lib is not found. Interestingly, defining CGAL_NO_AUTOLINK does not seem to disable this error. If I copy my lib under this name then he goes on in the same fashion about other libs (GMP, MPFR, ...) which I also compiled only once with RelWithDebInfo. Is it possible to disable CGAL autolinking or I am forced to use Release and Debug variants for CGAL and all its dependencies?
Thanks,
Dominik
- [cgal-discuss] disable autolinking?, Dominik Szczerba, 03/31/2011
- Re: [cgal-discuss] disable autolinking?, Laurent Rineau (GeometryFactory), 03/31/2011
- Re: [cgal-discuss] disable autolinking?, Dominik Szczerba, 03/31/2011
