cgal-discuss - [cgal-discuss] want to use CGAL in Matlab, but can't compile mex file in matlab,
  • To:
  • Subject: [cgal-discuss] want to use CGAL in Matlab, but can't compile mex file in matlab,
  • Date: Fri, 13 May 2011 17:37:45 -0700
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=toZTs4AptNZsfS0IKlcyUF5wAxFvLQIF+tec9fH6YNU7SM0WQbvsnfaR1GaLqB1qyz g2cECnfsPxBpNsRdYBKA0cwBVwKopxurFW4oUd+gr+dqtM+1+4hSl2ovcd60173A0yqC 8rit/vQxRmvZH+WyBGPUw+EfQvRt7JYUO4H6s=
Hi, everyone,
      In fact, I can compile it before I update my Ubuntu system to 11.04 and CGAL to 3.8. But now, it can't compile. The error information is at the bottom. I can't understand the error. Who can give me some suggestion or hints about it?
     Thanks a lot!
Best
Huayi
      mex -v spherevoronoi.cpp -lCGAL -lgmp -lboost_thread  -I/usr/include/:/usr/local/include/:/opt/matlab/extern/include/ -L/usr/lib/:/usr/local/lib/:/opt/matlab/extern/lib/glnxa64
-> mexopts.sh sourced from directory (DIR = $HOME/.matlab/$REL_VERSION)
   FILE = /home/huayiwei/.matlab/R2010a/mexopts.sh
->    MATLAB                = /opt/matlab
->    CC                    = gcc
->    CC flags:
         CFLAGS             = -ansi -D_GNU_SOURCE  -fexceptions -fPIC -fno-omit-frame-pointer -pthread
         CDEBUGFLAGS        = -g
         COPTIMFLAGS        = -O -DNDEBUG
         CLIBS              = -Wl,-rpath-link,/opt/matlab/bin/glnxa64 -L/opt/matlab/bin/glnxa64 -lmx -lmex -lmat -lm -lstdc++
         arguments          =  -DMX_COMPAT_32
->    CXX                   = g++
->    CXX flags:
         CXXFLAGS           = -ansi -D_GNU_SOURCE -fPIC -fno-omit-frame-pointer -pthread
         CXXDEBUGFLAGS      = -g
         CXXOPTIMFLAGS      = -O -DNDEBUG
         CXXLIBS            = -Wl,-rpath-link,/opt/matlab/bin/glnxa64 -L/opt/matlab/bin/glnxa64 -lmx -lmex -lmat -lm
->    FC                    = g95
->    FC flags:
         FFLAGS             = -fexceptions -fPIC -fno-omit-frame-pointer
         FDEBUGFLAGS        = -g
         FOPTIMFLAGS        = -O
         FLIBS              = -Wl,-rpath-link,/opt/matlab/bin/glnxa64 -L/opt/matlab/bin/glnxa64 -lmx -lmex -lmat -lm
->    LD                    = g++
->    Link flags:
         LDFLAGS            = -pthread -shared -Wl,--version-script,/opt/matlab/extern/lib/glnxa64/mexFunction.map -Wl,--no-undefined
         LDDEBUGFLAGS       = -g
         LDOPTIMFLAGS       = -O
         LDEXTENSION        = .mexa64
         arguments          =  -lCGAL -lgmp -lboost_thread -L/usr/lib/:/usr/local/lib/:/opt/matlab/extern/lib/glnxa64
->    LDCXX                 =
->    Link flags:
         LDCXXFLAGS         =
         LDCXXDEBUGFLAGS    =
         LDCXXOPTIMFLAGS    =
         LDCXXEXTENSION     =
Warning: You are using gcc version "4.5.2-8ubuntu4)".  The version
         currently supported with MEX is "4.2.3".
         For a list of currently supported compilers see:
         http://www.mathworks.com/support/compilers/current_release/
-> g++ -c  -I/usr/include/:/usr/local/include/:/opt/matlab/extern/include/ -I/opt/matlab/extern/include -I/opt/matlab/simulink/include -DMATLAB_MEX_FILE -ansi -D_GNU_SOURCE -fPIC -fno-omit-frame-pointer -pthread  -DMX_COMPAT_32 -O -DNDEBUG  "spherevoronoi.cpp"
/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2/cc1plus: /opt/matlab/sys/os/glnxa64/libstdc++.so.6: version `GLIBCXX_3.4.14' not found (required by /usr/lib/libppl_c.so.2)
/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2/cc1plus: /opt/matlab/sys/os/glnxa64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/libppl_c.so.2)
/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2/cc1plus: /opt/matlab/sys/os/glnxa64/libstdc++.so.6: version `GLIBCXX_3.4.14' not found (required by /usr/lib/libppl.so.7)
/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2/cc1plus: /opt/matlab/sys/os/glnxa64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/libppl.so.7)
/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2/cc1plus: /opt/matlab/sys/os/glnxa64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/libgmpxx.so.4)
    mex: compile of ' "spherevoronoi.cpp"' failed.
??? Error using ==> mex at 222
Unable to complete successfully.
