cgal-discuss - Re: [cgal-discuss] Re: Intersection of surfaces
  • To:
  • Subject: Re: [cgal-discuss] Re: Intersection of surfaces
  • Date: Mon, 30 May 2011 13:08:38 +0200
On 30/05/2011 12:38, Roger Mason wrote:
Hello Andreas,
"Andreas Fabri [via cgal-discuss]"
<[hidden email] </user/SendEmail.jtp?type=node&node=3560398&i=0>> writes:
> did you have a look at the user manual with the examples?
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Box_intersection_d/Chapter_main.html#Section_61.5
You mean define my Box_intersection_d like this?:
typedef CGAL::Delaunay_triangulation_2<Gt3> Terrain;
typedef
CGAL::Box_intersection_d::Box_with_handle_d<double,3,Terrain::Finite_faces_iterator,Iterator>
Box;
right. The manual page also has a paragraph refering to an
example for the Polyhedron. There as well, one stores handles
to facets:
This example can be easily extended to test polyhedral surfaces of the Polyhedron_3 class for (self-) intersections. The main difference are the numerous cases of incidences between triangles in the polyhedral surface that should not be reported as intersections, see the examples/Polyhedron/polyhedron_self_intersection.cpp example program in the Cgal distribution.
andreas
Thanks,
Roger
View this message in context: Re: Intersection of surfaces
<http://cgal-discuss.949826.n4.nabble.com/Intersection-of-surfaces-tp3549940p3560398.html>
Sent from the cgal-discuss mailing list archive
<http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
