cgal-discuss - Re: [cgal-discuss] disable autolinking?
  • To:
  • Subject: Re: [cgal-discuss] disable autolinking?
  • Date: Thu, 31 Mar 2011 21:19:01 +0200
Le jeudi 31 mars 2011 20:45:12, Dominik Szczerba a écrit :
> > This is the error reported during linking by Visual Studio:
> > Error 411 error LNK1104: cannot open file 'CGAL-vc100-mt.lib'
> > However, this name DOES NOT appear in the project dependencies
> > (project->properties), so it must be generated dynamically. I want to
> > link to CGAL-vc100-mt-g.lib, this one is in the dependencies, but is
> > ignored. This should not happen, because CGAL_NO_AUTOLINK is defined.
> > CGAL_LIB_DIAGNOSTIC is also defined, but "Linking to lib file:
> > CGAL_LIB_FULL_NAME" does not seem to be displayed, which means that it
> > is not auto_link.h that is causing this. Very weird.
> I found a possible reason: there is this line:
> /DEFAULTLIB:"CGAL-vc100-mt.lib"
Recompile the CGAL lib itself with CGAL_NO_AUTOLINK!
> So now I am "only" left with this error:
> Error 1 error LNK2005: _pRawDllMain already defined in
> mfcs100.lib(rawdllmainproxy.obj)
> E:\build\framework\trunk\vtkMy\Filtering\l
> ibboost_thread-vc100-mt-1_46_1.lib(tss_pe.obj)
> which according to google indicates the need to link with the DLL
> version of boost. This one, however, does not seem to be supported by
> CGAL/cmake, see the other thread of mine. Ideas how to solve it are
> most welcome.
No clue.
Laurent Rineau, PhD
