- To: "cgal-discuss-list" <>
- Subject: [cgal-discuss] precondition violation when intersecting a line with a sphere
- Date: Fri, 13 May 2011 00:30:05 +0800
- Importance: Normal
Hi,
I encounterd a precondition violation error when I was trying to find the
intersection between a line and a sphere.
CGAL error: precondition violation!
_expression_ : !p.degenerated()
File :
d:\codes\lib\cgal-3.7\include\cgal\algebraic_kernel_for_spheres\int
ernal_functions_on_roots_and_polynomial_1_3_and_2_3.h
Line : 212
Explanation:
Refer to the bug-reporting instructions at http://www.cgal.org/bug_report.html
I provide necessary info in the following to help reproduce the
error:
typedef CGAL::Cartesian<double> K;
typedef CGAL::Spherical_kernel_3<K,
CGAL::Algebraic_kernel_for_spheres_2_3<int> > SphericalK;
typedef SphericalK::Point_3 Point_3_SK;
// to compute the intersection, I construct a line and a sphere using the
spherical kernel as follows:
CGAL::Line_3<SphericalK> line(Point_3_SK(-0.1,-0.1,-0.1),
Point_3_SK(-0.1,-0.1,0.0));
CGAL::Sphere_3<SphericalK> s(Point_3_SK(0, 0, 0), 0.1); // c is a
Point_3
vector<CGAL::Object> isecs;
CGAL::intersection(line, s, std::back_inserter(isecs));
The assertion error is issued from within CGAL::intersection, when it tries
to do the confirmation,
actually, from this function:
template < class AK, class OutputIterator >
inline
OutputIterator
solve(const typename AK::Polynomials_for_line_3
&p,
const typename
AK::Polynomial_for_spheres_2_3& s,
OutputIterator res )
// we must have a line
CGAL_kernel_precondition(!p.degenerated());
Does this failure of assertion indicates I constructed a degenerate line?
But from the code you can see the line should be non-degenerate.
Thanks if anyone can point out the problem!
Yan. |
- [cgal-discuss] precondition violation when intersecting a line with a sphere, yanyajie, 05/12/2011
- Re: [cgal-discuss] precondition violation when intersecting a line with a sphere, Sebastien Loriot (GeometryFactory), 05/12/2011
- Re: [cgal-discuss] precondition violation when intersecting a line with a sphere, yanyajie, 05/13/2011
- Re: [cgal-discuss] precondition violation when intersecting a line with a sphere, Sebastien Loriot (GeometryFactory), 05/13/2011
