- To:
- Subject: Re: [cgal-discuss] Runtime library problem
- Date: Thu, 31 Mar 2011 18:58:13 +0200
Hi,
> I could compile my app with CGAL successfully, but when I run the program,
> it shows "_ZN4CGAL14assertion_failEPKcS1_iS1_". Does anyone have a clue
> about what's wrong? Thanks in advance.
can you provide a minimal test case? Which compiler/linker flags do you use?
What is your operating system? Do the demos/examples work for you?
Joachim
- [cgal-discuss] Runtime library problem, Zhongfu Zhou [zzz], 03/31/2011
- Re: [cgal-discuss] Runtime library problem, Joachim Reichel, 03/31/2011
