- To:
- Subject: Re: [cgal-discuss] "unite" operation in MinKowski_2
- Date: Mon, 16 May 2011 16:45:24 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=rl1Bcti5IcspBSxnkT4nK5Wo6qHimvptW7xbGI/MVeCgWRT86T6Iq0d+V8i61A/5Hy Grqz83vufaVDtrcQejZcugTYHClpVxZNTyCLVsHLtcb4YW2cyDcIdyqFElYoIz3kmSrk X6RQRzIdt5cziQG7ZoSCNGhlKp+ZmyAgPh2S0=
Dear S.
Maybe I didn't quite clearly describe my problem. I will restate the problem here and include files in the attachment(can be executed in VS2008)for you to reproduce the error.
I need to define a 2d Point class of my own. The objects of this Point class makes up the polygons that are involved in Minkowski Sum computation.
It looks something like the following:
typedef CGAL::Exact_predicates_exact_constructions_kernel ExactK;
typedef ExactK::FT MP_FT;
class C_Point2
private:
MP_FT pos[2];
// other info specific to C_Point2
// methods required to return cartesion coordinates
Also, I defined all the necessary classes for the Point to work with CGAL, i.e. C_Construct_point2, C_Construct_coord_iterator, and most of all, the kernel class C_Kernel. They can be found in the attached files.
I first write a simple demo to test the validity of C_Point2.
int main()
Point p(0.1, 0.2);
MP_FT x = p.x();
std::cout << p.x() << std::endl;
MP_FT x = p.x();
However, the problem issued when p.x() executes. I found the error is caused by a test down in to_double() method:
// Interval_nt.h
bool is_point() const
return sup() == inf();
It seems that it complains the cartesion component of C_Point has different supremum and infimum. If my guess is right, how could this happen?
Really need some pointers here.
Thanks alot!
Sincerely,
Yue.
2011/5/16 Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com>
Can you post a complete minimal example showing the problem?
S.
Yue Biek wrote:
Hello,2011/5/13 Efraim Fogel < <mailto:>>
This time I used the Lazy_exact type for my Point class,but I met problems once more,the problems are discribed as follows.
The Point Class in my code is:
Class MyPoint
{ private:
MP_FT pos[2]; //used to store x and y coordinate public:
MP_FT & x() {return *pos;}
I used the following code to show my problem. in main function:
int main()
Point p(0.1, 0.2);
MP_FT x = p.x();
but the code show faults:the wrong place is in Interval_nt.h and the code is:
Thank you!
You need to use exact-predicate and exact-construction kernel.
When you attach code, attach it in a way that it can be compiled and
executed, and perhaps even read by a human being.
Yue Biek wrote:
My OS is win7(32bit) and environment is VS2008,When I used the
MinKowski_2 in CGAL_3.8, I found the Union operation of two
Boundarys is something wrong.
the function are usd in Minkowski_sum_decomp_2.h
*The exact line is :*
sum_holes = unite(boundary_segments.begin(),
boundary_segments.end(),sum_bound, sum_holes);
My target is to morph between two non-convex but simple polygons.
At first,when I morph between a triangle and a rectangle,the
"unite" operation is right.and the morph process is right.
However,when the input are two non-convex
polygons(PandQ.dat),though the MinKowski sums of the two
polygons can be calcuated, the "unite" operation are something
wrong. when the input are two non convex polygons, the "unite"
operation are right the in the first time,but in the second time
,it fails.
Part of source code are here,Polygon P and Polygon Q are defined
before hand,and they are all non-convex and simple(PandQ.dat).
glClear(GL_COLOR_BUFFER_BIT);
float delt=0.11;
while(true)
for(float t=0.1;t<=0.9;t+=delt)
Polygon s_temp;
Polygon t_temp;
for(size_t i=0;i!=P.size();i++)
double temp_x=P[i].x()*(1-t);
double temp_y=P[i].y()*(1-t);
Point temp_p(temp_x,temp_y);
s_temp.push_back(temp_p);
for(size_t i=0;i!=Q.size();i++)
double temp_x=Q[i].x()*t;
double temp_y=Q[i].y()*t;
t_temp.push_back(temp_p);
Polygon_with_holes sum=minkowski_sum_2(s_temp,t_temp,ssab_decomp);
std::cout << "P = "; print_polygon (s_temp);
std::cout << "Q = "; print_polygon (t_temp);
std::cout << "P (+) Q = ";print_polygon(sum.outer_boundary());
if(!sum.is_unbounded())
glBegin(GL_LINE_LOOP);
for(Polygon::iterator
cur=sum.outer_boundary().vertices_begin();cur!=sum.outer_boundary().vertices_end();cur++)
glVertex2f(cur->x(),cur->y());
glEnd();
glFlush();
else
for (Polygon_with_holes::Hole_iterator
iter=sum.holes_begin();iter!=sum.holes_end();++iter)
Polygon::iterator piter=iter->vertices_begin();
for(;piter!=iter->vertices_end();piter++)
double temp_x=piter->x();
double temp_y=piter->y();
glVertex2f(temp_x,temp_y);
glEnd();
sum.clear();
s_temp.clear();
t_temp.clear();
if(s_temp.is_empty())
cout<<"empty "<<endl;
if(t>1.0||t<0.1)
delt=-delt;
-- ____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
-- You are currently subscribed to cgal-discuss.
C_Point2.rar
Description: application/rar
- [cgal-discuss] "unite" operation in MinKowski_2, Yue Biek, 05/12/2011
- Re: [cgal-discuss] "unite" operation in MinKowski_2, Efraim Fogel, 05/12/2011
- Re: [cgal-discuss] "unite" operation in MinKowski_2, Yue Biek, 05/15/2011
- Re: [cgal-discuss] "unite" operation in MinKowski_2, Sebastien Loriot (GeometryFactory), 05/16/2011
- Re: [cgal-discuss] "unite" operation in MinKowski_2, Yue Biek, 05/16/2011
- Re: [cgal-discuss] "unite" operation in MinKowski_2, Bernd Gaertner, 05/16/2011
- Re: [cgal-discuss] "unite" operation in MinKowski_2, Marc Glisse, 05/16/2011
