- To:
- Subject: Re: [cgal-discuss] Stack overflow in Alpha_shape_2
- Date: Thu, 26 May 2011 09:12:09 +0200
Two questions:
1) Is there a reason why you cannot use Exact_predicates_inexact_constructions_kernel?
2)We are really interested by a minimal example showing the problem.
Would be nice to have it (private message is fine).
S.
Marc Glisse wrote:
On Wed, 25 May 2011, GIS Worx wrote:
Thanks for the thread on the other issue. I think I may try avoiding the
Lazy_kernel, to see how performance is affected.
Note that when you disable the lazy kernel, IIRC, Epeck still uses a lazy number type, which could make it even worse. If you don't want any laziness, you could try something like: Filtered_kernel<Simple_cartesian<Gmpq> >
Many thanks for the suggestions, with a nudge to the right stack reserve
size, it works.
Using /F didn't produce results when set to an unreasonably low value. I
learned you have to actually modify the .exe for any /STACK option to work
(rather than my little CGAL related DLL). Using a VS2008 build environment,
a stack reserve size of 1750000B succeeds and 1500000B fails. The default
for the linker is 1MB.
Less than 2MB, so it's not too wild.
Sometimes, GMP can use quite a bit of stack space itself. I don't know how you got your GMP, but replacing 65536 by something much smaller (say 1024) in the definition of TMP_ALLOC in gmp-impl.h and recompiling can help.
I know that the Lazy_kernel is supposed to be more efficient, but I wonder
if recursion this deep really be more efficient that simply outright
evaluating on the spot.
Well the whole point is that in many cases you don't need the evaluation, and the approximate value stored in each node is sufficient. So in some sense, the deeper the DAG, the larger the potential gain.
I also wonder if there is something about my scenario that produces a particularly pathological case for the lazy evaluation.
If you post a full reproducible example, maybe someday someone will look into it.
- [cgal-discuss] Stack overflow in Alpha_shape_2, gisworx, 05/24/2011
- Re: [cgal-discuss] Stack overflow in Alpha_shape_2, Marc Glisse, 05/25/2011
- Re: [cgal-discuss] Stack overflow in Alpha_shape_2, Francois Berenger, 05/25/2011
- Re: [cgal-discuss] Stack overflow in Alpha_shape_2, Laurent Rineau (GeometryFactory), 05/25/2011
- Re: [cgal-discuss] Stack overflow in Alpha_shape_2, GIS Worx, 05/25/2011
- Re: [cgal-discuss] Stack overflow in Alpha_shape_2, Sebastien Loriot (GeometryFactory), 05/26/2011
- Re: [cgal-discuss] Stack overflow in Alpha_shape_2, Sebastien Loriot (GeometryFactory), 05/31/2011
