- To:
- Subject: Re: [cgal-discuss] Circular Arc imprecision in arrangements
- Date: Thu, 12 May 2011 09:49:09 +0200
Le 12/05/11 01:14, jahikae a écrit :
I'm working with arrangements using conics as traits-type.
Now, in my application I sometimes have to replace straight line segments of
the arrangement with circular arcs.
Dear Jan-Hinrich,
The problem is that circular arcs can only be constructed with the rational
number Kernel.
Not only. More precisely, the centers and squared radius of circles are rational, but not necessarily the endpoints of circular arcs.
I am not sure I fully get your question, so let me first write how I understand it:
The endpoints of your input line segments have non-rational coordinates, apparently because they are constructed from lines and conics. So, their coordinates are algebraic numbers of degree 2.
Then you want to construct circular arcs whose endpoints are such algebraic points.
The two original endpoints of the straight segment however can be
irrational.
So there is no way to preserve these original vertices and at the same time
have the new circular arc passing through them.
If you use CGAL::Arr_circular_line_arc_traits_2<CircularKernel>
then there are several ways in which circular arcs can be constructed, and some of them take algebraic points and endpoints, and keep their coordinates exact.
Hopefully you can find one constructor that works for you, see
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Circular_kernel_2_ref/FunctionObjectConcept_CircularKernel--ConstructCircularArc_2.html#Cross_link_anchor_803
But CGAL::Arr_circular_line_arc_traits_2<CircularKernel> cannot handle conics. Do you actually need arrangements of conics?
I am not very familiar with the arrangement package, maybe other traits classes can construct circular arcs from algebraic endpoints, too. There are other people who know better.
Still, I hope this helps.
Best regards,
Monique
What I do until now is taking rational coordinates very close to the
original endpoints and use those as endpoints for the circular arc. But this
messes up my arrangement, because the nearby faces all get merged because of
the gap that I introduce. I have to avoid this somehow.
Is there any way to construct circular arcs having the exact two endpoints
of the original straight line?
And if not, how could I best fix the problem?
Thanks!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Circular-Arc-imprecision-in-arrangements-tp3516105p3516105.html
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
- [cgal-discuss] Circular Arc imprecision in arrangements, jahikae, 05/12/2011
- Re: [cgal-discuss] Circular Arc imprecision in arrangements, Eric Berberich, 05/12/2011
- Re: [cgal-discuss] Circular Arc imprecision in arrangements, Jan-Hinrich Kaemper, 05/12/2011
- Re: [cgal-discuss] Circular Arc imprecision in arrangements, Monique Teillaud, 05/12/2011
