- To:
- Subject: Re: [cgal-discuss] Circular Arc imprecision in arrangements
- Date: Thu, 12 May 2011 08:52:30 +0200
Jan-Hinrich Kaemper wrote:
Eric Berberich wrote:
jahikae wrote:Hello Eric,
I'm working with arrangements using conics as traits-type.
Now, in my application I sometimes have to replace straight line segments of
the arrangement with circular arcs.
The problem is that circular arcs can only be constructed with the rational
number Kernel.
The two original endpoints of the straight segment however can be
irrational. So there is no way to preserve these original vertices and at the same time
have the new circular arc passing through them.
What I do until now is taking rational coordinates very close to the
original endpoints and use those as endpoints for the circular arc. But this
messes up my arrangement, because the nearby faces all get merged because of
the gap that I introduce. I have to avoid this somehow.
Is there any way to construct circular arcs having the exact two endpoints
of the original straight line?
And if not, how could I best fix the problem?
Thanks!
Dear Jan-Hinrich,
can you give some more background on the application. With the given information the answer is: It requires a non-rational number type for the endpoints of the segments. Conversion is not immediate, but possible.
With more background, we maybe have more ideas to help you.
Best regards, eriC
Hi Jan,
basically what my application does is to begin with an arrangement
where all edges are straight line segments.
Depending on the input data it bends some of these edges, i.e. replaces them with circular arcs.
Is there some additional structure/information that you can exploit?
So, for a new circular arc two points (source and target) are always given by the endpoints
of the previous straight line to be replaced and the third point can be calculated from the data.
Two points are taken from the arragement of segments, right. Both are rational, right? The third point is rational, too?
Now, as I'm obliged to construct the circular arc with rational coordinate points only,
I can't make the arc fit exactly in the place where the straight line was before.
This I do not get. The circle (and I guess thus also your arc) is defined by the three rational points through which the arc passes ...
So what happens is that I have to approximate the endpoints of the circular arc (to rational numbers), which
... but why do you have to still rationalize them? Or do you want less bits?
isn't satisfying as faces of my arrangement on the two sides of circular arc are merged into one face, because
the arc is disconnected from the previously neighboring edges.
I hope this has made it a bit clearer.
The disconnection is technically clear, but I do not see why the circular arcs endpoints are not vertices of the segment arrangement.
For the arrangement I use non-rational number-types.
Can you tell which traits class and which number type you use?
So this should meet the requirement you mentioned I guess?
eriC
- [cgal-discuss] Circular Arc imprecision in arrangements, jahikae, 05/12/2011
- Re: [cgal-discuss] Circular Arc imprecision in arrangements, Eric Berberich, 05/12/2011
- Re: [cgal-discuss] Circular Arc imprecision in arrangements, Jan-Hinrich Kaemper, 05/12/2011
- Re: [cgal-discuss] Circular Arc imprecision in arrangements, Monique Teillaud, 05/12/2011
