Re: [cgal-discuss] precondition violation when intersecting a line with a sphere
- To: <>
- Subject: Re: [cgal-discuss] precondition violation when intersecting a line with a sphere
- Date: Fri, 13 May 2011 11:10:17 +0800
- Importance: Normal
Dear S.
I fixed the problem by sustituting int with double in the algebraic_kernel,
but intersection routine just doesn’t return objects whose type is what I
expect. In the following code, the intersection definitely happens, and two
objects are inserted in vector isecs. If nothing goes wrong, they should be two
Point_3_SK instances, right? However, object_cast<Point_3_SK> only yields
null pointer.
typedef SphericalK::Line_3 Line_3_SK;
typedef SphericalK::Sphere_3 Sphere_3_SK;
Line_3_SK line (Point_3_SK(0, 0, 0), Point_3_SK(0, 0,
1));
Sphere_3_SK sphere(Point_3_SK(0, 0, 0), 5);
vector<CGAL::Object> isecs;
CGAL::intersection(line, sphere,
std::back_inserter(isecs));
const Point_3_SK *isec_p =
CGAL::object_cast<Point_3_SK>(&isecs[0]);
Where does the problem lie?
Thank you for your time!
Yan.
Sent: Friday, May 13, 2011 10:32 AM
To:
a line with a sphere Dear S.
O! I was so naïve, as I thought “int” should be
the type used to instantiate Algebraic_kernel when I saw a RT in
CGAL::Algebraic_kernel_for_spheres_2_3<RT>OK, thank you! I’ll see if this correction could solve the problem.
Yan.
-----原始邮件-----
Sent: Friday, May 13, 2011 1:45 AM
To:
with a sphere
Algebraic_kernel_for_spheres_2_3<int>
should be Algebraic_kernel_for_spheres_2_3<double>
You also should consider using an exact type.
Please read:
http://www.cgal.org/FAQ.html#inexact_NT
yanyajie wrote:
> Hi,
> I encounterd a precondition violation error when I was trying to find
> the intersection between a line and a sphere.
> CGAL error: precondition violation!
> _expression_ : !p.degenerated()
> File :
d:\codes\lib\cgal-3.7\include\cgal\algebraic_kernel_for_spheres\int
> ernal_functions_on_roots_and_polynomial_1_3_and_2_3.h
> Line : 212
> Explanation:
> Refer to the bug-reporting instructions at
> http://www.cgal.org/bug_report.html
> I provide necessary info in the following to help reproduce the
error:
> typedef CGAL::Cartesian<double> K;
> typedef CGAL::Spherical_kernel_3<K,
> CGAL::Algebraic_kernel_for_spheres_2_3<int> >
SphericalK;
> typedef SphericalK::Point_3 Point_3_SK;
> // to compute the intersection, I construct a line and a sphere using
> the spherical kernel as follows:
> CGAL::Line_3<SphericalK> line(Point_3_SK(-0.1,-0.1,-0.1),
> Point_3_SK(-0.1,-0.1,0.0));
> CGAL::Sphere_3<SphericalK> s(Point_3_SK(0, 0, 0), 0.1); // c is
a Point_3
> CGAL::intersection(line, s, std::back_inserter(isecs));
> The assertion error is issued from within CGAL::intersection, when it
> tries to do the confirmation,
> actually, from this function:
> template < class AK, class OutputIterator >
> inline
> OutputIterator
> solve(const typename
AK::Polynomials_for_line_3 &p,
> const
typename AK::Polynomial_for_spheres_2_3& s,
> OutputIterator res )
> // we must have a line
> CGAL_kernel_precondition(!p.degenerated());
> Does this failure of assertion indicates I constructed a degenerate
> line? But from the code you can see the line should be
non-degenerate.
> Thanks if anyone can point out the problem!
> Yan.
- [cgal-discuss] precondition violation when intersecting a line with a sphere, yanyajie, 05/12/2011
- Re: [cgal-discuss] precondition violation when intersecting a line with a sphere, Sebastien Loriot (GeometryFactory), 05/12/2011
- Re: [cgal-discuss] precondition violation when intersecting a line with a sphere, yanyajie, 05/13/2011
- Re: [cgal-discuss] precondition violation when intersecting a line with a sphere, Sebastien Loriot (GeometryFactory), 05/13/2011
