- To:
- Subject: Re: [cgal-discuss] Triange/Triangle Intersection
- Date: Fri, 13 May 2011 19:59:23 +0200
Am 2011-05-13 09:36, schrieb Marc Glisse:
On Thu, 12 May 2011, Marc Glisse wrote:
Indeed, I can't see anything in Lazy.h to interpret the
std::vector<Approximate_kernel::Point_3> returned by the approximate
kernel to output a std::vector<Lazy_kernel::Point_3> (both wrapped in
an Object). And we had better hope that the order of the points in the
vector will be the same with the exact kernel (but then I guess the
same applies to segments and triangles and is safe enough as long as
they use the same deterministic code).
Compiling with -DCGAL_DONT_USE_LAZY_KERNEL would work around this, at
the price of a slowdown.
The attached patch partially fixes things when the intersection type is
vector<Point_2> (replace Point_2 by Point_3 in the patch for your case)
but it forces an exact evaluation in this case because I was too lazy to
finish it properly.
Thank you for your work! I go on holliday tomorrow but I will
try that as soon as possible.
Best
Bernhard
- [cgal-discuss] Triange/Triangle Intersection, Bernhard Kornberger, 05/12/2011
- Re: [cgal-discuss] Triange/Triangle Intersection, Sebastien Loriot (GeometryFactory), 05/12/2011
- Re: [cgal-discuss] Triange/Triangle Intersection, Bernhard Kornberger, 05/12/2011
- Re: [cgal-discuss] Triange/Triangle Intersection, Marc Glisse, 05/12/2011
- Re: [cgal-discuss] Triange/Triangle Intersection, Marc Glisse, 05/13/2011
- Re: [cgal-discuss] Triange/Triangle Intersection, Bernhard Kornberger, 05/13/2011
