cgal-discuss - Re: [cgal-discuss] Re: polygon triangulation
  • To:
  • Subject: Re: [cgal-discuss] Re: polygon triangulation
  • Date: Tue, 19 Apr 2011 00:43:49 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=HjuNo415wVeykRtBj9V/FSM+vRzH1/u81hFeDQnI7+Su37e6/F3jd4ggCu5p6knmVy9yg6mnKKxFR9WAGZJDu+Pe+883iiXrjWgh4+Gxg+/8o6XZVjTMGOQdrSVlDAoQ1TzO9BHWESo+WhR+PPX5L4VkJm+7BSMN7SaAQVzr73U=;
Thanks for your help,
sorry, i cant understand the concept of "propagation from triangles to triangles", is it possible for you to explain it little clearer?
Thanks in advance.
To:
Date: Thursday, April 14, 2011, 6:59 AM
On 04/14/2011 05:32 AM, sara123 wrote:
> After reading the cgal manual (2D Triangulations) I realized that after
> constrained triangulation of a simple polygon we have eventually a convex
> polygon, even if our input polygon does'nt be convex!
Of course, it is computing a triangulation of the plane.
You have to filter out triangles that are outside you original polygon.
You can use a propagation from triangles to triangles, never crossing a
constrained edge. The simplest is to start with an infinite face and
get all faces that are not in the polygon.
S.
> what should i do if i want this does'nt happen?
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/polygon-triangulation-tp3356157p3448688.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
