cgal-discuss - Re: [cgal-discuss] "unite" operation in MinKowski_2
  • To:
  • Subject: Re: [cgal-discuss] "unite" operation in MinKowski_2
  • Date: Mon, 16 May 2011 18:55:46 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=nrTL+IFi17BpWzgnHpoh2pGtlkHQbXP9FPIhXIUL4rvf5VvNOjcOmqqigq/+RsBlom VGXGUZ3KlxacnYijG7N42S0ntwBRyGDZwN4UIo7YwM8WQnpgng7PyiusK8seBlV4SfNm 2j2o6z7imB/6unFyQkCKfVMLxog/39G9Y+JAI=
Sorry, when I use se Point p(1,2),the problem breakdown without any debug information.thank you all the same.
2011/5/16 Bernd Gaertner <>
My guess is that since the decimal value 0.1 is not representable as a double value under the binary IEEE standard, Lazy_exact_NT gives you a surrounding interval that is more than just one point. If so, this particular problem should go away if you use Point p(1,2).
Best,
Bernd.
Yue Biek wrote:
I first write a simple demo to test the validity of C_Point2.
int main()
Point p(0.1, 0.2);
MP_FT x = p.x();
std::cout << p.x() << std::endl;
However, the problem issued when p.x() executes. I found the error is caused by a test down in to_double() method:
// Interval_nt.h
bool is_point() const
  return sup() == inf();
It seems that it complains the cartesion component of C_Point has different supremum and infimum. If my guess is right, how could this happen?
Really need some pointers here.
