cgal-discuss - Re: [cgal-discuss] Assertion of Minkowski_sum_3
  • To:
  • Subject: Re: [cgal-discuss] Assertion of Minkowski_sum_3
  • Date: Mon, 30 May 2011 10:00:55 +0200
ZHAO Junqiao (John) wrote:
Dear Sebastien,
Thanks very much for your efforts.
I discovered that Polyhedron_3::is_valid(true, x) will always produce NOT
VALID. When x is larger than 1.
I just realize that a call to Polyhedron_3::normalize_border() is needed
for is_valid test when level is greater than 0.
S.
In line 143 of HalfedgeDS_const_decorator.h, each time when the iteration is
finished, e will be equal to hds->halfedges_end(). However, the address of
the e is not NULL, which will not be equal to the address of
hds->border_halfedges_begin().
It is also interesting that neither correct.off and error.off could pass the
is_valid (, x) check (where x >0), but they do pass the is_closed () check.
So it's still not clear to me what are the causes of the problem.
I will do further investigation too.
Wishes,
John
-----Original Message-----
From: Sebastien Loriot (GeometryFactory) [mailto:] Sent: Friday, May 27, 2011 8:45 PM
To:
Sorry for the late answer,
I am working on a issue I though was similar to your
but one problem I have with correct.off and error.off is
that if I call the Polyhedron_3 method is_valid(true,4), then
it tells me that the polyhedron is not valid.
If I try loading the Nef_polyhedron using the function
OFF_to_nef_3, then the Nef_polyhedron I have is open and
so the minkowski sum cannot be done.
S.