// Huayi Wei, <>
#include <CGAL/Surface_mesh_default_triangulation_3.h>
#include <iostream>
#include <fstream>
#include <list>
#include <set>
#include <vector>
#include "matrix.h"
#include "mex.h"
// default triangulation for Surface_mesher
typedef CGAL::Surface_mesh_default_triangulation_3 Delaunay3d;
typedef Delaunay3d::Finite_vertices_iterator Vit;
typedef Delaunay3d::Cell_handle Cell_handle;
typedef Delaunay3d::Vertex_handle Vertex_handle;
typedef Delaunay3d::Facet  Facet;
typedef Delaunay3d::Edge   Edge;
typedef Delaunay3d::Triangle Triangle;
typedef Delaunay3d::Geom_traits GT;
typedef GT::Point_3 Point_3;
typedef GT::Vector_3 Vector_3;
typedef GT::FT FT;
void mexFunction(int nlhs, mxArray* plhs[], int nrhs, mxArray *prhs[]){
  /* Check for proper number of input and output arguments */
  if (nrhs != 1) {
    mexErrMsgTxt("we need one input of generators!");
  if(nlhs > 2){
    mexErrMsgTxt("Too many output arguments.");
  mwIndex offset;
  mxArray * generator_on_sphere = prhs[0];
  mwSize number_of_generator = mxGetM(generator_on_sphere);
  std::vector<Point_3> points;
  double * pg_on_sphere = mxGetPr(generator_on_sphere);
  for(int i = 0; i < number_of_generator; i++){
    int subs[2];
    subs[0]=i;
    subs[1]=0;
    offset = mxCalcSingleSubscript(generator_on_sphere,2,subs);
    double x = pg_on_sphere[offset];
    subs[1]=1;
    double y = pg_on_sphere[offset];
    subs[1]=2;
    double z = pg_on_sphere[offset];
    points.push_back(Point_3(x,y,z));
  //produce the delaunay triangulation
  Delaunay3d D3d(points.begin(),points.end());
  //compute the circumcenter of the facet on the sphere surface
  std::map<Facet,int> facets_map;
  std::vector<Point_3> circumcenters;
  int count = 0;
  std::vector<Cell_handle> all_infinite_cells;
  D3d.incident_cells( D3d.infinite_vertex(), std::back_inserter(all_infinite_cells));
  std::vector<Cell_handle>::iterator cit = all_infinite_cells.begin();
  for( ;cit != all_infinite_cells.end(); cit++){
    int idx =(*cit)->index(D3d.infinite_vertex());
    Facet facet = Facet(*cit,idx);
    facets_map[facet]=count;
    Triangle t = D3d.triangle(facet);
    Point_3 p = CGAL::circumcenter(t);
    FT r = CGAL::sqrt(p.x()*p.x()+p.y()*p.y()+p.z()*p.z());
    circumcenters[count] = Point_3(p.x()/r,p.y()/r,p.z()/r);
    count ++;
  //construct the voronoi diagram
  std::vector<Edge> all_infinite_edges;
  std::vector<std::list<int> > voronoi_cells;
  D3d.incident_edges(D3d.infinite_vertex(),std::back_inserter(all_infinite_edges));
  std::vector<Edge>::iterator eit = all_infinite_edges.begin();
  for(;eit != all_infinite_edges.end(); eit++){
    std::list<int> idx_of_voronoi_vertices;
    Cell_handle cell = (*eit).first;
    int i = (*eit).second;
    int j = (*eit).third;
    Vertex_handle v1, v2;// v1 is the finite vertex and v2 the infinite vertex of edge *eit
    if (D3d.is_infinite(cell->vertex(i))){
      v1 = cell->vertex(j);
      v2 = cell->vertex(i);
    }else{
      v1 = cell->vertex(i);
      v2 = cell->vertex(j);
    Delaunay3d::Cell_circulator ccir = D3d.incident_cells(*eit);
    Delaunay3d::Cell_circulator ccir_begin = ccir;
    bool flag = true;
    while(true){
      Delaunay3d::Cell_circulator ccir_tmp = ccir++;
      int k1 = ccir_tmp->index(v1);
      int k2 = ccir_tmp->index(v2);
      idx_of_voronoi_vertices.push_back(facets_map[Facet(ccir_tmp,k2)]);
      if(flag)
	for( int j =0; j < 3; j++){
	  if(k1 == D3d.vertex_triple_index(k2,j)){
	    j = (j+2)%3;
	    if(ccir_tmp->neighbor(D3d.vertex_triple_index(k2,j))==ccir)
	      flag = false;
      if( ccir == ccir_begin)
	break;
    if(!flag)
      idx_of_voronoi_vertices.reverse();
    voronoi_cells.push_back(idx_of_voronoi_vertices);
  // set the return data: cell
  mxArray *cell_matrix = mxCreateCellMatrix((mwSize)number_of_generator,1);
    int n = voronoi_cells[i].size();
    mxArray * mxcell = mxCreateDoubleMatrix((mwSize)n,1, mxREAL);
    double * ptr = mxGetPr(mxcell);
    std::list<int>::iterator it;
    int j = 0;
    for(it = voronoi_cells[i].begin(); it != voronoi_cells[i].end(); it++)
      ptr[j++]=*it;
    mxSetCell(cell_matrix,i,mxcell);
  // voronoi vertex
  mxArray * voronoi_vertices_matrix = mxCreateDoubleMatrix((mwSize)count,3, mxREAL);
  double * ptr_vv = mxGetPr(voronoi_vertices_matrix);
  for(int i = 0; i < count; i++){
    int subs[2];
    subs[0]=i;
    subs[1]=0;
    offset = mxCalcSingleSubscript(voronoi_vertices_matrix,2,subs);
    ptr_vv[offset] = circumcenters[i].x();
    subs[0]=i;
    subs[1]=1;
    ptr_vv[offset] = circumcenters[i].y();
    subs[0]=i;
    subs[1]=2;
    ptr_vv[offset] = circumcenters[i].z();
  plhs[0] =  voronoi_vertices_matrix;
  plhs[1] =  cell_matrix;
