- To:
- Subject: Re: [cgal-discuss] Re: polygon triangulation
- Date: Tue, 26 Apr 2011 10:23:16 +0200
sara Samadi wrote:
Thanks for your help,
sorry, i cant understand the concept of "propagation from triangles to triangles", is it possible for you to explain it little clearer?
CGAL 2D triangulations are triangulations of the whole 2D plane (thanks to the infinite vertex).
A polygon in the 2D plane is defined by a close sequence of segments,
separating the triangles of the plane into two sets: those that are inside the polygon, and those that are outside the polygon.
Given a triangle, we can recover the whole set the triangle belongs to
by walking from triangle to triangle, never crossing a constrained edge.
As documented here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/TDS_2_ref/Concept_TriangulationDataStructure_2--Face.html
given a facet f, the three neighbor triangles can be retrieved using
f.neighbor(i) for i=0, 1 and 2.
S.
Thanks in advance.
To:
Date: Thursday, April 14, 2011, 6:59 AM
On 04/14/2011 05:32 AM, sara123 wrote:
> After reading the cgal manual (2D Triangulations) I realized that
after
> constrained triangulation of a simple polygon we have eventually
a convex
> polygon, even if our input polygon does'nt be convex!
Of course, it is computing a triangulation of the plane.
You have to filter out triangles that are outside you original polygon.
You can use a propagation from triangles to triangles, never crossing a
constrained edge. The simplest is to start with an infinite face and
get all faces that are not in the polygon.
S.
> what should i do if i want this does'nt happen?
> View this message in context:
http://cgal-discuss.949826.n4.nabble.com/polygon-triangulation-tp3356157p3448688.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] Re: polygon triangulation, sara123, 04/14/2011
- Re: [cgal-discuss] Re: polygon triangulation, Sebastien Loriot (GeometryFactory), 04/14/2011
- Re: [cgal-discuss] Re: polygon triangulation, sara Samadi, 04/19/2011
- Re: [cgal-discuss] Re: polygon triangulation, Sebastien Loriot (GeometryFactory), 04/26/2011
