cgal-discuss - [cgal-discuss] Re: Intersection of surfaces
  • To:
  • Subject: [cgal-discuss] Re: Intersection of surfaces
  • Date: Mon, 30 May 2011 06:15:57 -0700 (PDT)
Hello Andreas,
"Andreas Fabri [via cgal-discuss]"
<[hidden email]> writes:
> right.  The manual page also has a paragraph refering to an
> example for the Polyhedron. There as well, one stores handles
> to facets:
> This example can be easily extended to test polyhedral surfaces of the
> Polyhedron_3 class for (self-) intersections. The main difference are
> the numerous cases of incidences between triangles in the polyhedral
> surface that should not be reported as intersections, see the
> examples/Polyhedron/polyhedron_self_intersection.cpp example program in
> the Cgal distribution.
I think I tried something based on the manual example 61.5 a couple of
days ago, before I asked for help.
When I introduce:
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef Kernel::Point_3                                     Point_3;
typedef Kernel::Triangle_3                                  Triangle_3;
typedef std::vector<Triangle_3>                             Triangles;
typedef Triangles::iterator                                 Iterator;
into my existing code the application won't compile.  The stream of
errors is too long to include here.
I think it is time to give up on this.  Thank you very much for trying
to help, but I think using CGAL is beyond my programming skills.
Best wishes,
Roger
View this message in context: Re: Intersection of surfaces
