- To:
- Subject: Re: [cgal-discuss] create a offeset of polygons with circular arcs
- Date: Thu, 31 Mar 2011 17:45:40 +0200
Hi Markus,
there is a 2D Minkowski sum for polygons consisting
of linear and circular arcs in the making, but it is
not ready yet, and we don't want to make a commitment
for a release date.
Best regards,
Andreas
On 28/03/2011 10:24, Markus Plannerer wrote:
Hello,
I'm new to CGAL and found information about to create a offset of a
Polygon_2 with create_exterior_skeleton_and_offset_polygons_2. That works
fine but I need a offset from the combination of Polygon_2 with
Circular_arc_2. If You suppose to use Arrangement_2 with planar curves, is
there a offset function and how to convert back to polygons and circular
arcs.
Thanks for Your help,
Markus
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/create-a-offeset-of-polygons-with-circular-arcs-tp3411033p3411033.html
- [cgal-discuss] create a offeset of polygons with circular arcs, Markus Plannerer, 03/28/2011
- Re: [cgal-discuss] create a offeset of polygons with circular arcs, Andreas Fabri, 03/31/2011
